Question about Intel D945GCZ Motherboard
Intel motherboard hello i need to upgrade memory for a friend. technically if amotherboard has another place for the stick is it right to say that itwill fit another chip which already has in it. like 256 or 512. or howdoes it work? how can i tell when i open it up how much more it fits in or can i find this out without first opening it up pls... thx guys and gals.. :)
  • dragoness1
    dragoness1 Feb 25, 2009
    i'm not sure either if this is the number for the motherboard. where can i find that
  • 447 Answers
First, here is a link which lists exactly what memory modules you can use in the motherboard you've specified (if that is the motherboard in question)..
Second, you should be able to determine how many banks are still empty with the case open. You'll probably want to check the existing ram mod(s) for a part/reference number, take that number and punch it into Google to find out the exact specs and MHz so that when you purchase the upgrade memory you won't be cross populating it with a different ram speed (I don't like to cross populate).
If you have more questions don't hesitate to ask...
Note: I am not affiliated with the vendor link I provided, it's for illustrative purposes only.
Posted on Feb 25, 2009
  • John Elliott
    John Elliott Feb 25, 2009
    Many times if you pause (Pause or Break button) during the boot sequence you will see a string of numbers across the very bottom of the screen that can be used to identify *********** board.
I `have a dimension 3000 I ordered 2 1gb pc3200 ddr 128x64 to upgrade my computer but but every time i put 1 or 2 or the sticks in the computer. it beeps 5 times and will not boot up. I will boot if i...
Hello Sir. your PC3200 DDR (PC400) is not compatible with the dimension 3000, get a PC2700 (PC333) instead. or upgrade your motherboard to use a PC3200. BTW 2GB on an XP is too much memory. Use Vista, your processor lags. Its wiser to upgrade your motherboard and processor.
Jan 11, 2011 | Dell Dimension 3000 PC Desktop
I have a Gigabyte M85M-US2H 1) How do I find the revision number? 2) I want to upgrade the RAM and put in 2x2Gb 1066 I don't understand the comment by Gigabyte on their supported memory stick list:...
hello herra
have a look at the top left corner of the motherboard. gigabyte usually writes the version there or next to the main-board model on the board.
good luck
Dec 28, 2010 | Intel Motherboard
I have intel d845gvs1 motherboard with P4 2.4 ghz, Currently have 2 ram (512mb & 256 mb) how much further can i upgrade the ram, 1GB or 2GB also is the current combination of ram is right?
"Supports up to 2 GB of system memory with DIMMs utilizing 512 Mbit
technology DRAM devices"-intel
you can use 2 sticks of 1 gig apiece to get to 2 gigs of total memory, but you have to make sure that the ram sticks use "512Mbit " technology.
the 512Mbit technology refers to the arrangement of memory chips on the ram cards. a card which uses 64Mx8 (8 seperate memory chips of 64M apiece) would be appropriate.
"Nearly all motherboards only recognize 1 GB modules if they are low density 64M×8 modules. If high density 128M×4 1 GB modules are used, they most likely will not work."-wikipedia"
Oct 27, 2010 | Intel D845GVSR Motherboard
Does this motherboard support ddr400
Yes, this does support ddr400, there are two memotry sockets on the board they will hold 1 gig each you could try a 2gig stick in each but according to the spec on the board it only takes upto 2gigs of ram.
Jan 31, 2010 | Intel D845GVSR Motherboard
I need a sound with my computer
You can pick up all drivers needed for the motherboard here
Pick your OS and get the Realtek drivers and you should be up and running in no time.
May 10, 2009 | Intel D101GGC Motherboard
Cpx Pc Notebook memory upgrade
you can use 2x128mb or to flash the bios with new version..
Oct 28, 2008 | Dell Latitude CPX Notebook
Problem upgrading RAM to Intel D845GLLY
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
Jul 16, 2008 | Intel D845GLLY Motherboard
OS does not boot
Hello there.
Most likely the new stick(s) of memory is causing problems in your system. To verify this i would remove the newly added ram and see if the problem goes away.
Also you can download and run a memory test called 'memtest86+' from here. This can be burned to a cd and booted from the computer, to run a diagnostic on the new memory.
Hope this helps.
Apr 15, 2008 | Intel BLKD915GAVL (BLKD915GAVLX10U)...
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
I'd suggest using a memory tool, such as the one Kingston memory has: Enter the make and model of your motherboard and it will list the correct modules for your board. Crucial Memory has a similar tool.
Sep 25, 2007 | Intel ASUS X Series Motherboard P4P800-MX...
Intel D945GCZ Motherboard Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
