Question about Hansgrohe Axor Hansgrohe Starck Shower Column w/ Downpour Air Showerhead
Insufficient hot water from Gledhill pulsacoil 2000
I need showers for 6-7 people and my gledhill pulsacoil 2000 doesnt meet hot water requirements. Cold water by 5th shower. Should I change my boiler? Shower head is Hansgrohe Axor by Philipe Starck, I dont know if this is aerated. Could an aerated shower head help extend the hot water suppy to more showers?
  • Anonymous Mar 16, 2014
    what is the wiring plug at the back
  • 297 Answers
Changing the shower head will not do anything.to do what you want,you would need more BTU's or a bigger unit to supply more water,someone may be hogging the water also.
Posted on Jul 26, 2009
Water doesnt get hot unless you run the sink first then the wster on shower get boiling hot then ice cold showers a few weeks old
So you have 2 heating elements in your hot water heater. A top and a bottom. From the sounds of it your top element has went bad however they are only about $17 a piece new and it is recommended you replace both at the same time. Thats why it takes you long run to get hot water the top water heater water is still cold and long run gets to the bottom and gives you hot water.
Apr 03, 2015 | Home
Hello i have problem with my boiler mate 2000,when heating is swithch on , boiler on the kitchen still flashing with green lights (reset) im not sure how they fixted this problem all radiators ok ,hot
Hello Wojtek!
Over here in the colonies, we don't know from Boiler Mates, and I'm sure you have already discovered the same documents I foumd. The word "fiddly" came up in the second link and while we don't use that term often on this side of the pond, it definitely sounds pejorative.
Unfortunately, as we say over here, you may be "in for it".
Other than a reset, have you tried a "hard" reset by pulling the power? How about control/alt/delete ???
OK, now I'm getting silly.
All the best
http://www.gasapplianceguide.co.uk/Gledhill%20Boilermate%20explained.htm
http://www.gledhill-response.net/documents/boilermater2000switch_user.pdf
Dec 06, 2014 | Water Water Heaters
Triton thermostatic shower hot water is reaching the shower but not traverling any further only cold water comes out.i've had the whole shower system off the wall and hot water flows out of pipe but when i...
Could be the pressure on the hot water flow is insufficient, you really need a 5/6 feet head of water from the shower head to the bottom of the storage tank for sufficient pressure.
Nov 06, 2017 | Home
Push Pull Shower Valve also off in middle position
If you turn it to left or right (hot or cold) and get water out of the shower head,we'll elimate cloged shower head.If it just doesnt work in the middle ,probily a washer is stuck in your diverter,or to better understand>a part inside your shower knob assembly is clogging the water that goes up to your shower head. If you get water out of the shower head in the just cold possition or just hot position,then you will have to dissasemble the unit to repair. If you get no water in the cold or hot position could just be a clogged shower head.If you dont know how to disasemble a Shower diverter ,I wouldn't recommend taking it apart. Hope this helped!
Feb 09, 2012 | Moen Home
Rinnai gas water temperature keep alternating from hot to cold
A fault often found with these units is due to insufficient water flow. Usually this causes specifically the shower to run hot and cold. Try turning on more than one hot supply; if this fixxes the fault you will need to try and increase water flow. Most new tapware/showerware have water flow restictors built in. These are the cause of many problems with continous flow heaters such as the Rinnai. In taps they are usually located in the spout if it unscrews. In showers try the shower hose. Find them and take them out. Also make sure your mains supply to the house is on full.
There are more technical faults but this is something you can easily try first.
Aug 23, 2010 | Bosch & Tankless LP Hot Water Heater
I have to turn on lavatory faucet at the same time I'm running the shower so when I taking a shower the water doesnt go from hot to cold. It seams that maybe the hot water demad that the shower requires is...
This is not an uncommon problem with 'flash heaters' of this type; for safety, they all require a certain minimum of flow before the gas supply is turned on. Some brands/models have a factory-set adjustment for the minimum flow rate.
You might locate the mfr.'s website, contact them and describe your problem. This can also be caused by the modern flow-limited shower heads not allowing enough water to flow to keep the heater turned on.
If you have a retired shower head, you might try replacing the one currently used to see if it allows enough flow to allow proper operation. Either way, it is a waste of water.
Aug 03, 2010 | Kitchen Ranges
Insufficient pressure to force water through coffee
Propably the vibrating water pump is the problem.
It might be full of scale and it can not create any pressure or it is completetly damage and need to be replaced.
First we sugest to perform a descaling of the machine and try again.
Second you should try to reduce by little the quantity of the grounded coffee used. Aprox you should use 7 to7.5 gr of coffee. If you try to use about 6 to 6.5 and you have the coffee runing out from the machine like in 25 sec you have about 30 cc of water. Then try to clean the group shower which it can be ansrew by one cetrer screw and if you can you can open the machine and remove to clean also the coffee group solenoid valve. Bothe the valve and shower can be full of dry coffee that can blocked the way of water coming to the grounded coffee.
If you manage to clean everything above and the machine work ok so from now on in order to avoid the problem again try to flush water from the group many times without any coffee. With this is like you wash the group shower and valve from any remai coffee.
Good luck
Jun 04, 2010 | Krups Cappuccino/Espresso Maker -...
Water in shower not very hot
It could be possible you require more water volume, so take off both panels on youur water heater and check what temp. they are at.
I know I discovered the hard way there are 2 heaters and 1 of mine was low,good luke.
Mar 25, 2009 | Pegasus Technologies Home
Hansgrohe Axor Hansgrohe Starck Shower Column w/ Downpour Air Showerhead  Logo
486 people viewed this question
Top Hansgrohe Axor Home Experts
john h
Tom Chichester
Are you a Hansgrohe Axor Home Expert? Answer questions, earn points and help others
