Question about DFI NF4 INFINITY Motherboard
DFI NF4 INFINITY MOTHERBOARD NON BOOT
Hi, I have a DFI NF4 INFINITY MOTHERBOARD. When i turn the computer on it gives me the beep and everything appears to light up on the motherboard but it seems to stall at the infinity screen before it even reaches the part where it reads that all the hardware is there and working. Do you know what could be wrong?
This was working fine then shutdown and hasn't booted up since.
Any help would be appreciated.
  • 59 Answers
Could be the Hard drive or memory. Sounds as though it is reaching post. But dies after that, I would check both. I have seen both be the problem on other systems.
Posted on Feb 25, 2009
    Problem Solver:
  • 6 Answers
Sounds like a hardware problem. try unplugging all external devices including keyboard and mouse but not monitor. test if it works. if not, open the side of the case and remove the little battery found on the flat motherboard for 30 seconds. then slide it back into place. now try to see if it works. if still nothing, check to see if there are motherboard jumpers (they will be 2 tiny pins on the board with a clamp over the top of them, you probably wont find them), if you see the jumpers, move the clamp to the spot that says "clear cmos" then put it back. or if your motherboard has a clear cmos button on the board, press it and try the computer. if it still will not boot, it could either be the flat IDE cable (for a hard drive or cd drive) or the power supply which means you will need to purchase either a new power supply or ide cable. if all still fails, i would say the motherboard is shot.
Manual for LPUTNF4SLIDREXPERT
please help me find an online manual for this motherboard please mate hi brian i was wondering if u cud help me find an online manual for this motherboard (DFI LANPARTY UT nF4 Ultra-D) as im selling it on and want to check all the jumpers are in the correct positions please help me out dude, many thanks in advance for any help matey
Mar 27, 2013 | DFI LANPARTY UT nF4 SLI-DR Expert...
I want driver for this motherboard
Here are the links for the DFI NF4 driver you have requested.
Jan 26, 2011 | DFI NF4 ULTRA INFINITY Motherboard
Dfi nF4 DAGF red in light flashingon MOBO.. Fans
the cpu power probably isn't plugged into the mobo. It's the 4 pin spuare pwr connector
Jan 04, 2010 | DFI nF4-DAGF Motherboard
Intel D945GTP Motherboard - Replaced hd, installed XP Pro SP2 Downloaded Drivers from Intel Website. Ethernet doesn't work, ie can't connect to the Web or the home network. Device Manager says the device...
If you know all drivers are installed correctly and you still can't get onto the internet, then
I think you may have corrupt winsock files. Contact your ISP . They should be able to help you.
Hank
Jul 13, 2009 | DFI NF4 INFINITY Motherboard
DFI infinity wont post
Hi...
When your computer continuos beeping the problem is the RAM you need to open the CPU casing and check the remove the RAM clean the dust then after that, reinsert the RAM to the socket, then turn on your computer. "good luck".
Regards
PCmania
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Mike
Jun 28, 2008 | DFI Computers & Internet
Board stopped working
try one by one first the graphic card then with powersupply
Apr 21, 2008 | DFI NF4 INFINITY Motherboard
DFI nF4 Infinity problem!!! plz help
are the fans running - sounds like a PSU problem to me do you have a mutlimeter you can measure the voltage from the PSU - the motherboard website should have a manual, with pinouts and voltages.
May 08, 2007 | DFI NF4 ULTRA INFINITY Motherboard
DFI NF4 INFINITY Motherboard Logo
250 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Steve Frost
Steve Frost
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
