Top half of agitator turns free (does not agitate)
The top half of the agitator on my Whirlpool heavy duty capacity plus washing machine spins free and does not engage to agitate. The bottom half is working fine.
  • 1 more comment
  • dgheathcock Feb 25, 2009
    I've got some better terminology from the parts manual. The agitator is working fine, but the clothes mover (top half of agitator) is free wheeling.
  • dgheathcock Feb 26, 2009
    Thanks... I'll be looking aat those dogs tomorrow.
  • danita_mille May 15, 2009
    The top portion of the agitator spins freely and does not move the cloths.
  • 70 Answers
You will need a set of agitator dogs. Pull off your agitator cap and look under it, you will see 4(four)small tabs that catch and release the top 1/2 of the agitator.
Good Luck!
Posted on Feb 26, 2009
  • WRMtech
    WRMtech Feb 26, 2009
    Should be part number 285770
    Here is a YOUTUBE link that shows how to change them:
    http://repair2000.com/camdog.htm
    Best of luck
  • WRMtech
    well so much for the video, it has been removed. but the part number is still good :)
I have kenmore 80 series heavy duty/ super capacity plus washer that after it fills with water,hot or cold and it starts the wash cycle, I noticed that the agitator only moves once in awhile and stops
hum either a bad timer sticking the point contacts close. have u tried this in all cycles? and possibly a motor with bad windings not enough power to run agitation? try running in mild or gentle and see what happens? I was tempted to say the cam dogs in agitator but they dont work then stop then work, when they go out they go out.
Feb 17, 2015 | Kenmore Washing Machines
Whirlpool heavy duty super capacity plus washer will not agitate or spin. I replaced the agitator dogs but still have the same problem, is this a transmission issue?
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
Jan 22, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
I have a Whirlpool Heavy Duty-Super Capacity Plus, 7cycle/2 speed. Model LSR7200EQO , the agitator stopped working
My whirlpool heavy duty 2 speed 7 cycle washer machine stopped working, It fills up and aggitates for the first cycle then when it should drain and spin it doesnt drain nor spin
Jun 05, 2010 | Whirlpool LSB6200KQ Top Load Washer
Ultimate Care 2 Washer, Bottom half of agitator not turning
The problem is simple and inexpensive to fix. The agitator dogs are worn and need to be replaced. The following link explains:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
Read through the instructions and let me know if you have any questions. Use the part number provided for ordering any replacement parts. I hope this helps you.
Jul 07, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Old Washer won't spin or agitate
You found a belt? Most w/p washer do not have a belt they are direct drive. take off the pump and motor to replace the motor coupling, 2 plastic pieces w/ a rubber in between
Feb 15, 2009 | Whirlpool Washing Machines
Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Jan 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin or agitate
coupling.between motor and gearcase.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
526 people viewed this question
Top Washing Machines Experts
