Question about Nikon D70 Body Only Digital Camera
Nikon D70 On/Off switch will not turn the camera off.
If you switch the camera on and off, it will not turn off. The only way to turn it off is to remove the battery. Any ideas? This is a Nikon D70 with about 8000 actuations.
  • 175 Answers
Hi, The problem with your camera is the power switch under the top cover needs to be repaired Or replaced by a camera repair tec, I have repaired this problem many times, Not a quick fix.
Posted on Feb 26, 2009
Tony, where can i purchase a new power switch, my Nikon D70 stopped working too. Thank you. melissa
Posted on Oct 22, 2012
Nikon D70 batteries discharging too quickly
Try switching to the EN-EL3 EN-EL3a 1500mAh Li-Ion Battery for Nikon D70..or a 1800mAh.
Mar 17, 2010 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon d70 digital camera wont come on when switched on
I had the same problem. Camera had to be sent back to Nikon repair depot.
Jun 10, 2009 | Nikon D70s Digital Camera
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
May 28, 2009 | Nikon D70s Digital Camera
Nikon D70 with brand new Sandik ultra11 2gb flash card error CHR
Go to the Nikon site and upgrade the firmware on your D70 to version 2.0.
Before doing that, try turning the camera off, wait a min, then back on. That sometimes clears the error. The D70 is having trouble reading the card(s) you're putting in. The upgrade fixes that.
Mar 09, 2009 | Nikon D70 Digital Camera with 18-70mm Lens
CAMERA WILL NOT SWITCH ON NIKON D70S
http://nikonsro.com/email_images/nikonusa/service_advisory/d70.html
Is this your problem? If so, Nikon will repair it for free, even if it's out of warantee. :)
P.S. Please stop "shouting!" (Turn off caps lock!)
May 31, 2008 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon d70 green led stays on
If green LED is blinking constantly when camera is turned on, this is a known problem with D70. Upgrade camera firmware from nikonusa.com website.
May 09, 2008 | Nikon D70s Digital Camera
Nikon d70 camera
switch off the camera.Remove the battery from the camera,after two minutes reload the battery.Switch on ok?
If not, using the reset option you can correct it.
If not, if you have warranty leave it with seller
Mar 28, 2008 | Nikon D70s Digital Camera
NIKON D70
problem in card holder repair or replace
Feb 11, 2008 | Nikon D70 Digital Camera with 18-50mm Lens
Nikon D70 Digital camera
More than likely you have a defective switch, which should only be replaced by a Nikon authorized repair facility, since opening the camera to repair / replace it yourself would void the warranty. If you can't find your warranty papers, warranty information is available from Nikon.com.
Dec 25, 2007 | Nikon D70s Digital Camera
D70 stuck
Make sure your memory card is OK. Take it out, put it back in or try another card. Be sure battery is charged. Should not see low battery sign in viewfinder or in top panel. Try a reset. There is a problem sort of related to what you describe where a firmware update may cure it. D70 Firmware Update 1.0.1 / 1.0.2 - Windows. One of the problems this firmware fixes is :"When images were captured in Continuous mode at an Image size setting of M and an Image quality setting of FINE, the memory card access lamp sometimes glowed continuously and the camera could not be turned off with the power switch. This problem has been corrected." This bit of advice comes from another Web forum, not my own discovery. Maybe this happened and ran down your battery, unbeknownst to you. Turn the camera off and power it from an electrical outlet. Update the firmware per instructions on the Nikon site. If this does not work or if your firmware is updated, call Nikon for further advice. You may need to have it serviced. This blinking light problem has been mentioned on PN and another forum. Nikon may be familiar with it already.
Sep 14, 2005 | Nikon D70 Digital Camera
Nikon D70 Body Only Digital Camera Logo
676 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
