Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Need info whats the color of a 2.2 ohm 2w resistor red red ??? thanks
    President:
  • 2,992 Answers
A 2.2 ohm resistor would be coded red-red-gold-gold.
Posted on Feb 25, 2009
Thanks for the info about the STK392-110 IC's. I
There are some low-value (1-2 ohm) 1-watt resistors in each convergence yoke circuit. Most often one will get toasted when one chip fails. Problem should be visible to inspection.
Jan 01, 2010 | Televison & Video
Need help
I believe red, red, gold.
Feb 25, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Sony 57ws500
Ok, here are details of all resistors ...
R7324= 1k 1/2w
R7326= 220 ohms 1/2w
R7301= 10 ohms 1/4w
Need further help, let me know please.
Nov 06, 2008 | Sony KP-57WS500 57" Rear Projection...
Red Wavy lines running across the screen...
Yes - - that indicates one of your convergence amps have failed. That unit takes two STK392-110 Sanyo amps which I personally would replace with STK392-150's for greater reliability. Also check all of the return resistors in that circuit 1.5 ohm 2w and feed resistors 3.3 ohm 1w all are flameproof. You'll likely find that one or more of the return resistors are bad, with suspecting the red is the failed amp check in particular R846 for change in value or open.
Bill
Mar 24, 2008 | JVC AV-56WP74 56" Rear Projection...
53FDX20B
I would start 1st by checking all resistors ie.
RK43 2.2 ohm - 2W
RK47 1.5 ohm - 2W
RK51 2.2 ohm - 2W
RK55 1.5 ohm - 2W
RK59 2.2 ohm - 2W
RK63 1.5 ohm - 2W
If I were you I would also replace the convergence chips. From the above thread it's clear that they are of different quality so they may last different lengths of time (B&D is a good place to buy good quality ones).
I found a free pdf service manual for 53FDX20B on a Polish web site: http://instrukcje.elektroda.net/main1750.html
other models try here: http://www.webtronix.ca/hitachi/index.htm
http://www.asm-service-manual.com/List/Hitachi%20List%20ASM.htm
Download pictures from my repair (Password: delirious).
http://www.uploading.com/files/HGGLJLXC/Delirious.zip.html
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 06, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Blurred picture
Hitachi > 53FDX20B blurry picture
RK43 2.2 ohm - 2W
RK47 1.5 ohm - 2W
RK51 2.2 ohm - 2W
RK55 1.5 ohm - 2W
RK59 2.2 ohm - 2W
RK63 1.5 ohm - 2W
Jan 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Sony 7 blinks
6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
also found this
CHASSIS: AX1/AX1X/RA6/RA6A
MODEL: KDP51WS550, KDP57WS550, KDP65WS550, KP46WT500, KP46WT510, KP46WT520, KP51WS500, KP51WS510, KP57WS500, KP57WS510, KP57WS520, KP65WS500, KP65WS510
SUBJECT: Picture gets bright then shuts down. After repairs tech noticed a mark was created on all 3 CRT's.
CAUSE: Found Video Output was defective causing the failure of the 200v line. 200 volt line has two fuse resistors R7301 (10 ohm 1/4w) on the CB Board. R8225 (1 ohm 1/2w) on the D board. R8208 (0.47 ohm 1/2w) also on the D Board. All three resistors are in series. One or all 3 could be open. After replacing 2 resistors and Video Output IC set returned to normal operation. CRTs will need to be changed due to phosphor damage. On Models KDP-51WS550, KDP-57WS550, KDP-65WS550 CB Board resistor is R9335 10 ohm 1/4w. D Board resistor is R6509. NOTE: This resistor may be a jump wire according to the schematic. Models: KP-51WS520, KP-57WS520 These models have a fuse resistor on all 3 CRT Boards. CB R9335 10 ohm 1/4w CR R9110 10 ohm 1/4w CG R9211 10 ohm 1/4w On the D Board R6509 is a jumper wire according to the schematic.
Dec 11, 2007 | Sony KP-65WS500 65" Rear Projection...
Panasonic PT-47wx49 color distortion
you have convergence trouble and possible require ic's to repair the problem.
Aug 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
48 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
