Question about Sony KP-61HS10 61" Rear Projection Television
How do I remove the HV lines on the D board?
I'm trying to remove my D board, so I can replace the 2 stk's, and check out the pico fuses. I cant seem to figure out how to get the 2 hv lines off the board. Should I just cut them, and splice 'em back together later? I've heard you can push and twist them, though this doesn't seem to work...
  • 4 more comments
  • mrwiggles Feb 25, 2009
    How much should I be twisting? There isn't that much slack. And, how in the world do I get it back in?
    Thank you for your help! Here are some images of the HV block, and where the wires connect on the D board.
    Yay! I finally got the thick one off... I wasn't pushing in far enough. It now makes much more sense!
    Though, I'm still having trouble getting the thin one off...
    Here's a picture of what the connector looks like:
  • mrwiggles Feb 26, 2009
    Well... I got the thin one out, but it looks like a broke off the end.
    I guess I wasn't supposed to remove the thinner one from where it connects on the D board... DOH!
    Do I now have to replace that whole thing, where the two HV lines connect, on the D board?
    So, are you saying it's ok, that I ripped the focus wire out of the flyback, on the D board? I do not have to replace it?
  • 10,594 Answers
Do not cut them.
Push and twist thicker wire in HV block and pull out. HV block has 3 more wires going to 3 guns in TV.
Never cut this wire.
Posted on Feb 25, 2009
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Feb 25, 2009
    Thick wire has clip at end that locks in HV block. Simply insert wire in HV block and it will get locked.
    To release lock needs push, twist and pull.
    Can you post here an image of wire and its end to help you more?
    Shahid Electronics Feb 26, 2009
    Thick wire is not broke off and seems OK, Congratulates.
    Other red wire is focus wire and goes to focus block that would be mounted at right corner of TV and you need to take off lower front of TV to see focus block having 6 control knobs.
    Focus wire should be disconnected from focus block. If you pulled it out from fly back transformer, its bad and need new fly back transformer.
    What I see in image that you posted is thick HV wire and its end seems OK.
Kd-46wt500 sony big screen colors dont line up is projectors goin out picture on tv is blurry pic looks stretched out as well
Can you verify the model number and see if its A KP46WT500 model? If so chances are just the convergence Ics ( stk 392-560 ) and pico fuses are the problem. There are 6 3.5 amp pico fuses directly beneath the heat sink fins on the D board ( where the Convergence ICs are located) Check those six pico fuses and also two 5 amp picos on the G board ( where power cord plugs in) if any of the picos on either board are open then the Convergence ICs will require replacement.
Sep 26, 2011 | Sony KP-46WT500 46" Rear Projection...
I Change the two stk for the convergence but steel have troubles
most sony models require the 6 pico fuses on the D board and the 2 Picos on the G board will require replacement along with the two ICs. Did you check the pico fuses?
May 28, 2011 | Sony Televison & Video
My TV is showing convergence symptoms: the screen looks like 3D effects and as if someone is pusing in the middle of the screen. I've replaced my STK's, 2 pico fuses on the G board, and tested each...
One of two things:
Either:
a) The STK chips you put in are no good (not uncommon)
or
If you weren't careful you may have removed a surface mount resistor accidently while desoldering the orignal STKs. I had a customer do that to me once and figured it out by comparing the board to the schematic for that board location.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
I've replaced my STK's, 2 pico fuses on the G boards, and tested each convergence resistor along with the pico fuses on the D board--albeit they were still soldered in place. I desoldered two pico fuses...
I believe there is a power board on the left side when looking from the back. It will be vertical, right next to the board you worked on. Take that board out. I believe there are about four pico fuses on that board. One or two of them will be open. Replace the fuses and you should be good to go.
I,have projection sony tv 43ً ً i hv problem
Thats a Convergence problem STK ICs STK392-110
and you need to check the pico fuses the look like resistors but will be Green or Yellow 5amp.6amp.
Mats Electronics has them 1-800-628-1118
Jun 02, 2010 | Televison & Video
Convergence issue with kp-57ws500
You have to remove one leg of each pico fuse to test them properly. Same goes for the resistors. Other options is you have a bad soldering joint or a faulty STK chip still.
Jan 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Samsung pcl5414r power resistors and pico fuses??
Hi again and welcome back to FixYa,
Appreciate the direct "Ask Me'.
Based on your original post, only the STK ICs were replaced. Presumably 392-040, the surrounding resistors and pico fuses could very well have been affected as well. Depending on the board revision (pls confirm location numbering on the actual board), the resistors could be:
RZ104 -RZ106 - 270 Ohm 1/2watt
RZ133-RZ135 - 27K Ohm 1/16 watt
RZ136 & RZ138 - 3.3K Ohm 1/8 watt
RZ146 and RZ147 - 3.9 Ohm 2 watt
RZ148 and RZ149 - 150 Ohm 2 watt
while the pico fuses would look like the image below.
Good luck and Thank you for using FixYa.
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Sony kp-57ws510 convergenece prblem
You didnt replace the STK's? You must replace the convergance IC's or you will continue to have this problem.
Sep 18, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Rear projection convergence out. replaced boards, blowing fuses
99% of these problems are due to either shorted pins or a missed pico fuse. The stk ic's are on the "D" board, attached to large heat sinks, When looking from the back you can see the heat sinks but the part's themselves will be pointing away from you and hard to see without removing the board, or using a mirror to look at the part numbers. The fuses are generally located under the fins of the heat sinks. There are several of them and vary by model. On the "G" board there will be two yellow pico fuses near the connector going to "D" board. These fuses provide power to the stk ic's you must check these as well.
Dec 16, 2007 | Sony KP-51WS500 51" Rear Projection...
Sony KP-61HS10 61" Rear Projection Television Logo
514 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
