Question about Stratitec 5-Port 10BaseT Ethernet Hub (68853310038)
Cannot connect internet to ps3 and computer at same time
I am using a SURFboard SB4100 cable modem and a Stratitec 5 port T-10 router. I can get internet to my home desktop computer or my ps3 but not at the same time. Any suggestions?
  • Anonymous Apr 04, 2009
    i have a netgear gs105 router but i cant get on the internet at the same time with my computer and ps3, its either one or the other.maybe im not hucking it up right....i give up
  • 258 Answers
Try setting a static ip address, instructions can be found here:
http://www.howtofixanything.co.uk/howto-273.html
Posted on Feb 25, 2009
Can this be used as a 56k router? I need to have a temporary internet connection and it is only a basic connection because of the type of phone there is at the house. We tried to connect but I don't have...
The SB4100 is a digital modem that uses cable TV network to provide broadband Internet access, it can't work with an analog telephone line, for this type of Internet access (also called switched Internet connection), you need an analog internal or external 56K modem, and also you'll need a user name and password (an account) from the Internet provider service (ISP) ; for a temporary Internet connection maybe a prepaid cellular modem (GPRS, EDGE, 3G or 4G) USB type could help you better.
Feb 27, 2011 | Arris SURFboard SB4100 Modem
I got a NETGEAR router and I have been trying to get my Motorola SURFboard to recognize it. I had the USB connection installed and the NETGEAR uses ethernet, so I tried to install the ethernet but my...
The Cable modem must be disconnected from the computer. You cannot use USB and Ethernet at the same time.
1. Turn off power to the Cable Modem and the Netgear Router. Do the same with the computer.
2. Connect an ethernet cable from the modem to the router's WAN (Internet) port.
3. Connect another ethernet cable from one of the remaining 4 LAN ports on the router to the computer's ethernet port.
4. Now power on the Cable Modem ONLY. Wait for the modem to sync up with your service provider
5. After about 2-5 minutes power up the router and wait about 1-2 minutes.
6. Now power on your PC.
Check and see if you have internet access. If not you may have to uninstall any cable modem software related to USB connection. if this is the case, then you may have to repeat steps 4-6.
Since most cable internet providers do not use proprietary connection settings, your internet connection should be up and running without changing any settings in the router or modem.
If this does not resolve your issues, we can continue to work with you.
Nov 29, 2010 | Arris SURFboard® SB5101 Cable Modem
Globe symbol won't turn green.
I was banging my head for 2 days with about 35 different configurations and finally tried the following and it worked just fine. Also, tried connecting 3 computers and they all connected with "NO" issues. Even connected wireless with "NO" issues. Now I am at 20mb download speed...J compared to AT&T 1.5mb download speed.
This is my DLINK model -> (DIR-601 Wireless N 150 Home Router Wireless router)
1. Reset your Comcast Surfboard Cable Modem by unplugging it for 5 minutes.
2. Then reset your DLINK Router to the manufactures default settings. Then Unplug DLINK Router for 1 minute then plug it back in (Just plug your cat5 cable into port 1 and connect it to your computer) there should not be anything else plugged into the DLINK Router at the time you make the changes. Just 1 computer can be connected.
3. Went into the DLINK configuration 192.168.0.1 and changed the PPPOE setting that I was using for my AT&T Modem to Dynamic IP (DHCP). Once you make the changes save them and then unplug your DLINK Router it's off.
4. Turn on Comcast Surfboard Cable Modem and wait until all lights are on. Now plug in a cat5 cable from the Surfboard Comcast modem (NOT A CROSSOVER CABLE LIKE THE CD INDICATES) to the INTERNET port of your DLINK Router. Now turn on your DLINK router.
5. Then turn on your computers or restart them and it will pick up IP Addresses from your DLINK Router
Jun 08, 2010 | D-Link Wireless N 150 Home Router 4Port...
What is the best router to buy for a SURFboard SB4100 Cable Modem?
For this one the best router that I can think that you can consider in using are this 2 model , for a regular wireless G router you can get this model WRT54G , but if you have a large house and needs a stronger and wider signal for the wireless computers you can get this WRT300N they are both from Linksys.
May 01, 2010 | Arris SURFboard SB4100 Modem
I want internet on the other side of house
In order for you to accomplish that goal what you need to buy is a wireless router that can be located on the other side of your house so computers there can have internet access wired or wirelessly connected to the router. You can get a wireless router from Linksys, Netgear , Dlink or Belkin.
I have a Motorola SURFboard SB5101 Cable Modem a Netgear mr814v2 wireless router, I obtain the ip address on router status but for some reason my internet communication losed. I verified the configuration...
Hi, follow the steps below to configure MR814 with your motorola surfboard:
CONNECTIONS:
1. Connect a Ethernet cable from the modem to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that there is no direct connection between the modem and the computer (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually with http://192.168.0.1
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Jul 29, 2009 | Arris SURFboard SB5101 Cable Modem
I have a cable modem. from the cable modem I go to a 5 port hub
That is because most cabel internet providers only gives you one public IP. Please go to a Best Buy, Office Depot, Staples, Walmart, or Targer, and ask for a LinkSys Router. The router will do NAT (Network Address Translation) that will allow more than one PC share the single public IP. This will solve your problem and will cost an estimated $30.00. The router is simple to hook up, just plug the cabel from your modem into the Internet/WAN port on the router. And the two computers into any of the other ports. Be sure to unplug both cable modem and router then plug up the cable modem first, once the ready light is on, plug up the router.
Adam
Nov 15, 2008 | Stratitec 5-Port 10BaseT Ethernet Hub...
Losing connection
I assume this is a cable modem? You need to call your cable company and have a trouble ticket created. I worked for the cable company installing cable for quite a while and I bet my paycheck the signal getting to the modem are below specs and that's why the modem gets dropping the internet connection.
Hope this helps.
Aug 13, 2008 | Arris SURFboard SB4100 Modem
Computers & Internet Logo
380 people viewed this question
Top Stratitec Computers & Internet Experts
David Payne
David Payne
Are you a Stratitec Computer and Internet Expert? Answer questions, earn points and help others
