Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Need in Panasonic PT-53WX53as soon as the convers chips are replaced should it line up the blue still dose not want too work
  • 4,234 Answers
You need to check the area for pico fuses or low valued reistors. When the ICs go bad, they often will smoke the resistors or fuses that feed them.
Posted on Feb 25, 2009
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Problem with Panasonic PT-53WX54J 53 in. Rear Projection HDTV Television - Green Screen
You may have a component failing in the red drive stage possibly the blue as well or even the quadrature stage. A can of cold shot should help narrow the search considerably. It is also possible the red and blue projection tubes are nearing the end of their service life as well. If you have the means to test the tubes themselves, check the red and blue tubes for gas.
Dec 19, 2011 | Panasonic Televison & Video
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine.You can find it here: Have a blessed one!
Mar 22, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Blue line Ghost Image on Panasonic Projection TV
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} This set uses two Stk-392-110 convergence IC chips; both need to be replaced along with any of the 2.2. ohm light blue resistors around them; a bad resistor will be white in the middle; You can buy both for less than 13 dollars plus shipping on Ebay.
The chips are located on metal heat sinks with fins and are side by side. They are black(about 2 inches wide by 1 1/2 tall) and should have the STK-392-110 number printed on them in white.
Depending on your level of skill at this kind of work you may be able to do it yourself---if you need step by step instructions contact me---I have them in Microsoft word---start to finish repair including what you will need to do it.
If you are not able to do the repair yourself now is the slow time of year for TV repair shops----It should be fixable right in your home and the repair takes about an hour--I have done hundreds of these sets--some shops charge 300-400 but I do lots of them for 200-250 total cost. Make sure whoever you get changes BOTH of the chips!
Shop around and if they say "needs to go to shop" keep looking; any good tech can do this right in your home.
I do this here for free so if this helps you give me a vote here. If you need direct help contact me.
Aug 27, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic 53" tv
Blue background lines with colors otherwise OK may be a loose or dirty blur drive potentiometer on small circuit board behind front grille and beneath front imerboard cover. These are hot-glued in place from factory but may be the cause f the problem. They're VERY sensitive.
If you have bowed blue lines instead of properly aligned colors, you probably have a blown convergence amplifier IC. These boards are no longer available so yours will have to be repaired. Some shops repair them but many send them out for 6-10 weeks. Fairly expensive too considering the amplifier chips are about $35 each (x2).
Jun 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic hd projection with conver. problems
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from that includes replacement coolant, photos. instructions, etc.
Mar 24, 2009 | Panasonic PT-56HX41 56" Rear Projection...
Red ,Blue and Yellow lines off,curving inword from top and bottom
Its failure of 2 convergence out ICs and requires replacement.
You can replace these ICs if you have basic electronics knowledge and good soldering experience. let me know to provide you more info about parts.
Feb 20, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Grennish/yellow spots pt-50lc14
I received a new blue polarizer unit from Panasonic. I installed it and it fixed my problem!!!
Apr 09, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
