Question about Dishwashers
The pump is working and drains the DW if you pour water into the drain. The problem is that this thing appears to be stuck in "drain" mode always pumping out not advancing through the cycle no matter where you turn the control knob to.
  • ivonya Mar 09, 2009
    I have the exact same problem, sounds like it anyway. Seems like the timer motor is no longer working. When I slowly turn the control knob most of the functions will activate in sequence(such as inlet valve, main circulating pump, drain pump etc.) just won't advance thru on it's own. It will sit at what ever position I leave the knob at (ie: continues to drain, or let in water , or circulate water without stopping unless I open door, or rotate knob.) Can the timer motor itself be tested and if it is faulty, can it be replaced?
  • albert getty
    albert getty May 11, 2010
    change controls?
  • 833 Answers
You probably have a stuck solenoid which routes the water either to the arms or out of the machine. It is located near the motor and routes to the drain line. Most are removable and may be disassembled for cleaning. If the control knob does not advance, the issue is different.
Posted on Feb 25, 2009
Drain problem
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Is this a standard installation?
Dec 03, 2013 | Electrolux 24 in. EDW5505EPS Stainless...
Water will not drain
Good luck. Many times these simple steps will work for you.
Nov 29, 2013 | Bosch SHX68E15UC Dishwasher
Did not fully drain and will not turn back on
Might have blown fuse.
Check for obstructions in drain line -- the pumped line from pump under DW to drain. Is their debris in air gap or in the bottom of the DW, where the drain is screened?
Good luck.
Nov 27, 2013 | KitchenAid Dishwashers
GE model GSD3200GOOWW Serial # MD71074513
Good luck. Some times these simple steps will work.
Nov 18, 2013 | Dishwashers
Hi I have had this intake/drain light come on in my Miele G851 SC dishwasher. I followed the recommended instructions in the manual: - clean triple filter, drain pump, and non return valve - check...
Is their debris in air gap or in the bottom of the DW, where the drain is screened? Look for obstructions.
Good luck.
Oct 25, 2013 | Miele Dishwashers
I need to unblock a drain pipe from a whirlpool integrated dishwasher
Where is the problem. Is it the DW or the house drain? If it is the DW, here are some steps to follow. Use your brain thinking thing to help you too.
Good luck.
Oct 22, 2013 | Dishwashers
Dishwasher won't drain, the pump seems to be working but it's like it's clogged or something, any ideas?
OK, first using a sponge and bucket, drain out all the water of the dishwasher (DW) as you can. You can also use a towel too.
Check the discharge/drain cover at the bottom of the DW for any obstructions. Sometimes small pieces of all sorts of things get sucked into the drain port.
There should be a protective shroud/cover over the drain and you might have to remove a small hex head screw to get into the drain sump inlet. Some can be popped off without any tools.
Once you have the cover off, be VERY careful in probing the drain area trying to see if there are any small broken pieces of dishes or glasses that may have gotten into the sump area. You'll want to use a towel or sponge to get the water out of the sump area.
If you don't get anything out of the sump drain, it could be that the obstruction has worked its' way into the motor disposal impeller and you'll have to remove the DW from under the counter in order to get at the motor and pump assembly. This will require possible disconnection of the water supply line, AC power line or plug, and the drain line going to the sink or disposal.
Before getting into removing the DW, you can also check the drain line for blockage by disconnecting it from either the sink drain connection or disposal and blow into the line. If it's not clogged, you'll get air coming into the DW. If not, then the drain line is clogged. Also check the Air break connection, mounted on the sink, (if so equipped) and clean it out. You can also pour warm water down the Air break to verify that the line is clear.
If this doesn't work, please check my other solutions under dishwashers for a complete step-by-step for getting to the discharge pump section.
I've seen blockages occur fairly often on these models and it's usually caused by broken bits getting into the discharge pump and jamming the impeller. Once removed, normally the DW will work fine, unless the impeller has been totaly chewed up by the blockage, then you may have to replace the discharge impeller to get it able to pump out properly.
Hope you found this very helpful and best regards!
Aug 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Bosch SHX46A (6 years old) Selected regular cycle, pressed On and closed door. Cycle did not start normally. Pump runs, but no water is coming into the DW. I confirmed the water supply line is turned on....
From your description, I doubt that the problem is door latch is the cause.
The first thing that a modern dishwasher does before it begins to fill with water is run the drain pump.  It appears that this DW is not progressing to the next cycle (inlet water) and because the pump runs even when the door is open, I agree that the controller card may have failed.
If possible, inspect all the wire connections (remove main power before you do this) ... if there is a loose connection, the controller could do odd things.
Good Luck!  Please report back what you find, OK?
Apr 14, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Bosch Dishwaher shy56a
Bosch dishwashers have a seperate pump for washing and another for draining. Try making it fill more than once. There is usually a timed fill and the float stops it before it overfills It also might prevent it from washing without enouth water Try defeating the door switch and play with the float during fill. There may be a sensor that won't let it go into wash. Be prepared to get a little wet if it should start up suddenly. A slightly safer way is to fill it with the sprayer from the sink. and see if it will go into wash.
May 08, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Certainly sounds like the float is stuck in the over filled position or possible a bad float switch. Could also be a bad water fill valve - if you can blow air through it when removed then you need to replace it. You can follow this link to troubleshoot your washer, but note that its not exactly for your model - http://www.thermador.com/replacementparts/main/pdfs/SHU-complete-troubleshooting-guide.pdf Good luck!
Mar 25, 2006 | Bosch SHY56A02 / SHY56A06 Built-in...
Dishwashers Logo
146 people viewed this question
Top Dishwashers Experts
