Question about Kenmore 51562 / 51564 / 51569
Kenmore Refrig 51562 Side By Side; Icemaker leaks water underneat
The Icemaker receives water at full flow...no obstructions. The Icemaker also makes cubes and dispenses them to the bucket fine. The problem is that during the freeze cycle, water drips from underneath the tray and makes 'stalagtites/mites' in the freezer. The entire refrigerator is level front to rear and side to side.
Any thoughts? I am guessing maybe a leaky gasket or maybe a small crack I cannot see...
  • melbaandcurt Feb 25, 2009
    Isn't the solenoid valve outside the freezer compartment? The leak that is occurring is only after the tray is full of water. The water then begins to drip from underneath the tray itself.
  • 700 Answers
You are going to have to replacwe the solinoid valve for the icemaker mbecause its leaking by
Posted on Feb 25, 2009
  • Todd Born
    Todd Born Feb 26, 2009
    yes it is but the water needs to be stopped completely outside the unit that way the water stops before it overflows.
  • Todd Born
    Todd Born Apr 04, 2009
    I realize that whats happening is that the valve is still putting in water into the ice maker after it is suppose to stop.
The water dispenser quit working,i can hear motor/unit turning,would a plugged refrig filter be part of problem?
Yes a clogged filter could indeed make the water dispenser not work...it too would affect the icemaker as well, is ice being made?? if yes icemaker is working yet no water being dispensed what ya need to check for is a cracked or broken line and instead of water is leaking out of it somewhere.
GENE
Sep 23, 2011 | Kenmore Side by Side Refrigerator
MAYTAG DOUBLE DOOR REFRIG
THE PROBLEM IS WITH THE AUTO DEFROST (IF THE FEATURE IS AVAILABLE) OR ELSE YOU HAVE TO MANUALLY DEFROST IT REGULARLY
Sep 15, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Ice maker not producing ice,already check the basic problems,
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 05, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Kenmore icemaker
It sounds like the icemaker is making hollow cubes , and the unfrozen water in the cubes , after dumping , freezes and causes the ice shells to stick togather . This is a sign of " not enough water going into the icemaker " . Replace the water inlet valve , behind the refrig , the piece the wall water line connects to , on the refrig .
Oct 06, 2009 | Kenmore 57029 Side by Side Refrigerator
Jenn Air side-by-side refrig-freezer. When the water is hooked up it leaks substantially from the Ice Maker. I'm attempting to remove the module (from which the water flows) and it's unclear just how to...
Make sure the fill cup does not have any ice in it. The little cup that the tube fills when it calls for water. Besides that I would recommend changing the icemaker module on the front of the icemaker. It is held on with 3 screws.
Sep 07, 2009 | Refrigerators
I have a kenmore elite fridg that is not making ice,but i have water at the door. modle # 50509990. THANKS.
Pour about 2/3 cup of water into icemaker ( if there is no cubes in there now ) . If the icemaker dumps the cubes when frozen , replace the water valve . If it doesn't dump , replace the icemaker . Also make sure the coils at the bottom of refrig in front , are clean of dust , lint , pet hair , etc . Also check the plastic hose inside the freezer , to the icemaker , to make sure it is not frozen . If it is , replace the water valve , due to slow drip leak .
Sep 05, 2009 | Kenmore Refrigerators
I have a Kenmore refrig./ model# 363.9741714
The problem is actually not the ice maker itself. The problem is the electric solenoid valve in the rear bottom of refrigerator. If you follow the water line on the back of the unit down to the bottom and replace the valve that it is connected to then your problem will be solved. Hope this helps. Good luck cj2176.
Jul 25, 2009 | Kenmore Refrigerators
Too much wate flow into icemaker
it over filling or it leaking from the mold i never seen thi model over filled mold when i see wtr in bin is usually the mold that is leaking you can check with a mirror or remove to inspect is texture is peeling off repl entire ice maker if is ok then repl wtr valve is not closing when it has filled the mold you only need 4oz of wtr
Nov 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Water leaking
I guess it was water from drain lines, or leak from water lines.
Aug 01, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 51562 / 51564 / 51569 Logo
181 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
