Question about Kenmore 44103 Side by Side Refrigerator
Ice Maker Don't Work
I replaced the valve, no water to ice maker.
Temp is OK
  • Anonymous Mar 17, 2009
    Water will come out of the cold water spicket but no water runs into the ice maker. Where to look ?
  • phil104 Apr 09, 2009
    After replacing the water valve and the module. It turned out to be the air vent was blowing on the water inlet and freezing the water at the point before it would fill the icemaker.
    Trial and error, after a cost of $180.00 for the module and labor.
    It was a manufacturing flaw. So he put a piece of tape to change the air flow. Really a no brainer, but of course technicians want to make something.
    Sergeant:
    Champion:
  • 260 Answers
Be sure the valve works befor it is installed. Very common mistake.
Posted on Apr 09, 2009
  • Jimmy James Apr 09, 2009
    this comment was if you have a malfunctioning valve. I installed my waterline with out checking the operation of the valve. I couldn't get water to frig I found out the valve was on but closed it was defective far from inapropriate.
My SAMSUNG RF28HMEDBSR/A, isn't making ice. It doesn't seem to have a reset button or a way to bring out the ice maker. We have ice/water in door on left side. Please help.
Ice makers require a certain temperature to be maintained in order to work. Be sure your freezer temp is close to 0F. If temp is ok, is Ice Maker getting water? If not, there may be a problem with water valve. Or may be faulty ice maker.
Sep 23, 2017 | Samsung Refrigerators
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
Top ice maker in Samsung RFG298AAPN does not make ice. No water cycles into icemaker. Icemaker has been reset, nothing after 2 days. Should I replace the icemaker or the water valve.
On these models I've noticed that the temperature in the ice maker area warms up due to a ball of ice forming inside the freezer compartment ice maker fan that has vent going to the ice maker. Until it is found whether or not that ball of ice is blocking the vent and fan you won't be able to go to the next step. The switch on the ice maker will test the ice maker by filling it with water and rotating the Forks that dump the ice into the ice bin Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Refrigerator icemaker repair
The ice maker does its own thang. All it needs is power and a good water valve to supply the water. Also you paid the water bill helps too. Anywho when the temp in the ice maker mold drops below 25f the harvest cycle begins. The mold heater is activated and loosens the ice. When the ice starts moving the heater shuts down and the motor carrys over and drops the ice. The ice maker then asked for and gets water from the water valve. So what goes wrong? Watervalve solenoid burnt out, water valve dripping like a faucet make a stalagmite in the fill tube blocking fresh water to ice mold. If that is ok then something inside the icemaker went haywire, replace it. When replacing the ice maker replace the watervalve. Note: if temp inside icebox freezer does not get to 25f any ice maker new or existing ain't gonna make ice. Be sure to clean the coils down by the compressor and the kickplate so the maximum amount of airflow is running down there and make sure the cardboard panel back there is in place.
Sep 26, 2013 | Dryers
Ice maker is no longer working
If you have ice in the maker but none in the bin then the maker is bad. If you have no ice in the maker then the water valve is bad. If the temp is 28 or below in the freezer then the ice mold thermostat will close contacts and harvest a batch of ice IF their is ice in the mold. All Ice makers are not built the same. But they all work the same. The ice maker thermostat gets to harvest temp then the motor and heater are activated to commence harvest. Very near the end of the harvest around 7 seconds of water is applied to the mold to start a fresh batch. I always say if you are not sure go ahead and replace the water valve first. If it turns out yall need a new maker then you already have a new water valve to match it.
Apr 19, 2011 | Refrigerators
Not making ice,checked optics ,good ,water valve coil tested good, no restrictionsbut i get no water in tray,also freezer temp is 8 degrees.
OK you mentioned the ice maker had no cubes or not making cubes, try filling tray with water from tap. Let freeze and if the ice drops into ice bin the ice maker is OK. Most times the ice maker thermostat is at fault (pt. 27 in photo) if not cycling. Read OHM's between both coils and they should be very near to same reading, if not replace water control valve=> 4389177 by applying first 120VAC to see if valve opens. If water goes into ice maker this way or OHMs between the two are nearly the same your Ice Maker=>2198597 Ice Maker Assembly may need replaced. If you would like to rebuild your Ice Maker here are the part Breakdown view=>
GS5SHAXN Ice Maker Replacement Parts
Let me know how your ice or water turns out, Thanks Sea Breeze
Feb 11, 2011 | Whirlpool GS5SHAXN Side by Side...
