Question about Nokia 6086 Unique Phone - Pay Monthly
Nokia phone blinking
My Nokia 6086 cell phone is blinking continuously. Every 5 seconds, the screen turns solid blue. That lasts for a split second, then it atarts all over again.
Any ideas?
Thanks!
  • naturalchild Feb 25, 2009
    Thanks for the quick reply. We already flashed the phone, but that didn't work. I guess it's time for a new one.
  • Anonymous Mar 01, 2009
    My Nokia Phone is blinking on and off continuously. I have heard this from many other people who have the same phone. I want to know why this is happening! Help!
  • 70 Answers
Hi
It can be a software or hardware issue. If it's a software issue, you will need to bring it to a cell phone shop that will flash your phone and that can solve the issue. If it's a hardware issue then you might need the replace the lcd on your phone or other parts and that can be quite expensive almost not worth it, better of buying a new phone on Ebay.
David
CellUnlock.net
Posted on Feb 25, 2009
Nokia 3110 blinking at start up
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 03, 2012 | Cell Phones
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
Cant get it to woork blue light just blinks
you have to put ur bt device into pairing mode in order to pair it to a cell phone usually when u turn your bt device on you continue to hold the power button for 6 to 10 seconds and when you have a solid light you are in pairing mode then your cell will pair to your device,it will ask for a pin or pairing code,most blue tooth manufactures use a 4 digit code.the codes to most blue tooth devices are as follows 0000,1234,9999,or 1111.i hope this helps
Feb 20, 2011 | Jabra BT125 Headset
I would like connect Nokia bluetooth headset bh-602 to iphone, pls help me
go to the menu on your phone select manage connections turn on bluetooth then you'll see search listen, etc. position on search don't press yet
get your ear piece ready: press the on button and hold it until you see a solid blue light (not blinking but solid) if it blinks try again until you get a solid blue light (it takes about 5-8 seconds) when that happens go to your phone and press search it will look for devices (it may find several) look for your earpiece model and select it
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect
check on the connection manager again and your bluetooth should be on and connected.
if it works for you, don't forget to rate me
thx
Jun 06, 2010 | Nokia bluetooth headset bh-602
How to conet to my mobile phone name is nokia 6303i classic
go to the menu on your phone select manage connections set up bluetooth then you'll see search listen, etc. position on search don't press yet.
it will ask for a code or passkey, type 0000. Then it's going to ask if you want to bond or pair click yes and it will connect, check on the connection manager again and your bluetooth should be on and connected.
May 27, 2010 | Jabra BT125 Headset
Motorola HS850 N136 bluetooth won't go into discoverable mode. I press and hold the call button. The light turns blue for a second but then turns off. I am trying to get my cell phone to discover it.
open the boom (mic) right when it turns to solid blue!
http://www.motorola.com/consumer/v/index.jsp?vgnextoid=4507f7c0c1a0b010VgnVCM1000008206b00aRCRD&ps=y&pg=PG_TYP_00003&show=globalSupport&productID=e4e6e7af976c9010VgnVCM1000008206b00aRCRD
May 06, 2009 | Motorola Mobility HS850 Consumer Headset
Nokia 6085 screen flashes off every 5 seconds
I didn't think there were any software updates for the 6085. bring it to your service provider or nokia, or call nokia.
Mar 10, 2009 | Nokia 6085 Cellular Phone
My cell phone screen keeps on blinking
its just a problem with connections inside tighten up screws if you have knowledge in doing so...
Nov 24, 2008 | Nokia 6085 Cellular Phone
Nokia 6086 shuts itself off
This sounds like part of your power board is having problems. There may be a resistor heating up on it, or even a solder bridge, whihc results from a surface mount machine. In other words a factory defect. I would take it back and make them fix it under the warranty. Hope this helps,
amsoilgirl
Nov 15, 2008 | Nokia 6086 Unique Phone - Pay Monthly
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Open Questions:
Related Tags: code unlocking kodovi Problem with Nokia 6086 Unique Phone - Pay Monthly I cant find a unlocking code for my nokia 6086 I cant find a unlocking code for my nokia 6086 thanks AdChoices Showers for Special Needs DisabledBathing.com Get Info On Our Line of Showers for Special Needs. Free Brochure! Remove ULocker Ransomware www.spywareremove.com How to Remove ULocker Ransomware. ULocker Ransomware Removal Instr. Posted by bennebennett on Feb 22, 2009 Answer Question Add Comment Print Email Flag 2 Solutions k srinivas ganesh May 11, 2010 CAN U GIVE ME UR IMEI NO 2 Solutions bhupender sehgal 421 solutions May 30, 2009 Http://unlock.nokiafree.org/ visit this website to unlock your phone AdChoices Instant Unlock Code $1.79 www.cell-unlock-depot.com Instantly Unlock Cellphone By Code Use Any Carrier Paypal Verified Exchange Email Archive www.gfi.com/exchange-archiving Solution For Business's Email Management System. Free Trial! Was This Helpful? 1 Reply 4 Comments bhupender sehgal Jun 04, 2009 http://unlock.nokiafree.org/ sir please visit this website to unlock your phone thnks bhupender sehgal Sep 09, 2009 please give me your imei number Unlock Codes 617 solutions Mar 31, 2010 I used this site http://www.unlockcellphonecode.com/product_info.php/code-for-unlocking-nokia-mobile-cell-phone-p-68 Was This Helpful? 0 Reply Add Your Solution bold italic underline indent outdent undo redo insertOrderedList insertUnorderedList speaces insertText insertYouTube insertImage createLink Share on Facebook Get a New Cell Phone on Nextag Browse Deals and Offers for a Cell Phone. Get Accessories on Nextag Get accessories for your Nokia Cell Phone. Users Who Viewed This Problem Also Viewed: How do I pair the Nokia 6086 with the VM605 How do I pair the Nokia 6086 with the VM605 handsfree? charmel460 Dec 28, 2009Cell Phones41 Views1 Solution Unlock code for my nokia 6303 hi can anyone tell me if they hve an unlock code for my nokia 6303 kal_1001 Apr 4, 2010Cell Phones462 Views1 Solution Unlock nokia 6086
Feb 27, 2017 | Nokia 6086 Unique Phone - Pay Monthly
Nokia 6086 Unique Phone - Pay Monthly Logo
296 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
