Question about E-Machines EMA IMPERIAL GV (845GV) TG3 eMachines (145119) Motherboard
Wont load up
I just bought a new power supply and everything comes on now but is there suppose to be one green light on and one red light on on the mother board?
    President:
  • 2,992 Answers
If everything is working properly, then yes, those lights are normal. Many motherboards have LEDs on them to show standby power. You probably didn't notice them until you worked on the thing.
Posted on Feb 25, 2009
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
Power will not come on. I bought a new power cord
The power supply may be at fault. You can try testing the supply with a volt meter. However, this may be inaccurate because there is no load on the power supply.
You can try a friend's power supply or buy a universal power supply (usually cheaper than an OEM one).
You may also have a problem with the DC Jack. This is a common problem too. Try moving the tip of the power cord in the computer. Does it feel firm. Do the power lights come on and off. Unfortunately, DC Jack problem will require a professional.
May 20, 2010 | Gateway MT6705 Notebook
Green lights...no power. HELP!
This could be a problem with your power supply. If the motherboard sees that the voltages from your power supply are low, it will turn itself back off.
You can test your power supply by unplugging all of your internal power cables, ground out the green wire on the 20-pin/24-pin ATX connector and check your yellow (12v), red (5v) and orange (3.3v) wires. If the voltages come back more than 10-15% off, you will most likely need a new power supply.
Even if you have good voltages using the test method above, it is only an indication that your voltages are good at zero load. Your power supply may still fail under normal load. If you have recently added any hardware to your computer, remove it and try again. If this still doesn't work or you haven't added any hardware recently, replace your power supply.
May 13, 2010 | Computers & Internet
Picture wont come on screen
this problem is in the power supply.the red lights indicate as the standby mode.
Jan 23, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Monitor not turn on when hooked up to power supply only
Hi...there,
The AC Adapter supposed to lite GREEN not red... Try a different AC Adapter if you got one..
If it still the same problem after changed another AC Adapter... Then it's your backlight inverter are busted. Need to replaced a new one or returned...
Oct 24, 2008 | Computers & Internet
The wii wont turn off and the light stays green
Hold the power button on the console for 4 seconds, it should override everything keeping it on and the light will turn red. If this doesn't work sorry, thats all I know.
Apr 08, 2008 | Nintendo Wii Console
Emachines t3882 wont power on
The yellow wire carry 12 volt while the red one is 5 volt. But to check the voltage you have to unplugged all the four wires connectors (yelow, black, black red) and measure them one by one. If you say that they don't have any voltage on them then you have a faulty power supply. Replace it to solve the problem.
But if during unplugged your have the correct voltage read then it could be one of your device faulty. Normally your CD-ROM drive or floppy drive or HDD.
Mar 25, 2008 | Intel D865GVHZ Motherboard
Power light blinks red - tv will not come on
to let you all know that Im having the same problem with my tv.. amber then red red red red... and popping sounds from speakers... Its because they use cheap parts there are 19 capacitors in the power supply (DONT RECOMMEND FOR NON EXPERIENCED PEOPLE) the 2 main filter capacitors are 100uf450v the ones in mine are just fine then there are 3x 1000uf16v, 2x 470uf16v, 3x 470uf25v, 2x 1000uf25v, 6x 1000uf35v, and 1x 470uf35v... Im in the process of replacing those capacitors. about half of them are leaking and 1 is blown... very dangerous for anyone messing around back there.. just thought i would let everyone know that its a 20 dollar repair if you know what you are doing i got my caps at marvac.com
any other questions email pfctmitsubishi@yahoo.com
Dec 04, 2007 | Akai LCT2715 27 in. LCD Television
Relays click. That's about it
try unhooking the wires coming off the power board you should be able to unhook every thing except the switch wire and se plug if the green lights stay on and the red don't come on then you have something loading down your power supply if it still shuts down you need a new power supply
Nov 20, 2007 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
Computers & Internet Logo
78 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
