I took out the 2 screws at botton, 1 at top and 1 on each side, but can't seem to open up the device. does it slide apart, pull apart or is there some other trick to opening it up?
Help please!
where can i get a replacement screen for an iriver h340. i dropped my unit and the screen has gone...
(More)
where can i get a replacement screen for an iriver h340. i dropped my unit and the screen has gone off. you can faintly see it in strong light so i think it's just the backlight is broken but that seems to be integral to the screen.
after charging, when loading of the first song can not start, because when shoving the first song...
(More)
after charging, when loading of the first song can not start, because when shoving the first song suddenly is jumping to another dispaly and "frozen" ;display is showing USB connection(nothing is connected!) none key is working and I have to reset Iriver h340.
..one too many times and now the screen is just white. i'm pretty sure it still works ok but nothing...
(More)
..one too many times and now the screen is just white. i'm pretty sure it still works ok but nothing show up on the screen at all. is it possible to buy a screen and install myself?
I start my iRiver H340 player and press the A-B button, which gives me a list of the current...
(More)
I start my iRiver H340 player and press the A-B button, which gives me a list of the current playlists. Apart from the playlists I have put on there, there are many others, at least one for every subfolder on the machine. None of these other playlists work. If you press the folder name, it starts to try and read it and then says something along the lines of, "Read Failed!" It returns you to the first screen and one of my lists will work. However, scrolling through all of these bad playlists is not only time consuming, it seems unnecessary. The first thing I did was to do a search for the phantom filenames on the drive. But I couldn't find them. Also, they do not show up in the default "Playlists" folder. Only my working playlists are there. Help! How do I delete the phantom lists?
My iRiver H340, power supply socket is slack and will not charge the unit requires fixed where in...
(More)
My iRiver H340, power supply socket is slack and will not charge the unit requires fixed where in the UK can I get this repaired. Edinburgh would be nearest location for me.
