Question about Juki DDL-8300
Juki sweing machine timing problem
How do I repair the timing or adjust the timing on my Juki Sewing machine?
  • Anonymous Feb 27, 2009
    My timing is off, so the needles keep breaking and it won't sew.
    It happened after someone got alot of thred into the bobbin area
    and broke the needles.
  • 59 Answers
The timing of your sewing machine is, check your bobbin in right position, quit tightin the tension, and the timing for tiches is just always # 1.5
Posted on Mar 26, 2010
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
Nov 21, 2016 | Juki Sewing Machines
I need to know how to setting the looper timing on my Juki MO-655 serger. I don't have time to chase down a repair guy. Costume rush job.
Search the internet. There are web sites and videos that show machine timing, although adjusting a serger may a bit more challenging.
Oct 16, 2016 | Juki Sewing Machines
Juki industrial sewing machine. Machine will start sewing but after three stitches it stops.
You may need to adjust your tension dial with your fabric you are using and kind of thread, also adjust to thickness of fabric. Always use good sharp needles with your sewing and keep machine clean and oiled.
Feb 02, 2015 | Juki Sewing Machines
My wife broke several needles on her Juki DDL 555 machine and I need to know how to adjust the timing as she put a new needle in and the point was damaged
First thing to check is if you've got the right needle system: http://partsbooks.sewingmachine.com/Instructions/Juki/Industrial/DDL-5550%20&%205530%20Instruction%20Manual.pdf and that the needle is correctly oriented... the scarf has to be precisely set.
The next things I'd check are the stitch cycle -- hand crank the machine through the normal stitch cycle and see what's hitting. Then fix that. I've got my suspicions this may be a needle bar height adjustment. Don't thread up for this test... misthreading can also cause the needle to hit something and break, so start with the fewest possible variables first.
Feb 18, 2014 | Juki DDL-5550 Industrial Straight Stitch...
How do you adjust the timing on a Juki 1541-S walking foot sewing machine
Puckering can be from a number of different sources. The wrong needle/thread combo for the fabric. Poorly adjusted presser on the "feet"... too aggressive feed dogs.... It's hard to say without playing with the machine.
As to the company.... I would threaten to return it and demand a refund. It's amazing how fast they get a repair guy out there. Especially if it is under warranty.
Sep 23, 2012 | Juki Sewing Machines
Sewing machine needs the timming set on it
There is a guide for adjusting the timing in the repairs section at sewusa.com.
This adjustment is best done by a sewing machine tech.
May 06, 2010 | Juki TL-98Q
I have a juki sewing machine and the nittle
the problem of your juki sewing machine is your bobbin. adjust your bobbin to the right place.
Feb 16, 2010 | Juki MO-655 Mechanical Sewing Machine
Juki DDL-8300 Logo
1,055 people viewed this question
Top Juki Sewing Machines Experts
Tally Girl
Tally Girl
Pete Alaniz
Level 1 Expert
Derek Massey
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
