Question about Philips GOGEAR SA6045 MP3 Player
Phillips SA 3285 Not Loading Firmware
I cannot get any power to my player. When I run the Phillips device manager it tells me there is a problem and would I like to fix. Each time the firmware will not install and it is still dead. Anybody have any ideas on how to fix this?
  • 8,596 Answers
Download the updated version of the Philips Device Manager from Philips website first. Then:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Posted on Feb 27, 2009
I have a problem with it want come on\
Hi h rosson9821,
Depending on your specific model (typically Philips GoGear products begin with "SA"), you can perform a Repair/Recovery which will restore your product to factory settings as well as update the firmware (and improve performance).
After performing a Repair, be sure to leave your player charging for at least 2 hours and practice a regular charging routine.
For FAQ's, manuals, software, chat, and more, you can visit the Philips Support site at www.philips.com/support (enter your model number to find product specific information).
If you have additional questions, you can reach Consumer Care at 1-888-744-5477.
Hope this helps! If so, let me know by rating this solution!
REPAIR INSTRUCTIONS:
To reset the player, please use a hard sharp object such as the tip of a ball-pen to insert the RESET hole GENTLY and then press and hold the power slider to switch on the player.
If the reset method does not help, please try Device Manager:
1. Install the Philips Device Manager and run it with your player connected to PC.
(You can download it under Software & drivers section in the product web page.)
2. Run the Device manager Software on your PC.
3. Click the Repair tab in the Device Manager, press and hold the VOL+ button on your player to perform the repair function.
4. Safely disconnect the player from your PC when the repair is completed.
5. Turn on your player.
6. Go to Settings --> Information to check the current firmware version. If the firmware is 6.28 or higher, the problem should be solved.
Aug 08, 2011 | Philips GoGear ViBE Digital Media Player
Firmware won't update; Player won't turn on or show up on PC
if you use vista, try with xp... another post about and it worked for me.
May 16, 2009 | Philips GoGear HDD1830 MP3 Player
Firmware
The firmware has corrupted.
Run the Philips Device Manager, installed from the driver CD.
Connect the PSS110 to the mains and PC, when the Philips Device Manager registers that the device is connected click on the Restore option, and follow the on-screen prompts.
This will format the device and replace the corrupted firmware.
NOTE: ANY TRACKS WILL BE DELETED
Apr 25, 2009 | Philips PSS110/17 MP3 Player
Phillips go gear 4g file system fail
There are only a few things you can try:
1) Reset the player (won't resolve)
2) Run a Repair in the Philips Device Manager
3) Run an Update in the Philips Device Manager
Download the newst version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If these methods fail to resolve the problem, call Philips and see if you are eligible for an in-warranty replacement.
-Tha Mp3 Doctor
Mar 25, 2009 | Philips GOGEAR SA6045 MP3 Player
Phillips mp3 player
Download the updated version of the Philips Device Manager from Philips website - only the updated version will enable you to get the correct firmware upgrade that will resolve your issue. Once you have downloaded the new Philips Device Manager, open it with your mp3 player connected to the computer, and click the Update tab - it will update the firmware on the player, resolving your issue.
-Tha Mp3 Doctor
Feb 11, 2009 | Philips GOGEAR SA6045 MP3 Player
Lost memory on my philips gogear 2gb
3 different problems:
ashton -
If your GoGear is an HDD model, then it is incompatible with both Vista and Windows Media Player 11. If you have Vista, forget about this player. If you have XP, roll back your Windows Media Player to version 10 and try running a Repair in Philips Device Manager - the damage might already be done, but it is worth a shot.
If you have an SA model GoGear, get the latest Philips Device Manager from www.usasupport.philips.com. Make sure you enter your correct model # in the website, or you will damage your player. Run an Update in the updated Philips Device Manager to upgrade the firmware to fix the freezing issue. Philips has a weird quirk that if you want to really upgrade the firmware, you have to also update the Philips Device Manager first or the Device Manager from the CD will give you a false positive: "Your device is already up to date."
mwungura - You problem may be hardware related, which will require a replacement, but here's how we'll find out: First, make sure the hold/lock switch is not engaged. Try turning your player on again. Consult your manuals for details on what I have just said. Second, try resetting the player - the Philips website/user manual will tell you how to reset your particular GoGear. Third, download the latest version of your Philips Device Manager by going to Philips website. Once you have done that, first run the Update function to upgrade the firmware. Finally, run the Repair function in the updated Philips Device Manager. If all of the above methods fail, call Philips and find out how to get an in-warranty replacement (or take it back to the store).
Guest - your player is screwed - there is no software available for fixing that problem. Call Philips and find out how to get an in-warranty replacement (or take it back to the store). The problem was caused because you deleted a key system file when you were trying to delete music - next time, be very, very careful.
-Tha Mp3 Doctor
Dec 14, 2008 | Philips GoGear SA178 MP3 Player
How do i fix my go gear phillips mp3 player..it froze
Steps to Repair:
  1. Open the Phillips SA-31xx device manager.
  2. Connect the player to the computer while pressing and holding the on/off button of the device (the inner round button.image_thumb%5b1%5d.png). Windows will tell you that a USB device is connected in the repair mode.
  3. The device's screen will look like:
  1. On the device manager, click on the Repair tab.
  2. On Repair tab, click the Repair button. It will show the message that the device is repaired. The device will also show that it's being repaired.
3. After the device has been repaired, below message will be shown.
4. BEWARE ALL DATA WILL BE LOST from the Phillips Go Gear SA-31xx Media Player without any warning.
Aug 19, 2008 | Audio Players & Recorders
Mp3
-Tha Mp3 Doctor
Jul 17, 2008 | Philips GoGear SA178 MP3 Player
Phillips mp3 player frozen
Sounds like a firmware problem.
Run the Philips Device Manager to repair the device. This will format the player and re-load the corrupt firmware.
Jun 20, 2008 | Philips SA4010 MP3 Player
I have a new sa4315/97 which was set up last night, transferred files ok and worked well. Plugged it into the computer this morning and the device manager couldn't find it and to run the repair option. ...
Sounds like corrupt firmware.
Run Philips Device Manager, and select the repair option.
Press and hold [PLAY / PAUSE] on the player whilst connecting to the PC.
Continue to hold until Device Manager tells you otherwise.
Follow the on-screen prompts.
This puts the player into recovery mode. If Windows shows a Found new hardware window, select automatic installation, because the recovery driver is installed with Device Manager.
This will format the player and re-load the firmware.
NOTE: ALL TRACKS ON THE PLAYER WILL BE DELETED.
May 04, 2008 | Audio Players & Recorders
Philips GOGEAR SA6045 MP3 Player Logo
258 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
