Question about Cavalry Storage Cavalry CAUO37500 500GB OneTouch Ext USB 500 GB USB 2.0 Hard Drive
PC DOES NOT DETECT DRIVE POWER IS ON PC POP UP INSTALL DISK EXPLORE CAN NOT FIND DRIVE
Cant detect hdd
Hi Martin...
The problem is being caused by the Logical Disk Manager
Administrative service and possibly the logical Disk Manager service
not being started or the services might be disabled. to solve the
problem, click on the "Start" menu, click the "Run" command, and then type
in the box: services.msc , scroll down until you see both the above services.
right click on each of the services about and select properties, on the
general tab, change the startup type to "automatic" and click the start
button under the service status. do this for both of the services, and
that should will fix your problem."
For Windows 2000 and XP:
Right click on My Computer.
Choose Manage (This will open the Computer Management window).
Go to the Storage category and select Disk Management
Right click the new drive (usually listed as Hard Disk 1) and "initialize"
You now have the option to partition and format the drive.
The default settings of Primary Partition and NTFS- Quick Format are recommended for most users.
External hard drive can not be recognized, are more common on computer
failures, what's the reason caused this failure?
1, Setting the CMOS parameters
If you never used the USB external device, there may occur the case:
The system can not detect USB hard drive even if the driver is properly
installed, which was mainly due to the motherboard CMOS default port is closed, if not set to
open state, it naturally Windows can not detect the external hard drive. In order to solve this
problem, we can re-boot into the CMOS settings, and set "Assign IRQ For USB" to "Enable" in
"PNP / PCI CONFIGURATION" column, now the system can be assigned to the USB port available
interrupt address.
2, Power shortage
As the USB drive need to consume some power when it at work, if directly through the USB interface
to take power, the power supply may be not enough. Thus, almost all of the external hard drive
comes with a separate external power supply or a PS2 keyboard to take power transfer interface,
at this time you should connect external power supply or through the transfer cable ps2 connected
to keyboard to ensure that it have provided adequate power to the external hard disk,
recommended that you should ensure the external hard drive have adequate power supply when you
use it, otherwise, the external hard disk is likely to be damaged due to insufficient power
supply.
3, USB extension cable fault
USB interface type does not match the external hard disk interface ,this case caused it can not
be used. For example the standard USB interface of the computer configuration is 1.1, while the
external hard drives purchased are USB 2.0, which requires the cable connected computers and
external hard disk must support USB 2.0 standard. Because high-speed mobile device plug in a
low-speed hub, the device may not be properly installed, and some people use external hard disk
while using USB flash drives, For convenience, they directly used USB 1.1 standard cable that
supplied by USB flash drives, as a result, the USB 2.0 standard hard drive not be recognized
correctly. Just replace it by the USB 2.0 standard cable can solve this problem.
4, Windows version is too low
Pre-Windows 98 operating system does not support USB peripherals, so in any case to install the
driver, set the CMOS parameters are unable to make normal use of external hard disk. In this
case, one solution is to upgrade the operating system up to Windows 98, another way is to
Microsoft's official site, download the appropriate patch to make it can identify mobile hard
disk.
5, The system is set incorrectly
When installed driver, the external hard disk icon will be seen on the Device Manager for some
Windows 98 users, but the Explorer does not include the corresponding letter identification,
which is improper system settings. In the Device Manager, double-click the Hard Drive icon, and
click the pop-up window in the "Properties" button, and you could see disconnect, could be
deleted, synchronous data transmission and Int 13 unit four options, of which "could be deleted "
is no tick in front of the system, and simply check this option to restart your computer, you can
see in the Explorer, the new external hard disk drive letter.
While the failure of the external hard disk does not recognized are more the reasons, but
generally not the USB interface or external hard disk's own fault, so it requiring us to consider
some more from around the association when exclude it, I believe you can successfully use the
external hard disk.
Hi I had the same problem and solved it like this assuming that you are running windows xp
With your external casing powered-up (it does not get power through USB does it?) and your WinXP
PC running, plug in the USB.
