Question about Kenmore 46462 Front Load Washer
Replace enlet value
How do You replace the enlet value on a Kenmore washer serial. Num.110.26722693
  • 15,935 Answers
If you suspect you have a defective Water Inlet valve (also known as a FILL valve or MIXING valve) it can easily be diagnosed by performing the following steps:
- First, make sure the water taps are turned on all the way, and the fill hoses are not kinked in anyway. If everything checks okay, proceed to the next step.
- Now, turn the water taps off, disconnect the fill hoses from the back of the washer and place them in the wash tub. Turn the taps back on and make sure you have proper and forceful water flow (minimum water pressure should be 10-25PSI).
- Check the sediment screens on the Water Inlet valve on the back of the washer. Sometimes these screens will clog with rust or sediment and prevent water flow. Cleaning with some distilled vinegar works well.
If you’ve attempted all the steps above, but still have no luck, more than likely the inlet valve is bad and requires replacement. Please, read all instructions thoroughly BEFORE attempting. This is a simple repair that any “Do-It-Yourselfer” can accomplish. Follow the steps provided:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
7. The inlet valve is located on the back panel with two or more sets of electrical connectors attached to it. The connectors are usually color-coded to indicate which valve is HOT and which valve is COLD (In the case of a Mixing Valve, you may have additional electrical connectors). Remove the connectors and check the contacts for corrosion. Sometimes a good cleaning can restore a valve solenoid to working order. (You may want to label the connectors, if necessary, to ensure you know how they go back on).
8. Disconnect the small rubber water hose(s) attached to valve with a pair of pliers to release the hose clamps. Inspect the hose(s) for any evidence of cracking.
9. With the water hose(s) removed, loosen the mounting screw(s) and the inlet valve comes off.
10. Re-install new inlet valve following these steps in reverse order. Pay careful attention to make sure you correctly connect the HOT & COLD electrical connections (RED is usually the HOT water side). Make sure all hoses are fitted back in place and the hose clamps are snug.
11. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
12. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
13. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
14. Reinstall console.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Instruction manual , kenmore rotory 117-552 machine 1954
go to the website of sewvacdoctor.com & ask them about a manual
try
sewingpartsonline.com
sewusa.com
Apr 02, 2012 | Kenmore Sewing Machines
I need help removing the top of a kenmore washer mod num c1102250081 got the lid off but cant get the top off
To access the washer interior on these model washers, you need to remove the exterior washer case. The following link explains how:
http://www.fixya.com/support/r3631789-washer_case_removal_whirlpool_top
With the washer case lifted out of the way, you should have full access to all the interior components.
If you need further assistance, please post back and let me know. I hope this helps you.
May 03, 2011 | Kenmore Washing Machines
Won't stop cleaning to go to dry
I have not worked with this Kenmore model, but:
It would be good to check the heating element to make sure it has not failed. Some dishwashers will wait forever for the water to come up to temp before it goes to the next cycle.
If the heating element checks out:
-IF it has a knob/dial that you turn to start the dishwasher on any cycle, that timer/controller has most likely failed.
-If your dishwasher does NOT have a dial as described above, then the main controller card (PCB) has most likely failed.
May 05, 2009 | Kenmore 16072 - Multiple Color Built-in...
What is the date of manufacturing based on the serial number of my Kenmore 70 series washer?
Tyler,
It came off of the Clyde, OH production line the 26'th week of 2001.
Amazing, ain't it? Seriously... the info is embedded in the serial number. Here's the link to the code sheet.
Please remember to rate this solution as "FixYa", OK?
SG
May 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Need replacement coupling for Kenmore Washer
Go to a sears service senter and they can order one for you
Jan 22, 2009 | Kenmore Washing Machines
Kenmore Elite Top Loader "CE" error code.
CE means communications error
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Press STOP/CANCEL to clear the display.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Dec 18, 2008 | Kenmore Washing Machines
What is your serial and model number
From your model and serial num your machine is newer than what is currently accepted, I would keep bugging them.
Aug 25, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore 46462 Front Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
