Question about Garland H283 Gas Kitchen Range
Need part # for oven thermocouple on garland h283
Will a universal thermocouple (like for water heater or furnace) work?
this is a dual oven unit and the part i need is located under the cover at the bottom of the oven.
  • 3 Answers
Yes, I just grabbed a standard 18" thermocouple at ACE ($8.50) and installed it. Works just fine.
Posted on Nov 13, 2009
    Novelist:
  • 125 Answers
Hello. To answer, yes a universal will work, however, it may not last as long as the OEM part, as the original may be constructed slightly different to hold up against the heat better, and other environmental factors not encountered by a water heater, furnace, standard home range. So as a servicer, I would suggest the original part first, then a universal, to get you by.
Posted on Feb 28, 2009
  • 70 Answers
Here is what I think you are looking for:
18 inch thermocoupler: G1019418
here is a good website
http://www.whaleyfoodservice.com/garland-parts.asp
Good Luck!
Posted on Feb 26, 2009
I just installed a new thermocouple from garland in my range but the oven still shuts off. I don't know why.
I have a Garland range 4-burner and it is 24 inches wide.I don't have the model number;and I want to buy a thermocouple. I need a part number it.
Nov 25, 2010 | Garland H283 Gas Kitchen Range
Change thermocouple Garland range
I know the question is a little older, but maybe it helps someone else... I just did the job and it turned out to be much easier than I thought it would be. The whole burner assembly slides out, so you don't have to work in that small space!
Simply turn off the gas, disconnect the two pipes that go from the oven to the valve (gas and thermostat), disconnect the two door springs from the burner unit, remove the screw that holds the valve, remove the two screws that hold the burner in place and simply slide the thing out. You may have to loosen the right half of the heat protector plate to get it out. That's it.
Jan 31, 2009 | Garland H283 Gas Kitchen Range
What do I clean my 60" garland double oven with?
Use warm, soapy water for everyday cleaning, and dry with a soft cloth. Use a mixture of 25 percent white vinegar in water to remove mineral deposits left by hard water. Step3Remove burned-on food, wash with warm soapy water and a scrub brush made of nylon. 4Remove rust with an oxalic acid cleaner such as Bar Keepers Friend 5 Use glass cleaner and a soft cloth to remove fingerprints. Polish stainless steel with a paste made of water and baking soda. Rinse and dry thoroughly. Please rate this fixya
Jan 28, 2009 | Garland H283 Gas Kitchen Range
Pilot light to oven went out
It could be that the safety ($150 to $250) is getting old, or grease filled. It could also mean the thermocouple ($7 to $12) is going bad, or has a bad connection. If the copper jacket of the thermocouple is blackened near the pilot, broken or cracked in anyway, it may not be working properly, as it generates a small voltage when heated, less than100th of an AAA battery, to keep your pilot lit. If the pilot orfice is clogged with dust it produces a smaller, less hot flame, which also lowers the output of the thermocouple. If I was performing the service, you would automatically get a pilot cleaning, and a thermocouple, the safety could still be bad, and confirming this is a 50/50 chance to begin with, but it is a cheaper start. Good luck, ask more if you need too, thank you, an Happy New Year.
Dec 27, 2008 | Garland H283 Gas Kitchen Range
Garland stove oven pilot light does not stay lit
If there is any adjustment, it would be a small screw on the oven control accessible with the oven control knob removed. This adjustment affects the size of the top burner pilots, but I'm not sure about the oven. The oven pilot orifice may have an obstruction, or if the flame is actually normal size where it covers the thermocouple when it burns, you may have a thermocouple problem.
Dec 22, 2008 | Garland H283 Gas Kitchen Range
Black Garland H283 convert to Electric ignition?
Is there a kit to convert an older Garland 6 burner, double oven, griddle and salamander to electronic gas ignition?
Sep 25, 2008 | Garland H283 Gas Kitchen Range
Burn marks on pot and pans
Just got a Garland 6 burner stove w/single oven. It was Natural gas need to convert to propane. Need supplier for conversion kit
Sep 05, 2008 | Garland H283 Gas Kitchen Range
Garland range
The unit does not have it's own shut-off. You'll need to shut it off at the building's supply. The plumber surely installed a valve right behind the unit.
Make sure a technician inspects the gas supply tubing for the OVEN pilots. They run from the front manifold, to the back of the oven, down the back, and under a shield. They tend to go bad.
May 30, 2008 | Garland H283 Gas Kitchen Range
Oven pilot shuts off while cooking model H286RC-24
You may have an adjustment problem. The pilot flame needs to under the thermocoupler back from the tip just a touch. But ultimately, if the flame is good, the thermocoupler is good, you have a bad valve.
Also make sure that there is no overall gas pressure problems with the unit. A bad regulator can starve a unit for gas one minute, and work the next.
May 28, 2008 | Garland H283 Gas Kitchen Range
Commericial stove oven problems
the end of the thermo coupling needs to be in the flame of the pilot light
Apr 22, 2008 | Garland H283 Gas Kitchen Range
Garland H283 Gas Kitchen Range Logo
526 people viewed this question
Top Garland Kitchen Ranges Experts
John Tripp
John Tripp
Dennis Boxerman
Are you a Garland Kitchen Range Expert? Answer questions, earn points and help others
