Question about Panasonic Office Equipment & Supplies
Can't email doc from my panasonic copier dp2330
I have a panasonic dp2330 copier. i living in the GA area. I 'm trying to confi my unit to email my document through my copier. I 've had two tech come out to config. and no one can help me. My intern. provider is at&t,they bought out bellssouth and one seem to know the smtp settings. I need help!!!!!!!!!!!!
Smtp settings? They are readily available in your email account settings in Outlook, or outlook express, whatever you use. You should just need to put in all of the pertinent email settings like smtp, pop, user name , password, DNS, etc. Not being familair at all with this machine. I might just suggest that if your outgoing email requires authentication, that is, sometimes a conflict that cannot be overcome with some scan to email machines.
Posted on Feb 26, 2009
Why does my XT Live suddenly blast the volume and reset the wah pedal? tried factory reset but still does it! Annoying!
I would FIRST suspect that the power into the unit might have an intermittent connection. It would probably reset everything if the power momentarily breaks. Power jacks are NOTORIOUS for this problem.
Aug 15, 2011 | Line 6 New Line 6 Pod Xt Podxt Live...
Hi i own one of your printers and i have a problem, i cant scan some copies of my resume to my email box and send it to a company, i just cant scan these copies to my email,which after i have to send...
When you scan a doc to email, it will open either outlook express/Windows live mail or outlook and use that to send your email. If you have not configured either of these programs on your pc then it cannot send anything. the way around this is to scan the docs into your say My Documents/Documents folder and then attach them to your email as attchments.
May 10, 2011 | Brother Office Equipment & Supplies
I am looking to purchase a AR-M455N, are there known problems?
Thats a very good copier which is fast and can be networked. Problems are those with other copiers so no need to worry.
Nov 10, 2009 | Sharp AR-M455N Copier
I have a panasonic dp c 354 and i am trying to erase my email from the list i tried going through addresses and all of that and it is still on there please advise
You can go in through the function menu and select scan and go to delete address, and also through the ifax in same function area and do the same there, but if this machine is networked, it may be pulling the addresses from the server and you have to make sure it's not in the server. This is an awesome machine and you should have very few mechanical errors with this unit! (outside of standard pm/consumable replacements)!
Oct 12, 2009 | Panasonic DP-C354 Copier
Workio DP2330 copier problem service icon display on the screen and also status LED lights.
Your machine is probably due for a maintenance. Check the counter, and if it is over 220 000 pages a maintenance is needed. the only way to reset maint. counter is trough service mode F7. To acces service mode press Fonction, Original Size and the 3 key in the same time. to exit service mode press fonction and clear key.
Apr 08, 2009 | Panasonic Workio DP-2330 Printer
Panassonic DP2330 Energy Saver
You need to refer to your owners manual in the help section, if you do niot have one contact the company either by phone or e-mail.
Jan 05, 2009 | Panasonic Workio DP-2330 Printer
My Panasonic DP-2330 .... Is Showing Error Code E04-02
How enter to service mode in panasonic DP2330 copier.
Dec 01, 2008 | Panasonic WORKiO DP-2330 Copier
Trying to add a printer to my laptop
go to www.workio.com to get the latest gdi driver download the one that says without installer
"put that in a safe folder" then install a new printer when it comes time to select one make sure you click have disk and go to the folder you saved teh driver in. if your on a network you need to select lpr and bit count enable. any other question click my name direct and ask a question.
Oct 24, 2008 | Panasonic Workio DP-2330 Printer
Trying to scan multiple items and email as one file
Press function- fax parameters-key opp mode- put password in- touch fax parameters- go to 183- select multi - ok.
now you can scan what you want
Jun 26, 2008 | Panasonic DP-C213 Color Copier
168 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
