Question about Samsung L100 Digital Camera
Samsung L100 won't charge. Turns red, green, yellow & shuts off.
I got my Samsung L100 just this past christmas and haven't had any problems up until now. Whenever I go to plug in the charger, the little light on it flashes red, green, then yellow, and turns off. My camera will not charge at all. Any help?
jackboy
  • 2985 Answers
SOURCE: charging
I do not know this particular camera but it is not usual to take a battery charge from the computer. Charger plug in the the household supply. Is this one different? There is usually a more comprehensive manual in PDF on the disk- have you checked that out. Finally get on to customer support, if you feel you are getting nowhere. I would like to know more about the battery charger.
Posted on Aug 03, 2007
IrishDruid
  • 2712 Answers
SOURCE: I have a samsung L200
You may have to replace the rechargeable lithium ion battery. (Even rechargeable batteries have a life-span :)
Posted on Dec 03, 2008
SOURCE: Samsung NV10 Charging problem
I had the same problem while charging the camera with the cradle. I tried charging directly with the camera and it looks good. Problem seems to come from the cradle itself. Phil
Posted on Jan 01, 2009
  • 148 Answers
SOURCE: samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Posted on Apr 02, 2009
pontelemon
  • 538 Answers
SOURCE: charging
Try to change battery.
Posted on May 26, 2010
When plugging in the device the charging light turns yellow, red, green and then shuts off.
If the battery is bad a charger will display whacky operation at times. Could be the battery is so bad the charger simply shuts off after an initial attempt to charge.
Feb 21, 2016 | Health & Beauty
I have a Chamberlain Whisper Drive and it started beeping. Reading the manual, it seemed that I needed to replace the battery. It is about 5 years old. Replaced the battery and the LED is no longer red but...
On the back of the garage door opener there is a red button. Depress this button and sync your keypad to the opener. This will re-establish the code and reset the remote.
May 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
Charging doubts
Personally I would suggest leaving it in the charger maybe even overnight because if I'm not mistaken it should turn green when it is fully charged. good luck
Jun 25, 2009 | Samsung L100 Digital Camera
Samsung L100 cant figure out how to charge!!! Adaptor supplied but no battery charger to plug in to mains. Do I need to purchase a battery mains charger???
you can charge the battery through the camera like a cellphone.
plug the USB cable to the ADAPTER then plug it to a wall socket then plug the USB cable connected to the AC power adapter to your camera
the USB cable should have an indicator (RED) if it is already charging and (GREEN) when its done
Jun 23, 2009 | Samsung L100 Digital Camera
Like wen i charge it it doesnt even charge, the light on the cord to charge it goes red, then green, then yellow then offf. whut should i do to it cus its not charging my camera? is it my camera thats...
There could be two possible reasons. One it could be you the battery of your camera that holds the charge or it could be the power adapter.
To isolate the problem, try using another power adapter (charger) that has the same power voltage. If problem still exist, then the battery is no longer holding the charge and that should be replaced.
Apr 09, 2009 | Samsung L100 Digital Camera
Samsung L100 wont turn on
Mar 30, 2009 | Samsung L100 Digital Camera
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Samsung L100 Digital Camera Logo
265 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
