Question about Dometic RM2652 Refrigerator
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
  • Anonymous Mar 19, 2014
    sometimes it takes several trys to get lit
  • 93 Answers
You may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Posted on Mar 15, 2009
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
Our refrigerator works on AC. When switched to lp gas it sometimes come on and works and then goes off. Then we can't get it to work again. Then it will work if we turn on the hot water hea
It seems like a gas pressure problem. Possible blockage or kinked pipe or faulty regulator on the gas bottle. If the fridge runs ok only when you use the gas hot water, that would change the gas flow / pressure. LP gas products are normally around 1.5 to 2.75 kpa pressure. If you have access to a manometer, the gas pressure can be checked. (NB/ You should hold a gas service licence to do this)
Sep 29, 2014 | Dometic RM2852 Refrigerator
RM 2652 check light comes on anywhere between 1 minute and 5 hours after startup. Does same thing on auto or gas. If I restart it does same thing. I never know how long it will work. Please help.
According to the service tip manual if your check light is on then it will be one of these:
DC Volts
Wiring
LP Gas
Manual Gas Valve
Solenoid
Orifice
Burner
Thermocouple
Lower circuit Board
Since it does it on both AC and gas, you can toss out the LP Gas, Manual Gas Valve, Orifice and Burner.
Make sure that you have good DC voltage and tight connection to your refrigerator.
Jul 06, 2011 | Dometic RM2652 Refrigerator
Low flame on a 2600 dometic fridge/ flame is not enuff to keep fridge cold
Hi and welcome to FixYa, I am Kelly.
Download this manual:
http://www.dometic.com/9efb3e8b-c980-4383-952c-996a35e3c872.fodoc Go to page 12 for burner cleaning. Clean the burner and the gas orifice (jet) thoroughly. If after cleaning you still have the problem you may have to remove the solenoid vavle and clean out the gas safety valve. The manual also mentions checking LP gas pressure. A weak LP regulator will cause a low flame. I would clean it first... and if you still have a low flame check / replace the LP regulator before tearing into the gas safety valve.
Thanks for choosing FixYa,
Kelly
May 09, 2011 | Dometic RM2620 Refrigerator
Dometic RM 2800 Works great on AC but not on LP
Most likely cause is a blocked gas jet in the main burner its rare for the thermostat to be faulty but you cant dismiss it
Jul 27, 2009 | Dometic RM2652 Refrigerator
Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
May 18, 2009 | Dometic RM2620 Refrigerator
Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
624 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
