Question about LG RU-60SZ30 60" Rear Projection HDTV-Ready Television
NOS GE Ballast - Good?
Have several unused, although probably 10 year old, GE ballasts for 2 40W bulbs. Haven't tried to hook them up yet. Can ballasts go bad just sitting arround?
  • clamjane Feb 25, 2009
    Thank you very much!!
  • 6,784 Answers
Hi, The GE ballasts that you are referring to is OK. if stored correctly, they should be just fine.
Posted on Feb 25, 2009
Headlamps not working.
is the light setup one ballast for high and low beam ? if so the ballast has gone, probably even the bulbs. replace the ballast and bulbs. some aftermarket ballasts don't last, if you cannot find the right ballast for replacement you will need to replace both ballasts. as every ballast set are set the same and sold in pairs.
Jun 01, 2017 | 2001 Oldsmobile Silhouette
Fluorescent light only one bulb out of two burning very dim
I like to start by swapping the position of the bulbs. If the one that didn't light, now does, it probably indicates a bad ballast (that long thin black "boxy thing" with wires coming out of it - it may be under a removable metal cover). Next replace the unlit bulb with a new one. If that doesn't light, try swapping the new light to the other position. If you still can't get two bulbs to light, replace both lamps with new ones. A good indication of a bad bulb is one or both blackened ends. The bulbs having two pins on each end have a small filament inside. This blackening is the metal of the filament "boiling off" and depositing on the glass. Eventually the filament gets thin and breaks so it doesn't provide the heat necessary to "prime"" the mercury inside the bulb that conducts electricity and excites the phosphor coating inside the bulb that emits light.If none of this works, most probably the ballast has "gone bad" and it, or the whole fixture, must be replaced, normally by an electrician. This can be done by the home "handyperson." You can cut the wires, remove the old ballast and replace it with a new one, splicing them to those of the same color from the new ballast using small "wire nuts." The one black and one white are the 120 volt power input wires. There are normally a pair of reds, a pair of blues, and a pair of yellows. Any wires of the same color are interchangeable. The blues and reds will go respectively to the bulb's sockets on one end of the fixture; the two yellows go to the opposite fixture end and are connected, in parallel electrically, to the other lamp sockets. If this makes sense, you may attempt to change your own ballast. If not, hire an electrician. Match the specifications for voltage, wattage, and number of bulbs, from your old ballast to the replacement - there are several different important electrical values to match even if the ballast looks physically the same size. Last, always turn off the electricity, and verify that it is safely off using a test light or meter before working on the fixture. Even though the black wire is normally energized and the white has zero volts measured with respect to ground, sometimes their function is reversed by an amateur where the wall switch may disconnect the black wire and make the fixture go off (as it should) yet the white wire remains dangerously energized, which is why you always test both of the wires with the test light or meter with respect to ground before touching any of them. Again, if this is not PERFECTLY clear, hire an electrician. Don't take chances, Electricity KILLS!
Apr 20, 2013 | Home
My 50in LCD has had a green tint to it for several months, was told by Best Buy that it was likely that a mirror got misaligned when we moved. Friend had the exact same tv...thought that the bulb went...
Good luck with that.... But if you really want to try,... look at where the bulb makes electrical connection when it is plugged into the set. You should see two thick wires leaving a connector and going to a circuit board. this board is the ballast. You'll have to disassemble until you can get the board along with the wires and connector.
Aug 14, 2010 | Panasonic PT-50LC13 50" Rear Projection...
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Mitsubishi 52525 TV Red Lamp LED
340v should be on power pwb plug PL on the 1 and
5 (GND) pins for the ballast. and the ballast plug CN should also have the 340V with pin 1 of that plug being GND nd pin 3 should have the 340V If the PL plug on the power board is low the power pwb has a problem most likely the doubler circuit. If CN plug voltage is high say 360V the ballast is suspect.
Jan 10, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubushi tv model # 52327 ballast replacement
The ballast for the lamp too should be replaced along with the lamp. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Mar 13, 2017 | Mitsubishi WD-62525 62" Rear Projection...
Two different size ultraviolet ballast. The .71AMP ballast feeds two 40W ultraviolet ''UV'' bulbs. The .37AMP ballast feeds one 40W ultraviloet bulb. The two light to larger bal;last want come on. The...
I usually test the ballast simply by excluding everything else.
1) Put in bulb that you know works
2) Replace starter (if you have one)
3) check that wiring is intact (sounds like it is for you but I had one light that the wiring barely made contact so sometimes it came on and sometimes it blinked)
4) If all that is good, then it's probably the ballast.
Sep 29, 2009 | Garden
X2 board
ebay has several that need bulbs... just a thought here is one of the item numbers Item number: 270207032811
Jan 23, 2008 | InFocus ScreenPlay 4805 Multimedia...
LG RU-60SZ30 60" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Computer Repairing
Computer Repairing
