Question about Samsung NV15 Digital Camera
Replace lcd screen on nv15 camera
How do I replace lcd screen on samsung nv15 camera
  • 102366 Answers
SOURCE: set date and time on my NV15 samsung camera
Follow the instructions beginning on page 70 of the manual. If you need a manual, you may download it at http://downloadcenter.samsung.com/content/UM/200802/20080222092305125_NV15_English.pdf
Posted on Sep 09, 2016
Set date and time on my NV15 samsung camera
Sep 09, 2016 | Samsung NV15 Digital Camera
Can the LCD screen be replaced? I dropped the camera and there are now two black smudges on the view screen the make difficult to take and view pictures. If so, what is the cost?
It can be replaced by a camera repair shop, but will likely cost more to replace than to purchase a new camera of the exact same type (or better).
Mar 10, 2011 | Samsung NV15 Digital Camera
My samsung nv15 camera will not load pictures on to pc when plugged in via usb port the camera switches on with opyions of 'computer' and 'printer' but neither will open to allow me to see pics instead...
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 06, 2011 | Samsung NV15 Digital Camera
The shutter on my NV15 camera is open but no image is displayed.
The Iris or CCD may be the problem. The Iris may be wet - preventing it from fully opening or closing (or it might be stuck). The CCD may be bad - preventing the image to translate into an electrical signal. Try leaving it in a dry environment for a day to dry.
Nov 04, 2010 | Samsung NV15 Digital Camera
I caint load my picture to computer it says usb
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
May 12, 2010 | Samsung NV15 Digital Camera
My samsung flas NV15 won't open. It's stuck. Can I force it to open?
If it's just some dirt or sand that's stopping it, you can try to gently assist it. However, the gear assembly could be faulty, so don't force it too hard, or you'll break some teeth in the gears and make it worse. Not an easy fix sometimes, since it could be the electronic circuit for the gears. Last resort, of course, is maybe get a good replacement or parts camera on Ebay. Good luck!
Feb 25, 2010 | Samsung NV15 Digital Camera
Sound problem
it mutes while you zoom in or out.
Nov 22, 2009 | Samsung NV15 Digital Camera
Samsung NV15 Digital Camera Logo
64 people viewed this question
Top Samsung Cameras Experts
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
