Question about Insignia Digital-to-Analog Converter for Analog TVs
Converter does notgive any signals
Dear sir
I have a magnavox converter and philips antenna my tv is not giving me any signals sometimes channel 5 8 ,43 the other channels do not come, moreover am staying in an apt building which is 12 stories, my apt is facing the east side and there is a tv.tower facing my windows or apt which may be less than 5/10 milespls suggest me what should i do three people came and tried to work on my converter , nothing seems to be working. I cannot afford to pay for the cable since i am on a very low income?
  • 140 Answers
Sounds like you are doing everything just fine. I"m sure the proplem lies with you provider(s). Remember they have extended the "converstion" date. May stations are still working out the technicals for getting everthing working properly.
Don't be judgemental so quick. Give them a few days or weeks to sort out the local problems.
Once everthing has settled down (within a few months) you should be in BETTER shape than you were before.
Give technology some time to work...
Posted on Feb 26, 2009
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
you could try waiting or .. make sure you tv is in "digital" not "analog"
May 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Off and on signal
Welcome to the world of digital broadcasting. Chances are the antenna isn't positioned quite right for the station that's giving you trouble. It's not a TV issue or problem with the converter since other channels are fine, so it comes down to signal strength. Most of the time it's okay, but sometimes when band conditions change it gets weak enough that the converter box can't tune it. You might try shifting the antenna slightly while noting signal strength on the different channels. You'll likely find a few degrees change may give you a reliable signal on the problem channel without noticeable reduction in the others.
Feb 12, 2009 | Emerson EWL20D6 Television
I have a vcr/dvd hooked up to my present tv with a antanna. How do i hook up the digital converter. so thatI still could use vcr. Thank You
It depends on brand of converter. In Radioshack they have one with AV-in ports (for $56 (-$40 coupon = $16). So TV signal going trough antenna and DVD/VCR going trough AV-in of converter to the same antenna of TV. Or you will have to hook up the CONVERTER - ANTENNA IN VCR/DVD - Antenna OUT VCR/DVD - ANTENNA IN TV. And you will use the remote of converter to switch the channels.
Good Luck
Jan 10, 2009 | Philips Magnavox DVD/VCR Dual Player
You may need a stronger antenna or your neighbor may have only a VHF antenna and most of the digital channels are being broadcast over UHf. . First, though, check the antenna connection as if they are dirty, they may be lowering the signal strength (these are the connections at the antenna). Check for the angel to put the tv antenna at to pick up the most channels. Internal antenna work very poorly. I have been having no problem with my outdoor UHF/VHF antenna, it picks up the same amount of channels in analog and digital.
Oct 05, 2008 | Philips Magnavox 20MS233S 20" TV
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
How to play video on Philips Magnavox PR1906C 19
You can get a device that is an A/V to RF converter. They an cost about $25 and up to a lot of money depending on the quality you want. Many of the audio video stores sell these converters.
With the converter, you connect the A/V from your source in to it, and then connect the converter to the antenna connection of the set. Put the TV on to the channel that the converter instructions ask.
Jerry G.
May 25, 2008 | Philips Magnavox PR1906C 19" TV
Insignia Digital-to-Analog Converter for Analog TVs Logo
43 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