You should hear 'chime', what happens then?
If harddisk is recognised here, but does NOT have a drive-letter and cannot be seen in Windows
Explorer, the answer is in Windows Disk Management
Go Administrative Tools > Computer Management > Disk Management. ( on left column)
Maximize this page. Physical Drives appear at the bottom; Logical Drives at the top.
Hopefully your drive will appear at the bottom (physically), you must then 'import' it into the
Windows installation
; Windows will put its 'signature' on the drive and assign it a logical drive letter :^)
you can try to format it here if it is new and has no info on it , check back to My computer and see if present.
Mar 20, 2013 | IBM FRU PN 49P1599 Desktop Motherboard
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Gateway M465-e laptop won't detect hard drive for XP install
The Gateway M465-e is only compatible the SATA hard disk drives. If the drive you are using is not a SATA drive, then it will not be able to work with your hard drive.
Dec 18, 2009 | Gateway Computers & Internet
Shuttle shut down problem
go to BioS set up..
see to it if the CD Rom Drive has been detected..
if Not,,, try to connect again
...back to BIOS SET up
if it detect..save it...
then boot the computer until it pop up the windows environment..
double click "my computer " icon
if CD ROM has there..
your computer normally shut down..
Oct 19, 2009 | Shuttle XPC PC Desktop
SAN Disk Pen drive detection
you connect your pen drive in your PC that will pop up one window named found new hardware....connect to internet and click on that window....that will ask tom install driver....follow the step and install the software.... restart your PC this problem will get over...\hope bthius will helps you... Thank you.....
Oct 10, 2009 | Express FormTool v5 (1077917SF)
HDD is not dedected.
the first thing that pops up in my mind is a power problem. check if the hard disk starts making a 'spinning' noise when you plug in the power chord and turn the disk on. when you hear a ticking noise instead, it means the disk is broken. be sure it only makes the spinning noise. if it does, connect the usb-cable between the disk and the computer. if the disk is not recognised, replace the cable. if still not ok, post what you did as a comment, and please be as accurate as possible, because this problem may have several causes.
Jun 22, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Will not read any media dsick in DVD combo drive
The disk should actually show up in the My Computer window as a removable drive. Right click on the icon, and select explore.
You should be in the file now.
Mar 16, 2009 | Averatec Refurb Centrino 1.3GHz 512MB 40GB...
Installing the external drive
In XP and Vista no need to install.
They will detect automatically.
To know, goto Windows explorer.
Find drive letter other than your local drive.
Usually called "removable disk".
Dec 26, 2008 | Maxtor OneTouch II external hard drive...
Disk drive not detected
When the drive is not recognized, try going to start->control panel->administrative tools->computer management->disk management and see if the drive is recognized by it, if so try assigning a drive letter then exploring it
Nov 17, 2008 | Dell Latitude D600 Notebook
My PC detects the USB Drive but it doesn't appear in the My computer display
HI
PLEASE GO TO MY COMPUTER RIGHT CLICK ON IT AND GOTO MANAGE IN MANAGE U SEE DISK MANAGEMENT AS SOON AS U CLICK THE DISK MANAGEMENT AND YOUR HARD DRIVE IS CONNACTED UWILL NOTICE A POP UP IF NEVER BEEN USED BEFORE THE HARD DISK AND THEN FOLLOW THE INSTRUCTION...AND IF IT WA S USED BEFORE THEN U GO TO DISK MANAGEMENT U WILL FING YOUR DISK LISTED SO U JUST HAVE TO SAY CREATE VOLUME AND FOLOW THE INSTRUCTION...
IF ITS IDE JUST BE SURE FOR THE JUMPERS...
Jun 03, 2008 | Samsung Spinpoint M HM121HI 120GB SATA...
Cavalry Storage Cavalry CAUO37500 500GB OneTouch Ext USB 500 GB USB 2.0 Hard Drive Logo
95 people viewed this question
Top Cavalry Storage Computers & Internet Experts
Arora Singh
Arora Singh
gary433
Glenn Smart
Glenn Smart
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
