Question about Altec Lansing Multimedia Computer Speakers
Connect Altec Lansing ADA745 to HD TV RCA output for home theater
Can I connect of my Altec Lansing subwoofer and speaker system to my HD television RCA output jacks by using terminal adapters and use it as a Home Theater system ?
  • sammolner Feb 25, 2009
    Thank you for the quick response and answering my question.
    Sam
  • sammolner Feb 26, 2009
    Rik,
    Any suggestions as to where I can get the adapters--and is there any cause to worry about possile harm to my new HD TV?
    Thanks,
    Sam
  • 77 Answers
Hiya
actually yes you can.....providing you get adapter cables 3.5mm jack to phono rca
Rik
Posted on Feb 25, 2009
    President:
  • 1,179 Answers
It won't work like this due to this being a computer only speaker system. It requires the drivers to work with a computer & a Home theater does not recognize the format. Sorry.
I want to connect ADA-995 speaker system to stereo
You don't. They're already amplified via the amp that's inside the subwoofer. They're only designed for a headphone output on a PV or portable audio player
Apr 03, 2014 | Altec Lansing Audio Players & Recorders
How do you connect the altec lansing ada 890 speakers to a flat panel HD TV
You can use the audio output RCA outputs to connect to the speakers. You need to use a multi- connector to match the input of the Altec. You can get the mating connectors to the headphone to RCA which can be connected to the Audio outputs. Also you can use a network to match the input impedance, use a simple reisitive network.
Dec 09, 2011 | Altec Lansing ADA 890 Computer Speakers
Can I connect my Altec Lansing ADA745 4.1 speaker system to an Acer AS5745-7247 laptop?
Yes. Altec Lansing ADA745 4 Speakers can be connected to a laptop.
Make the connections as follows
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Altec Lansing ADA745 4 Speakers
I just got a used set of altec lansing ADA745 computer speakers and can't get power to them. I have never seen computer speakers w/ two wires for input to the computer. I plugged the usual green colored...
https://support.dell.com/support/edocs/acc/ada745/ada745.pdf
That is the setup guide for the speakers.
The two wires plug into a cable that then that single cable plugs into the computer, this way you have sound coming out of the left and right hand speakers.
Feb 05, 2010 | Altec Lansing Multimedia Computer Speakers
I want to connect my subwoofer to my TV, can someone suggest how I go about it?
Check if your TV has RCA audio out with variable signal & get an RCA to mini jack cable to connect between the TV & the subwoofer.
Sep 19, 2009 | Altec Lansing VS4121 Speaker
Can the Altec Lansing VS3251 5.1 work with a Xbox?
Because this system is made to work with the PCs, it has a 3.5 mm stereo input. The 360 has rca cable outputs. Fortunately, the signal is the same and all you need is a 3.5 mm to rca y adapter that you can find at radioshack or any local electronics store.
Apr 14, 2009 | Altec Lansing VS3251 Speaker
I am not sure how to connect altec lansing vs3251 5.1 with my tv
U can connect it by a Y connector. Its a 3.5mm stereo jack on one end and the other end splits into two RCA sockts. So u can use these RCA sockets to connect to feed the audio output from the TV. thats all.
Apr 10, 2009 | Audiovox Audio Players & Recorders
My philips dvd player 5.1 have female ports at back side for audio but i have the sound system of LG which has simple naked wire to connect .
Philips DVP 3256 has 6 outputs which takes in RCA connectors
Altec lansing VS3251 has 3 STEREO outputs.
Buy 3 nos of STEREO (female) to RCA (male) cables
1. Connect the Altec's green wire to first stereo-to-RCA cable. RCA ends to DVP 3256's Front left and Front right
2. Connect the Altec's black wire to second stereo-to-RCA cable. RCA ends to DVP 3256's Rear left and Rear right
3. Connect the Altec's orange wire to third stereo-to-RCA cable. RCA ends to DVP 3256's Centre/Sub woofer. Interchange RCA ends if the Subwoofer sounds dull.
Good Luck
Jan 29, 2009 | Altec Lansing VS3251 Speaker
Altec Lansing ada745 fuse
It is written on the sub. You can also take it out or look at the spare which is taped to the power cord wall plug. I believe it's T1A 250V fuse
May 15, 2008 | Altec Lansing Multimedia Computer Speakers
1,237 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
