Question about Hitachi 43FDX15B 43" Rear Projection Television
1.5 ohm resistor rk 46 keeps blowing
I have the red shift convergence problem. I replaced the 392-120 with 392-150 and all the resistors. it worked but did not solve the shift issue. I noticed that the rk46 resistor was burnt so I replaced it and put in stk394 160 ic which is supposed to be a direct replacement for the 120,150 chips. I powered it up and it fried the rk46 1.5 ohm resistor almost immediately. Put another resistor and it did the same thing. I noticed that the resistor is in series with two diodes which seem to check out ok. I noticed that the resistor connect to a plug labeled red pcb which appears to be the red cathode ray gun. turned the set on without the divergence board connect and all the guns seem to emit a snow ball pattern in their respective colors I shut it off immediately to avoid damaging it. Do I need to buy two more chips or is there another problem?
  • bmcdoodle Mar 15, 2009
    Guru, If you read the other posts regarding convergence ics you would see that it is a common and successful procedure to swap the 120 120 with 150s of the same prefix and is also recommended by Hitachi. I am looking for solutions from people who have specific experience with this problem. Thanks for trying
  • Hitachi Master
  • 3,459 Answers
You should have put the original OEM STK's in the set - if your set had 110's or 120s put those chips only. Do not risk different chips with different specs/amps/ etc....when you do resistors blow as you have discovered.
Posted on Mar 15, 2009
RK46 BURNT CANNOT SEE COLORS ONLY 2 STRIPS DARK AND 2 STRIPS LIGHT. WHAT IS THE OHM VALUE AND DO I INSTAL GOLD STRIPS TOWARDS IC OR AWAY. HATACHI 43FWX20B DP24 JOE
rk46 is 1.8 ohm resistor---rk54 is the same value, rk 62 is 2.2, and Rk 42 is 3.3 ohm. It does not matter which direction it is installed---it is a resistor
If you have any questions feel free to let me know.
SD TECH
Oct 08, 2009 | Televison & Video
2.2 ohm resistor blowing after convergence repair
It might be the issue on the board. I would recommend you to show it to a repairman
Sep 07, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red color distortion hitachi 46f500
Can't remember which this one uses but its right on the chips. Check your resistors too.
Apr 08, 2009 | Hitachi 46F510 46" Projection HDTV
Convergence
If you cannot align, the ICs probably need to be replaced. You can check the input on feedback resistors in front of the ICs with an ohm meter. Some resistors may be bad causing your problem. Usually you would need to replace the ICs and bad resistors and do a full re-alignment to fix.
Dec 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence repair problems.
alot of people make the mistake of putting two STK392-150 Ics in the Hitachi , and most times it will not work unless you change all the convergence resistors.. If youre going to upgrade hitachi to anything other than the stock ICs, it is recomended by Hitachi to use the STK394-160 ICs but then you have to change the ratings on the resistors. You can get the upgrade kit for your hitachi at the following link.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Rear projection tv
You will need to replace both convergence ICs they are STK392-120 and that model will also open 2 or 4 of the 6.8 ohm 1 watt resistors. You can get replacement ICs and resistors at the following link with free instalation instructions with pictures as well as free tech support to help you locate the open resistors that will need replacement. Here's the link.
Jun 26, 2008 | Philips 46PP9302 46" Rear Projection...
Color convergence?
Can anyone give me the resistor values for location RK 42, RK 46 and RK 62? Hitachi 46F500 TV. Or can I be pointed to the location of a service manual?
Tony
Sep 13, 2007 | Hitachi 46F500 46" Rear Projection...
Resistor ohm values??????
RK42 = 2.2 , RK46 = 1.5 , RK58 = 3.3 , RK52 = 1.8 , RK 50 = 2.2 , RK54 = 1.5
Aug 28, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 43FDX15B 43" Rear Projection Television Logo
358 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
