Question about Hotpoint 24 in. FDW60 Free-standing Dishwasher
Hotpoint fdw60 dishwasher, heater not heating water or drying.
Have taken the heater out and it has been tested and found to be o.k.,any ideas !.
  • egocache Mar 12, 2009
    My FDW60 is not heating & after a period of time just the "delicates" light flashes, I phoned Hotpoint technical & they said it was an indication of a heater timeout. So I have tried a new heater element unit but still have the same fault, very frustrating at £42 & an hour crawling around under the machine!
    Anyone any ideas on just Delicates light flashing?
  • Anonymous Mar 16, 2009
    aaaggggggggghhhhhh!!!!!!!!!!!!!!!!
  • 25 Answers
If the heater is ok and the wiring is also not burnt out, then the fault will likely be the heater relay on the pcb. (Which means usually replacing the board).
Posted on Feb 28, 2009
Hotpoint fdw60 4th & 6th lights flashing
These two lights indicate a fault in the heating circuit.
You would require to have access to and be able to use a multimeter to test the heater if the machine isn't actually heating the water.
If it is heating the water then obviously we know the fault isn't with the heater.
Check the heater first.
Take the door apart and check the wiring in the door isn't broken.
If everything checks ok, take the pcb out, look for burned or dry joints around the relays.
Nov 05, 2012 | Washing Machines
My hotpoint Aquarius Dishwasher starts up bu only runs a few moments before stopping with 2 lights flashing " wash " " drying "
I had the problem of flashing lights and water did not pump out.Found a piece of bacon in drain pump wedged between impellor and pump body...cleaned it out...problem solved..
Mar 18, 2010 | Hotpoint 24 in. FDW60 Free-standing...
SDW60 - AL08 Error - No Hot Water
First switch off the machine and unplug it at the mains. Leave for 10 minutes then plug back in and re set your machine to the programme you want. It might be that the control panel needs re-booting. They are a bit sensitive and mine had a mind of its own, washed to its own agenda, left water in the bottom etc etc. so that might be the problem with yours. If that doesnt do it, go on the Hotpoint website and find the customer service number. Ask if there is anything you can do to solve the problem yourself before paying for a service call. It could be your heating element has packed up but try the easy fix first. Thats what I did and it cost just the price of a phone call. They were really helpful.
May 29, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hi fridge-1,
I had the same problem and fixed it by fitting a new control board .
Best of luck.
michael-howe
May 03, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 not heating the water or drying
open the dishwasher and take the bottom dish rack out, you will see a really thick steel wire which runs around the edge of the bottom of the dishwasher in a loop, that is what heats your water.
check to see if this has snapped
Aug 09, 2008 | Hotpoint Dishwashers
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Mar 18, 2008 | Hotpoint 24 in. FDW60 Free-standing...
FDW60 Fault
Hold down the start key and you will re- set the D/W.
Please Rate This !!! Thank YOU !!!
Mar 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Dishwasher trips the house mains
try to diconnect the heater and run the unit.
Oct 20, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint FDW60 problem
Wash motor either seized up/ faulty or the is an itme jamming up the impeller. Regards Advisor
Aug 22, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
728 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
