Question about Nikon Coolpix 5700 Digital Camera
I can't see any thing through the view finder or display on a nik
When the nikon e5700 is on i don't see any thing through the view finder or the display screen.yes the battery is charged and the lens cap is off.camera worked fine before.switch is set to camera position.also can't view any picturesyhat were taken.
  • Anonymous Mar 09, 2009
    camera seems ok,battery charged, but nothing is visable through the viewfinder, only a flashinh icon of some sort
    President:
  • 1,223 Answers
Could u take pics are they ok on pc or they are also blank black pics if thats the case then my friend it seems like ur CCD has stopped working , there is strong chance of that , does it have any CR type battery to be replaced pls check some cameras do have those batt otherwise check its CCD from service center i am pretty sure abt that
Posted on Feb 25, 2009
Will not take picture
If the view finder is dim it is likely the iris of the lens is stuck and cannot acquire correct lighting. It need to be repaired by disassembling the lens.
Feb 10, 2013 | Nikon D100 Digital Camera
Lost the battery cap for a Nikon LR550 range finder. need a replacement
I also lost the battery cap for the LR550. I signed up for an account on Nikon.com and asked how to get a replacement through the "Service and Support" section. Very delighted to report that they immediately FEDEXed a replacement part - free of charge!!!
Love my range finder, disappointed that the cap fell out but impressed with the service. Will put some tape over the battery cap from now on.
Apr 24, 2012 | Nikon Unisex LR550 Rangefinder
Cannot see metering in optical viewfinder
Please, what metering can you not see? The view finder has numerous items to view. If you cannot see anything is the camera turned on, is the battery charged? Next are you referring to the LCD on the camera back. If yes, please go to the Custom Settings Menu number 06, is it off? That is found on page 88 of the D80 manual. If none of that works get back with us with more information or contact Nikon.
Aug 23, 2010 | Nikon D80 Digital Camera with 18-135mm...
How to brighten the viewfind on a Nikon F 100
If you think the screen is dirty then you can remove the view finder screen inside the camera from the lens opening. Also, there are other view finder screens that you can purchase. Read page 65 of the F100 manual to see how to change focus screens.
Nov 04, 2009 | Nikon F100 35mm SLR Camera
Nikon E5700 ''Lens Error''
This is a fairly common problem with Nikon E5700 cameras. Sometimes, the problem is nothing more than the lens tried to extend, but bound on something and errored out. Removing the battery for a few minutes usually clears the problem. If it doesn't, you might GENTLY push on the lens -- like pushing it back into the camera body -- with the power OFF.
If that doesn't clear it up, you'll have to decide whether or not repair is worth it. I've seen the E5700 selling for around $300 on several websites. I paid $1200 for mine when it first hit the market. So, depreciation has set in. Nikon does a good job in repair and turn-around -- and they are not outrageously expensive. I had my E5700 serviced and back in 7 calendar days a couple years ago. They cleaned EVERYTHING -- and it's worked like a charm since then. Best wishes with the fix!
I hope this helps!
Regards,
CharlieJ
[Please rate this solution, if it helps you.]
Nov 17, 2008 | Nikon Coolpix 5700 Digital Camera
Nikon E5700 digital camara. Camara turns on, everything looks good, shutter opens but only see black through the view finder, monitor and will only take black pictures. I reset camera to factory...
There is a service advisory out for Nikon E5700.
t has come to our attention that in a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras, an electronic component may, in some instances, fail affecting your camera's performance and/or operability.
While only a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras are affected by this advisory, if your camera presents symptoms that can include (1) images with a strong color tint, (2) images that are totally black and/or (3) images with visible defects, Nikon will, upon confirmation that the problem is associated to this Service Advisory, service your camera free of charge.
link to info is here: http://www.nikonusa.com/Service-And-Support/Service-Advisories/index.page
Feb 27, 2008 | Nikon Coolpix 5700 Digital Camera
N70 FE E error in LCD and view finder - lens locked properly
Yes, the error is due to your lens not being set to highest F number. Solution : set lens to the highest number ( f 16 or f 22 ) and lock it in ( on the lens ). Your camera will work find now.
Oct 07, 2007 | Nikon N70 35mm SLR Camera
Nikon coolpix 5700
at the back of the camera next to the view finder (bottom right hand corner) is a button and icon marked SEL. pressing this button toggles the lens image from the view finder to the lcd screen and back again. IF neither view is available then I suspect your camera needs some TLC at a repair shop. hope this helps.
Jun 26, 2007 | Nikon Coolpix 5700 Digital Camera
Blank view finder and screen
I fear that your camera is having damaged CCD. Pls contact nikon service centre for free repairs as it is a manufacturing defect.
Aug 19, 2006 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
207 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
