Question about Bosch 24 in. SHU43 Built-in Dishwasher
On 2/18/09, I had a part replaced (due to a recent recall issue) on our Bosch dishwasher, SHU43C06UC. I had not had any problems with my dishwasher - ever - and, since the replacement, my dishes are not being properly cleaned. The Sears repairman who replaced the part tells me that the part he replaced has nothing to do with my present issue and, because my DW is no longer under warranty, I would have to pay for any further services he may provide. 1) What do I need to do to troubleshoot this dishwasher issue, and 2) Considering I didn't have problems prior to the recall part being replaced, what would be my options?
    Guru:
  • 1,524 Answers
Http://www.boschappliances.com/safetyrecall/dishwasher/default.aspx?pid=BCH0905OIQ001
Posted on May 28, 2009
Does my Bosch SHU43C06UC/17 dishwasher have a hot water element in it? Our kitchen tap water does not get very hot, and before I hook up the dishwasher I want to make sure it will have water hot enough to...
Hi.
Your dishwasher should never be connected to a hot water tap.
Every dishwasher has its own Heating element. If you connect it to a hot water tap you may eventually damage the inlet valve which has sensitive plastic components in it and may even void your warranty if your installation manual suggests Cold water connection only.
Regards Sam
Oct 06, 2013 | Bosch 24 in. SHU30 Built-in Dishwasher
MY BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. I HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT I...
Hi gwmkjm,
I'm Harvey the Master Plumber.
Your question is: YOUR BOSCH DISHWASHER MODEL #SHU43C06UC/17 WILL NOT START. NONE OF THE LIGHTS TURN ON AS IF THERE IS NO POWER GETTING TO IT. YOU HAVE CHECKED THE POWER CORD AND THE BREAKER BOX AND EVERYTHING IS O.K., BUT YOU STILL CAN NOT GET IT TO TURN ON. AT ONE TIME THE LED LIGHT LIT UP FOR A BRIEF SECOND, BUT NEVER AGAIN. ANY OTHER SUGGESTION?
Yes. 9 times out of 10 it's a loose or broken wire in the d/w junction box under the d/w behind the kick plate on the right. Make sure to turn off the electric before you expose the wirenuts. Remove them and install new.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 28, 2008 | Bosch Dishwashers
Info light on dishwasher stopped coming on while running.
Please can you look at this link
http://www.bosch-home.com/us/support/safety-notices/dishwasher-recall.html
Some of the bosch dishwasher are subject to a recall the problem is exactly the fault you have tried to rectify in your submission. The recall is free of charge and the units are between 5 and 14 years old. You will need to enter the full ENr, FD and Serial No to check if yours is affected.
Mar 19, 2013 | Bosch SHX45M0xUC 24 in. Built-in...
My Bosch Dishwasher model #SHU43C06UC/17 in 5 years old and has been working great and all of a sudden last week it stopped working. When you try to start a new load it will start the timer, but the...
Welcome to FixYa.
I would first run a diagnostic to see what error is presented and in turn will direct which way to focus the repair.
Try this and then let me know what you find aa a result...
This diagnostic posted below should guide you, let me know if it isn't clear or you don't understand something.
Sep 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Hello, My Bosch she44c dishwasher is not evacuating the water from the machine. I checked the line and i can hear the motor trying to pump. I've tried to make sure the impeller was clean, so at this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 09, 2010 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch shu43c06uc-17. Our dishwasher turns off mid cycle, and now leaks from the bottom.
  1. open the bottom panel 2-4 screw
  2. take a flashlight and turn the machine on
  3. see where it come from
  4. if you need take the unit out a bit from the counter
  5. check it all around to find the sorce of the leak
  6. good luck its EZ :)
Nov 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a Bosch SHU43C06UC, the timer module was replaced during the recent recall. Before that, the old timer was within a few seconds of the technical information timers guide (page 57): R&H 9 min, QW...
Hi, I have a suspicion when the new control was installed the "programming" may not have been done correctly. You should contact the dealer responsible for the "rework". Failing any help with them I'd suggest contacting b/s/h customer service. To answer the question re; can it be reset to factory defaults ? Answer; sort of. If programmed correctly, you should have comparible cycle times as previously. There is always the possibility the control installed is faulty as well. I know having had quite a few reworks working for Sears, and the rare one was faulty. Hope that helps good luck
Oct 03, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher door leaks
Hi have you adjusted the door striker on the top part of the dishwasher? This is the part that the main door latches onto and can be adjusted in or out!
Feb 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Not Drying
I found that if the rinse agent (Jet Blue) has run out the dishes stay wet.
Aug 21, 2008 | Bosch SHU3305 Dishwasher
Dishwasher leaking around the bottom of the door
I had the same problem in 2004, lots of Bosch trained repair techs, calls to Bosch, and the appliance dealer we purchased it from with no answers. Our kitchen cabinet bases were ruined by the flooding that occured. After months of trying to get help I insisted on speaking to a supervisor that told me it was my fault for putting a flexible cutting board on the right side a blocking the vent. I told her that no where in the manual did it mention this issue and none of their trained techs were aware of this flaw in their design. When I asked about getting my cabinets repaired she said that was not an option. When I mentioned possible legal action her response was "good luck with that". Here it is 2009 and they recently called about a possible fire hazard recall for the control panel. The Bosch trained tech that came out to complete the repair knew nothing about the vent/flooding issue.
Jan 17, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
320 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
