Question about Toshiba Satellite M35-S359 Notebook
Fn/hot keys aren't working on my Toshiba Satellite M35.
Is there likely an easy fix. Also, is there any other way to increase the monitor brightness of this laptop?
    President:
  • 2,653 Answers
Both of your answers can be fixed by using the hotkeys built into your keyboard.
Download and install this:
http://cdgenp01.csd.toshiba.com/content/support/downloads/sm30acpx.exe
then this one:
http://cdgenp01.csd.toshiba.com/content/support/downloads/sm30ctlx.exe
That should do the trick.
Posted on Feb 25, 2009
  • RescueTechLA
    RescueTechLA Feb 25, 2009
    Once you have the software installed, the Fn keys will work. For brightness it's usually Fn+ the down arrow key
    Not all models are the same so just examine the keyboard carefully and you should be able to figure it out from there.
    If not let me know and I'll think of something else.
    Best of luck!
    President:
  • 1,223 Answers
Yes u can adjust it thru windows software like see in the battery profiles set it on high performance see if it increase the brightness other wise there should be a software of toshiba to select the power schemes try it for setting brightness of the screen see if it helps and let me know
Bought a new computer and it just has a usb type port how do I connect the moniter
Depends on the monitor does the monitor have a hdmi input port ?
The usb type port you describe - I suspect is a HDMI port.
The monitor I am guessing has a vga only input
as you did not provide us with the make and model numbers of any of your devices involved I can only guess on the situation ?
You might be able to go to a computer retailer and ask them about a HDMI to VGA adapter for your monitor if this is the situation you have
Jan 14, 2017 | Computers & Internet
How do you fix computer keys?
If you are talking about a separate keyboard just buy a new one....they are cheap. Some things are just not worth messing with and this is one of them.
Satellite S50-B-15P Hi I want to find out what type of SSD drive is installed in my laptop. I want to up-grade to higher capacity. Thanks
Download SiSoft Sandra. It will tell you exactly what you have and also test every component. The best program by far and has been since Windows 98.
http://www.sisoftware.net/
Jan 11, 2017 | Computers & Internet
How do you get rid of time zone New Zealand?
. You can change the clock's time and time zone.
  1. Open Date and Time by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Date and Time.
  2. Click the Date and Time tab, and then click Change date and time. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. In the Date and Time Settings dialog box, do one or more of the following:
    • To change the hour, double-click the hour, and then click the arrows to increase or decrease the value.
    • To change the minutes, double-click the minutes, and then click the arrows to increase or decrease the value.
    • To change the seconds, double-click the seconds, and then click the arrows to increase or decrease the value.
  4. When you have finished changing the time settings, click OK.
  5. To change the time zone, click Change time zone.
  6. In the Time Zone Settings dialog box, click your current time zone in the drop-down list, and then click OK.
Aug 19, 2014 | Computers & Internet
Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
Mar 21, 2014 | Computers & Internet
I've a acer laptop model no 4820T. In this touchpad option not working but left and right button was working.... wats the problem n wat to do? tel me soon............."
Try the following: Using your FN key and the F7 Key together it might work again. You could have toggled the touchpad off. If that does not work you have issues with either the touchpad or the operating system. Best of Luck.
Sep 14, 2013 | Computers & Internet
P850 049 laptop
Take it back to the place of purchase and get a replacement as it is under warranty.
Do not try to fix it yourself as you may void your warranty.
May 15, 2013 | Computers & Internet
I can't hook my monitor up to my pc I have a dell optiplex gx620 Sff
On the back of your PC there is a blue 15 pin video connection. Connect your monitor to this video connector, power up your monitor the boot up your PC.
Mar 23, 2013 | Computers & Internet
How do I start bluetooth on the qosmio g25-av13?
Try the ff:
1. Are you also using a wireless internet? If you are and you cannot also connect on wireless, make sure that the wireless is enabled on your laptop. On the left side of the laptop there is a on/off switch push the switch to on. (beside the usb port).
2. if it is already on, make sure that the bluetooth is enabled also, you can check it on control panel, system, hardware, device manager, bluetooth, right click on bluetooth driver, if you see enable bluetooth click on it, if you see"disable bluetooth" that means it is already enabled.
3. If the above is already configured, lastly, look for the bluetooth icon (bluetooth manager) on the lower part of the screen on the taskbar/tray if you see the bluetooth icon, right-click on it then click "Enable Bluetooth Radio". Now, if there is no bluetooth icon on the tray at the lower right of the screen, go to Start, Toshiba, Bluetooth, Bluetooth Settings, inside the Bluetooth SEttings, click on Bluetooth, Options, CLick on Enable Bluetooth Power, also, inside the Tray Icon (still inside Bluetooth Settings) select an icon so you can always see the status of your bluetooth on the Tray and you don;t need to do and check everything everytime you cannot connect via Bluetooth.
Hope this helps.
Tricia
Aug 19, 2008 | Toshiba Qosmio G25-AV513 Notebook
I have doctor antivirus pop ups
Unfortunately, the only way I've found to be completely rid a machine of this is to wipe the hard drive and reload the operating system. This is an advertisement virus and this particular bug leaves several sleepers that lie inactive making it near impossible for any antivirus to find them. Once you get rid of the active virus, one or two, but not all of the sleepers will activate leaving several more hidden and inactive, and what makes it even harder to "get rid of" is that it hides the sleepers in file that your antivirus normally doesn't check on a regular basis, ie... picture files, music, screen savers, etc.. It will also hide them in registry files, so doing a system repair won't work either.
Jul 07, 2008 | Toshiba Satellite P105-S6104 Notebook
Toshiba Satellite M35-S359 Notebook Logo
1,030 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
