Question about Kenmore 98702 Stacked Washer/Dryer
Towel caught under agitator
Machine was trying to spin but couldn't. Smelled something burning. Found that there is a towel caught under the agitator. What should I do? Thanx
    Genius:
  • 2,920 Answers
Remove the top part of the agitator and inside youll see a nut that will have to be taken loose so tht you can get the agitator to raise up high enough to get the towel out
Posted on Feb 25, 2009
Maytag Neptune MAH5500 smelled like burning plastic at the end of the cycle. (The whole basement smelled bad.) The smell seemed to be coming from the plastic part at the top where it latches.
Tub bearings get worse, if they faulty, the machine would be noisy and getting louder. Sudden burning smells usually mean an electrical failure of a component but if this has stopped and the machine is working properly, its possible that something has got caught up in the rim of the tub or gasket area and during spin it has got "burnt" by being dragged around the edge. Have a close look at your clothes that were washed on that day for signs of burning or damage and around the top at leading edges of the tub for signs of melting or damage.
Mar 21, 2017 | Maytag Washing Machines
Seems like something is caught in the machine and stops the spin
when spinning the agitator and bowl spin as one unit
check for proper operation under machine
call a technician for a proper diagnosis and quote
Aug 18, 2016 | Washing Machines
Machine not spinning dry
Top-loading washing machine has an outer tub that fills with water and sits stationary as well as an inner tub with holes in it. The inner tub has an agitator that attaches to the drive shaft. A drive belt turns the drive shaft, causing the agitator to move back and forth. Broken seals at the bottom of the agitator, or a broken belt, may cause the agitator to perform inefficiently and leave your clothes dirty
In order to properly wash clothes and prepare them for drying, a washer must agitate or spin the load. This helps wring excess water out of the clothing. If your washer has suddenly stopped spinning properly, you will notice that your clothes will be sopping wet when the washer is done. Typically, there is a simple reason for this problem that you can fix without calling in a professiona
1 Check the lid switch. You will notice on the lip of the lid there is a small stem that hangs down. This fits into a hole on the top of the washer housing and tells the washer the lid is closed and it is safe to spin the load. If the switch is faulty or has been blocked, the washer will not agitate or spin.
2 Clean out the switch receptacle. Use a multipurpose cleaner and a sponge (not a paper towel, it can shred and get caught in the switch receptacle.) Thoroughly clean the area around the switch and the receptacle.
3 Test the washer. Close the lid, allow the washer to fill with an inch of water, and move the selector to the spin cycle. Pull out on the selector. If it does not spin, stop the cycle (push the selector in) and turn the washing machine off. This means there could be three problems with the washer: the switch might be broken, something might be caught in the agitator, or the motor for the agitator may be burned out.
4 Check underneath the agitator. Small items such as underwear, panty hose or bra straps can become caught underneath the agitator and keep it from moving. Run your hand underneath this area and see if you feel anything. If you do, unwrap the item and test the washer again. If it still does not work, move to Step 5.
5 Contact a repair person. If the washer still will not agitate or spin, it will need to either have the switch replaced or the motor replaced. Contact a certified appliance repair person to have the machine inspected. If it is still under warranty, the repair person's visit should be covered.
However if its only the agitator arm, then
Instructions to Remove/replace the Agitator
1 Unplug the washer.
2 Slide a putty knife under each side of the washing machine top to release the springs holding the top in place. Lift up the top on its hinges.
3 Pull the tub clips from the inner tub using a pair of pliers.
4 Pull up on the agitator top to expose the nut holding it in place. Remove the nut using a socket wrench. Lift up on the agitator to remove it from the machine.
5 Turn the agitator upside down and remove the seals from the bottom. Replace them with a new set of seals. If the agitator is cracked, replace it.
6 Reassemble the washer.
Removing the Belt
7 Unplug the washer from the wall outlet.
8 Pull out on the bottom panel on the front of the machine. Look underneath to locate the drive belt.
9 Pull on the drive belt at the washer tub to remove it. Push down on the idler pulley near the motor to remove the belt from the machine. Route the new belt around the pulleys in the same way as before.
10 Reassemble the machine, plug it in and test.
Apr 20, 2012 | Whirlpool Washing Machines
My washing machine will not drain,
2or 3 possibilitiies .faulty lid switch...if machine spins,lid switch is ok.something caught in water pump (very common),or a bad motor,(no spin or agitation),accompanied by burning smell usually..pls note:if something in pump,this can also prevent motor movement and cause overheating too
Mar 09, 2010 | Kenmore Washing Machines
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Help! I suspect an old towel ripped and got caught on the agitator in our Whirlpool Commercial use Super capacity washer (Mod # LSR8433KQ0) That's what seemed to be the culprit when I went out. Now it will...
normally, if the motor is humming, then you dont need to hit a reset button.
If water still enters, and water still drains, you may have a broken drive coupler, or bent shaft on transmission.
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore 70 series will not spin water out
Sounds like the tranny is possibly shot. The motor spins backwards to extract, and if the tranny is bound up the belt may spin and burn.
Jan 24, 2009 | Kenmore 22422 Top Load Washer
Kenmore Washer Won't Drain
yes, check the drain, could be clogged, or check the water pump assembly as well, the clothe could be stuck in the impeller.
the burning smell could be coming from a separate electric water pump and it can not turn that is why it is burning already.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Washing Machines
Broken Machnine
hi. thanks for the question. the problem is .there is something caught in the water pump, and a burnt out belt ,replace both parts thanks the appliance doc
Oct 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Kenmore 98702 Stacked Washer/Dryer Logo
137 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
