Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The electric has gone off--can I use the oven by lighting it myself? how?
  • 6,784 Answers
Sure but, this is not recommended so be very careful when igniting this oven manually. i would turn on the gas at a very low range then, use a fire place match. These matches are very long. If your range is totally electric. you will not be able to use the unit because it uses an element that is charged by electricity.
Posted on Feb 25, 2009
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Baumatic OSF60OVEN 60cm fan oven. Grill works, fan works, light works but oven is not heating up. Is it likely to be something I can fix myself?
You possibly have a blown heating coil, the most likely one is in the main oven, as this is the one that's used the most sometimes you can tell as the element shows signs of blowing other time it doesn't the only way to check this is to remove it and put a test lead to either end on connection clips to see if it's dead also on the element it's self to see if it's gone to earth, but must be removed or disconnected on the end terminals so you don't get a false reading. if you are a handy type person there is no reason wye you can't undertake this work just make sure the electricity is disconnected from the oven prior to any work being undertaken Good luck
Mar 02, 2015 | Baumatic Ovens
My smeg electric oven model no. SA22XMF/7 is not heating after we lost power. Fan and light is working but the heat is not. What can that be ? Is it the fuse or the element has gone
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Nov 29, 2011 | Smeg Ovens
Fan forced element is broken in my Smeg SA301X. I'd like to fix it by myself. I opened the cover in side and measured the element. there are 3 screws fixing element on the back wall. one in the bottom...
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Aug 17, 2011 | Smeg SE250XUK Stainless Steel Electric...
Smeg se280x has just gone dead in middle of cooking .the digets have gone and is blank the oven fan @ light still work but that is it regards paul ?
Jul 18, 2011 | Smeg SE280X Stainless Steel Electric...
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
Lower oven not heating
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Oct 10, 2010 | Zanussi ZCE7551X Electric Kitchen Range
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Key pad light
how old is oven does elements stay on when lights fade or they dim too will advise after reply
Dec 27, 2007 | Jenn-Air JMW9530C Electric Double Oven
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
123 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
