Hobart AM15T Dishwasher
Problem for Hobart AM15T Dishwasher
When are AM-14 tank heaters energized?
By lshipman01 on Feb 25, 2009
Just finished electrical installation for AM-14 for a customer, who purchased the dishwasher at an auction. It didn't come with a booster heater or gas heater. I've downloaded the operating instructions, but haven't found an answer to this question: the tank heaters are energized during the wash cycle (and maybe during the rinse cycle too--didn't check) but at no other time. Is this the normal operation? It would seem that if this is correct, then there wouldn't be much of an opportunity to raise the water temperature since the cycles are so short.
I would have expected the tank heaters to be energized as long as the tank water level was correct and the water temperature was below the setting. I'd be grateful for any thoughts, and thanks!...........Lee
Solution #1
posted on Aug 14, 2009
Not Rated)
paultech8226
Rank: Guru
Rating: 94%, 15 votes
When the float lifts in the wash tank, and the power is on, there is a few seconds delay before 2 con energises the wash tank heater. I is not dependant of the cycle, or if the door is open or not. If you open the control box door, you can monitor the wash heat led and 2 con. If you want to adjust the set point, the old boards have a heat sink in the middle, hold the yellow button near the top and adjust the trim poy on the board while observing the display. There should be a schematic attached to the waterproof barrier in the control box.
Was this helpful?
Yes
No
Solution #2
posted on Mar 02, 2009
Not Rated)
bigg t
Rank: Guru
Rating: 86%, 609 votes
Lee,goto your other post and i posted some solutions.Bigg T
Was this helpful?
Yes
No
Popular Solutions for Hobart AM15T Dishwasher
Questions and Unsolved Problems for Hobart AM15T Dishwasher
Do you recommend Hobart AM15T Dishwasher?
Answer
Answer
Removing Diplomat integral dishwasher to check filter and pump due to inaccessible blockage, as the... (More)
Answer
where would i find the dial switch position located on the dishwasher
Answer
need fagor 1VF 65VIT dishwasher fault code "decoding"
Answer
door will not close....wash cycle panel does not light up it is a necht dishwasher dont know the... (More)
Answer
temp on final rinse is 200 deg and dishes are coming out of washer with surface temp of 160. board... (More)
Describe your Dishwashers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
in Newport, KY
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 470-7119
All the parts that you need for your Dishwasher...
appliancehelp.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
