Question about Toymax Binatone S350 GPS Receiver
Says on display failed to load language resource file
  • psytron Apr 02, 2009
    I have the same problem with my Becker Traffic Assist highspeed 7934, it says failed to load language file, and cant work or proceed with it.
Facebook give me lot of error when i get out of a game on facebook many windows open and i can't close them
Try using a different web browser
like Firefox or Google Chrome.You
can get them INSTALLED over at the
link below. Good luck:
Ninite Install or Update Multiple Apps at Once
Nov 08, 2014 | Facebook Apps
She gets an error message when booting up:: Fail to load language file
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. Go to Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but only when you initiate.
If this fails, even though this should fix it, download CCleaner (free) and clean your Windows Registry.
Oct 05, 2012 | Acer Aspire Computers & Internet
Cant sign on to computer
    • 1 Download the missing comctl32.dll file. Locate a website that offers the comctl32.dll file. You can also use the link in the Resources section.
    • 2 Unzip the download file if it is a .zip-type file. Right-click on the file and choose "extract" to make the file available in a .dll format.
    • 3 Install the missing comctl32.dll file in the proper folder on the computer. If the operating system is 64-bit Windows, copy comctl32.dll to the "C:\Windows\SysWOW64" folder. If the operating system is 32-bit Windows, copy comctl32.dll to the "C:\Windows\System32" folder.
    • 4 Restart the computer by clicking on the "Start" button and selecting the "Restart Computer" option.
    • 5 Open the computer program that previously displayed the error message stating that the file comctl32.dll was missing. This will verify the program now works properly.
Nov 21, 2011 | Dell Latitude D 600/610
I HAVE WNDOWS 7 STARTER, I WANT TO CHANGE MY PC LANGUAGE FROM FRENCH TO ENGLISH, HOW CAN I DO THIS?
Make the FixYa experience better for everyone by voting!
The following is through the courtesy of Microsoft:
Instructional Video: CLICK HERE
Change the display language
The display language is the language that Windows uses in wizards, dialog boxes, menus, Help and Support topics, and other items in the user interface. Some display languages are installed by default, and others require you to install additional language files. When you change the display language, it is changed for your user account and is not changed on the Welcome screen. If you want to set the display language for multiple users or the Welcome screen, see Apply regional and language settings to reserved accounts.
  1. Open Regional and Language Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Regional and Language Options.
  2. Click the Keyboards and Languages tab.
  3. Under Display language, choose a language from the list, and then click OK.
gl_ico.png Note
If you don't see the list of display languages, you need to install additional language files first. For more information, see Install a display language.
Jun 25, 2011 | Packard Bell EasyNote E2 316 Notebook
I have a Designjet z2100. I loaded the drivers from the support site. Whenever I print, the printer display reports wrong file format. I am using window 7 64 bit and have tried using windows update to...
Next time include the System error code, in this case 61:XX.
Power off and remove the power cord. Reconnect and power on. Make sure that the correct driver is loaded.
Make sure that the Graphic language setting is correct.
Resend the file to the printer.
Make sure that the Firmware is up to date. Upgrading the Firmware will re-install the PostScript fonts.
It is also possible that the file is password protected.
Do all files fail?
Mar 25, 2011 | HP DesignJet Z2100 InkJet Photo Printer
Change the language
click start control panel,regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location
hope this helps
Jan 13, 2011 | Computers & Internet
In my Laptop Key board, if i type any alphabets the same will not be displayed on screen instead of which Some other symbols are getting displayed, post which i am not able to understand that symbolic...
It may be likely that your keyboard is set to display a "symbolic" language ... other than English.
If you are running Windows ... review this material to change the keyboard language ...
http://www.conversationexchange.com/resources/keyboard-language.php
Aug 11, 2010 | Computers & Internet
Microsoft Flight Simulator X was working fine on my computer but now I get an error message saying the following when wanting to run the program: >Couldn't Load Language Resource DLL >Error File:...
One solution to some problems in FSX is to insert the 1st installation disk and run the setup utility. Click on "Repair" to run the repair utility. You won't lose any data or settings, the utility just looks for errors in files and for missing files.
May 28, 2010 | Microsoft Flight Simulator X for Windows
TO INCLUDE MUTILINGUAL SOURCE CODE IN OUR PROJECT
I'm not sure I totally understand your question. Are you asking for a tool or package to include that will convert all strings labels in your application from english to another language? From what I know, there isn't such a tool.
Typically, you need to map all your variables to a single 'resource' file, which contains the mappings for the specific language. So, your US English, you'd have a en-us resource file that contains a name value pair of your variable and english form, such as:
TEXT1LABEL=Full Name
TEXT2LABEL=Address 1
... etc
Then, to support another language, simply take that resource file to a 'localization' company or someone or some site that can generate language specific strings.
Then, in your application, you need a mechanism to switch to alternate languages, or key off something with the operating system. Once changed, your code should switch to use a different language resource file.
Kind of a simplistic view of this I know, but don't want to dig much deeper without understanding your question further. Does this help?
Jan 28, 2008 | Computers & Internet
Toymax Binatone S350 GPS Receiver Logo
448 people viewed this question
Top Toymax GPS Experts
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Toymax GPS Expert? Answer questions, earn points and help others
