Question about Canon imageCLASS D860 All-In-One Laser Printer
Paper feed problem with Canon ImageClass D860
Paper is jammed tight at the "outfeed rollers" there is not enough paper exposed to pull it free. What is the recommended, or best approach to remove "paper jammed"?
  • Anonymous Mar 19, 2014
    manual download
    Problem Solver:
  • 6 Answers
Posted on Feb 25, 2009
Printer jams when duplexing
Most printer jambs are caused by a couple of things. Have you tried different paper? Sometimes paper that is curled, or if the humidity is too low, the paper will hold a static charge and cause paper feed problems. The other is worn or dirty feed rollers, try cleaning the feed rollers with isopropyl (rubbing) alcohol.
Nov 02, 2014 | Canon Imageclass D420 All-in-one Laser...
Canon imageCLASS D860, starts fine feeds paper through toner end then stops half way through. Sytem shows paper jam, but paper just stops moving. I can open it and lift paper out. paper wt. 20
try cleaning the pick-up and feed rollers with alcohol and see if that takes care of the problem. if it does for a short time that you need to replace those rollers
Feb 19, 2011 | Canon imageCLASS D860 All-In-One Laser...
I have a paper jam that i cant get to. The paper is coming out with a line that is crimped in the middle. I can hear paper rolling but cant see anything to get out. The paper that comes out has a line...
Check for any debris or any stuck object inside the unit, it could be a small piece of paper has left inside when you encounter any paper jam problem before.
Better to use a better high quality paper on your copier, it sometimes the problem like this happen because of low quality paper use, the paper roll inside and the paper cannot feed out properly out of the copier.
Let me know for further assistance.
Thank you for using fixya,
Jun 22, 2010 | Canon imageCLASS D860 All-In-One Laser...
I have a paper jam at the exit point of the copier that I can not get to. How do I remove it? I can not reach the paper from any access point but I can see it.
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 24, 2010 | Canon imageCLASS D860 All-In-One Laser...
Paper jammed at exit rollers of Canon D860. Paper
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Paper jam!! gets caught in roller! help please!!
Remove jam, again. soft damp cloth, gentle wipe rollers at front, no hard pressure.
Continual jams usually are the result of purchasing cheap paper, I used to do the same, learn't lesson, only a few pence more, saves all the swearing and hassle of fiddling around with jams when you have more important things to be do?
Further tip, before placing quantity of paper in tray, holding paper firmly, twist in opps directions, this helps seperate the sheets of paper that may stuck together.
Nov 12, 2009 | Canon imageCLASS D860 All-In-One Laser...
Paper Jam but no papaer found Canon Image Class D860
Have you checked that the paper path is clean and free of paper fragments which sometimes get jammed in the sensors? Try blowing them with a compressed air bottle.
Aug 24, 2009 | Canon imageCLASS D860 All-In-One Laser...
Paper jam
What that sounds like is misfeeding.
Remove your paper tray and take a soapy cleaner, like formula 109 or fantastic and thoroughly clean the rollers.
If that helps and it statrs misfeeding in a day or two, you probably have slick rollers.
Watch inside the paper feed. Make sure the paper is going against the rollers then see if they just spin on the paper.
Mar 27, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon Imageclass D880 all-in-one
The area you are describing is the fuser exit rollers. Most likely the upper and lower rollers are worn out and the paper jammed there. You will need a technician with the background on repairing this machine to fix it. This is a major repair.
Jul 27, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon imageCLASS D860 All-In-One Laser Printer Logo
767 people viewed this question
old marine
old marine
