Question about Shure Beta 52A Professional Microphone
Gooey black washer dissolved
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Contact Shure for replacement parts.
Posted on Jul 27, 2014
SOURCE:
Soap leaves behind after wash cycle
Could be using too much soap, soap that's too old will clump and not dissolve completely. If your soap is clumpy and very dry, dissolve it completely with boiling water in a pan, then put it in the unit.
Jun 15, 2014 | Maytag Neptune FAV6800AW Top Load Washer
Various questions re operation of LG Washer
In general, you do not need to dissolve powders before washing. In some cases, you can alter spin speed but not time.
Nov 22, 2013 | LG Washing Machines
I can't get my bosch nexxt 500 washer to wash in cold water - even when I turn off hot, the washer won't fill
Some washers mix some hot water with the cold during filling to dissolve detergent. I had to learn that too!
Aug 02, 2013 | Washing Machines
Chalky wash
Try dissolving the detergent first, if it doesn't dissolve in the water by itself, change detergents.
May 20, 2013 | Sears Kenmore 3.6 cu. ft. Top-Load Washer,...
Laundry detergent not dissolving
If you can let hot water to mix more with the cold when the washer fills, that will help the detergent to dissolve. If that's not an option, you can heat up about two quarts of water on the stove and when very hot, turn down the heat and add your detergent, then stir it till dissolved, and then add it to the washwater and clothes.
Sep 19, 2012 | Fisher and Paykel Washing Machines
The soap doesn't dissolve
your using to much soap . pour vinegar about a half cup into the bottom of the washer before you start, do this about 3 washes then should be okay,
Sep 09, 2012 | Magic Chef 5-Cycle Dishwasher
My washer will only dislove the powder saop on warm or hot cycle and now it won't let any water in to the tub at all why
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Your service manual and more notes on LGs HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 09, 2010 | LG WM-2277HW Front Load Washer
Action Packs not dissolving
these packs do not dissolve good in cold water. check that the washer heats up correctly, if it does not, get that fixed.
maybe you bought a bad series of packs. maybe they do not dissolve correctly. test one in hot water (about 50°C). they should dissolve good then.
Jun 04, 2009 | KitchenAid 24 in. KUDS02SRSS Stainless...
Clothes smell of old dirty water, after washing
this will solve your problems
Affresh™ Washer Cleaning Kit Affresh™ Washer Cleaning Kit contains 3 Power Puck tablets and 6 Grit Grabber cloths. The tablets remove and prevents odor-causing residue that can occur in all brands of HE washers. Affresh™ cleaner is a formulated, slow-dissolve, foaming tablet that gets under residue, breaks it up, and washes it away leaving the washer smelling fresh and clean. Simply place one tablet in the wash basket (without clothes) and run a Normal Cycle (hot option) or Clean Washer Cycle. The Grit Grabber™ premoistened cloths have been formulated to penetrate, dissolve and remove odor-causing residue from the rubber door seal. Now consumers can clean where they can't reach with the Power Puck™ tablets and where they can with the Grit Grabber™ cloth. Affresh™ brand is environmentally friendly, safe on septic tanks, and safe for all washer components. Package includes three tablets. Part #W10194073 $10.99
Please remember to leave a solved rating!
Dec 07, 2008 | Whirlpool Washing Machines
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Shure Beta 52A Professional Microphone Logo
47 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
