Question about Dishwashers
How do i replace lever seal?
Is this a job my husband can do himself? he took the door apart and figured out the problem. will he need to replace more than the lever seal in order to fix the leaking? (will he need to purchase the surrounding parts, also?) is that part easily replaced? he is pretty handy fixing things.
the dishwasher is leaking water from underneath the door when it is in the wash and rinse cycle (when the water is being sprayed). it isn't a lot of water, just some light dripping.
  • 547 Answers
Http://www.partstap.com/ Hi you should be able to find instruction on this site as well as parts thank you for useing fixya please take the time to rate me
Posted on Feb 25, 2009
Can gasket for CR09FFW be replaced?
if you are referring to the door seal ( sometimes called a gasket) yes it can be replaced by a new genuine item or in some areas there is a private operation that goes around making door seals to fit and are fitted as part of the price
look in the yellow pages (business directory ) for refrigerator repairs or refrigerator door seals
Note here - although you may contemplate doing the job your self , some old seals are glued in and need knowledge as how to remove it , and the door will some times go out of shape when the door shelves panel is removed so it is best to get in a professional to do the job
Nov 11, 2015 | Crosley Refrigerators
How to replace bottom door seal
Difficult job. It may be possible to take the door halves apart and get to the screws that hold that bottom door seal to the door, but in some cases, it is necessary to remove the door completely and take it apart to be able to replace that bottom door seal. In any event, it's probably best to call a professional dishwasher repairman and let him do the job.
Sep 24, 2014 | Dishwashers
My husband took the entire stroller apart to wash it. How do I put it back together?
try looking online at the manufacturers site to see if they have diagrams. otherwise i would see if the hubby knows how he took it apart. other than that it might just be trial and error. good luck
Aug 23, 2011 | Toys
I have a Magic Chef self-cleaning oven. The lock lever broke as I was trying to open the oven door after the self-cleaning cycle was finished; Any suggestions for getting the oven door opened? And if I am...
I had the same prob. Just today I figured it out. My husband tried for a hour the other day and it just took me 30. Min. Lift up the burnner part. You will have to unscrew a cover that sticks up on the front part. Open that section and this is what I done. I beat it with a hammer to ser it it worked, but no. I played with it then I took a screw out on the lever and wool
Jul 24, 2011 | Ovens
I took the bladeoff to oil and now can't remember how to get it back together.
i needed to replace my blade - my husband replaced it but it would not cut so we took it apart and cant figure out how to put it back together. nothing helpful on line.
did anyone have a link how to put all the pieces back together to create the blade? thanks
Jan 16, 2011 | Oster 76076-010 Hair Trimmer
I have a stackable washer and dryer. Both have worked fine except recently clothes started getting caught between the drum and the front frame of the dryer. My husband pulled it apart checked the screws...
You may have a felt seal in the front that needs replaced. A wire off the pin switch could be off, and you will see the pin switch when you open the door, and make sure it is clicking.
Jun 22, 2010 | Kenmore 63942 Dryer
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
LG WD-1021-WF Front Loader Washing Mashing
Not a hard task if you coat rims with liquid detergent before trying to install new seal.
Using thumb go slowly around rim working seal all the way back.
Replacing main spring can be done by working bottom to top and then hold left side of spring in place while you pull right side in with long nose pliers.A couple of minutes difficult work and your 90% done.
Care is required so as not to puncture seal,
Main point is to ensure seal is fully seated before applying spring.
Having machine laid on its back makes the job so much easier.
This job took an hour and 30 minutes, the hour spent checking the internet first.
Good luck
Kevin
Jun 20, 2008 | LG WD-1280FHD Front Load Washer
VERY LOUD GRINDING NOISE LG WM-2277HW Front Load Washer
Get a new washer. Perhaps another brand.
The fix for me was to get a new washer. Had same issue with loud spin cycle. Tried researching while wife was continuing use of washer. Then the LE message appeared.
Took back apart and found that water had leaked and caused a boat load of damage. Bearings shot, seal leaks, drum leaks, Stator damaged. Same issue as 'jammy64' stated.
Cost to repair wasn't worth it. Going to get an
Electrolux model.
May 19, 2008 | LG WM-2277HW Front Load Washer
Attachment hose has no suction
Sometimes when you take them apart and
reassemble the vac (the plastic slide doesn't
make full contact with the lever,or it isn;t on
the lever at all) that switches
from the floor to the attachment. IF Tthere
are no clogs in the duct then that the
most likely problem
Nov 18, 2007 | Dirt Devil 12 Amp HEPA Filter Vacuum...
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