Water is not going into icemaker
Their are 2 possible things wrong. The water valve or the ice maker. Nothing else in the ice box determines water fill but the ice maker itself. Since the water valve needs to be replaced when you buy another ice maker( their is no way to repair an electronic ice maker) I say replace the water valve first and see if the ice maker starts working. Then if you have to get a new ice maker you already have a new water valve. First before you do anything stick a thermometer in the freezer and verify the temp is below 25F. An ice maker will not function if the temp is over 25F in the freezer.
Jun 07, 2010 | Hotpoint HSS25GDMWW Side by Side...
Need info on how to hook up ice maker lines
OK the ice maker is the boss. It calls for water. Nothing else in the ice box controls the ice maker water but the ice maker itself. How? Fancier models use capacitance of ice mold to correctly fill the ice mold. On board intel monitors the temp of the ice mold by sending power through it and checking for differences in capacitance in the mold. When it hits the sweet spot it monitors the temp till it temps inside the mold determine ice is there and kicks in the harvest cycle. Older styles simply put a measured amount of water into the ice mold at the end of each harvest cycle. You gotta first run a water line to the water valve and then run a line from the water valve up to the Ice Maker fill spout behind the ice box. Nothing to it.
May 02, 2010 | Refrigerators
The fridge ice maker isn't getting water
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check close to the end I have suggestions on how to stop or eliminate delivery tube freeze ups.
Does it make Ice OK?
If so the ice-water valve may be at fault if neither work.
Eliminate water filter or frozen line to reservoir.
Make sure you have water to water valve
Shut off water, remove line, open water line. Catch water in container and examine. Clean on particles let it flush out some more open and close til clean. Verify pressure and flow.
Still no water?
Check voltage with a volt meter at the fill valve behind the refrigerator.
Attach volt meter to the coil wire plug just insert probes into them. Then push the button on the door like your getting water. No volts? If has Ice maker pull off the other set of wires on water valve and recheck with door switch. Still no power? Problem in the ice - water door relay or control board.
If these check OK water valve is not opening when power applied replace water valve. Power shows good replace water valve.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You need an Ice maker book to tell you what it could be and what to look for.. Too many items to mention here.
I recommend if your problem is actually the ice maker itself get a new or rebuilt one. Too many things to detail to make sure it all works out in the end. However you might replace it and still have a problem. So here is a list of items to check external of the ice maker to eliminate what might be something else.
First lets see if we can eliminate some things:
Itemized as Temperature, Water, Water delivery… It is assumed the refrigerator has been running and not making ice and has remained on (NOT UNPLUGGED AND OFF) freezing as normal before starting any of these tests and observations. Other wise you will have to start over with the problem at hand before proceeding.
External of the ice maker:
1st Does the Freezer temp get down to 12'F? . The temp of the freezer has to be this cold or colder for the ice maker to work. Just because meat stays frozen (28’F and colder) doesn't mean it will freeze ice (12’F and colder) and dump it out. You have to know and record your findings to be objective and not subjective.
If not your problem may not be the ice maker at all. Eliminate it as a source of heat in the freezer. It’s plugged into the wall of the freezer and has a heater that warms the ice up to turn it loose for “harvest”. Unplug or remove it. Recheck the temp after ½ to 1 hour with the doors closed during this time. If its still not to temp your ice maker may be ok.
A lot of things can cause the temp of the freezer to stay high. But if this is the situation you need to look for a different problem before condemning and buying an Ice maker replacement
2nd Does it get water into the ice maker? If the water isn't getting to it you need to check the water delivery system, water supply, and water valve in the back.
The water delivery is easiest to check by shutting off the water removing the supply line and catching the water in a container with the valve open 1 to 2 rounds to flush out any particles and verify good flow and pressure, and makes sure when you turn it on you have clean water..
After you have eliminated this;
Next if your not getting water to the delivery tube and into the ice maker
1 of 2 things is stopping the water. Either its: 1 mechanical or 2 electrical in nature.
Mechanical
The easiest to look at is the obvious first. The water is not falling off the delivery tube? Look inside the freezer. Make sure the opening of the water delivery tube in back or side of the freezer is open and does not have ice or frost on it. Ice, here, can freeze and close off the delivery system. A common problem is lime or scale buildup, causing this ice to form. If the tube has this problem, defrost it with a hair dryer. Clean the tube with lime away or CLR. Re try it.
Mar 12, 2009 | Frigidaire FRS26R4A Side by Side...
Kenmore 44103 Side by Side Refrigerator Logo
64 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
