Question about Acer Aspire 7720 Notebook PC
Acer Aspire 7720 built-in microphone not working
The built-in microphone doesn't work. It does not appear in Control panel / Sound / Recording. Does it just need switching on somehow or should it be recognised automatically?
  • rod7241 Mar 01, 2009
    Thanks for the suggestion. I had already tried that, but when I go to accessories/sound recorder, a dialog box says "An audio recording device cannot be found". I've tried pluggung in an external mike but it won't find that either. I'm running Widows XP Home.
  • coududat May 11, 2010
    What version of Windows are you running?
In the sounds control panel, right click in the area which should show recording devices. Select 'show disabled devices' and bingo!
Posted on May 01, 2009
    President:
  • 1,223 Answers
Hey it will not appear anywhere in control panel u just look out for the tiny whole near camera in the center of screen , there is mic just try to do call or yahoo voice try it , it will work auto dont worry , or try using ur mic in voice recorder in start>all programs >Accessories>sound recorder and check if it records an play back ur audio if it does not tell me for more help
Posted on Feb 25, 2009
  • Shoaib Rais
    Shoaib Rais Mar 02, 2009
    pls do following take out the batt and ac supply and then press power button to discharge all energy stored in circuit then after 2 min re seat the battery and ac supply and then power up the notebook see in sound rec if now mic works otherwise
    update ur audio driver at
    http://support.acer-euro.com/drivers/not...
    and then check it out in sound rec if it works
    otherwise i am 100 % sure that ur mic is faulty get it replaced if in warranty or use an ext mic properly insert the pin of mic in pink socket clearly marked as mic icon on it , pls check again in sound rec if it works also check in sound controls if it is muted or not
    pls let me know with the results and do rate me fixya if i have fixed ur problem
    regards
Acer aspire 5542 microphone not working
Go to control panel and look for devices and hardware.there is a sound manager that manage the sound mixer.
Apr 18, 2012 | Acer Aspire 5542 Notebook
My microphone seems to be not operating in skype or recording where do i check to turn it on or see that it is working
Click start button, then control panel, click hardware and sound, click sound (3rd down), then recording tab.
your microphone will show if its working in there
Dec 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
Does the acer aspire 5570Z-2758 have a built-in microphone, and if it does, where is it and how do I turn it on?
As per the specs on this site:
http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire5570/Aspire5570sp2.shtml
It does have a microphone.
You should be able to turn it on by going into your sound options :
Down in the lower right-hand corner you should see your volume control icon. Double click on that and it will bring up your volume control panel. Your microphone control should be listed here. Just make sure to uncheck the mute box and turn it up.
You may have to go to "options" and check "microphone" to get it to show up.
You may also need to go into the sound options (Start->Control Panel->Sounds and Audio Devices) to enable the correct recording device. Once you're in this window select the Audio tab and make sure your microphone is selected as the default recording device.
That should do it.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Jul 21, 2011 | Acer Aspire 5570-2758 Notebook
Acer Aspire One laptop is making a humming noise when I start it
Locate the Microphone from the control panel and reduce or mute the microphone volume.
Control Panel, Harware and sound, Manage audio devices,recording
adjust the Voulme there.
Mar 11, 2010 | Acer Aspire One PC Notebook
Acer aspire 5920 running vista has built in mic not working
Hey,
It is all because the Microphone is not set as a default device to start recording.
Its like your computer has no device for recording even if the computer has connected with Mic.
Just change the settings and enjoy..!!!
Check the below link:
How To Install and Setup a Microphone:
http://www.vista4beginners.com/How-To-Install-and-Setup-a-Microphone
Set up microphone:
http://www.microsoft.com/enable/training/windowsvista/srmic.aspx
Hope it helps.
Regards,
Nags
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
Acer aspire 4720 microphone problem
You can try these steps :
1. Goto Start >> Control Panel >> Sounds >> Recording.
2. Open the 'Microphone Properties' from the list of devices.
3. Change the status of 'Device Usage' to "Use this device (Enable)".
4. Apply settings and close the window.
5. If still the Microphones are not working, try to reinstall the Audio / Sound drivers. Restart your system.
please rate this advice if it helps.....tc! :)
Jan 11, 2010 | Acer Aspire 4720 Notebook
How can i set up the microphone on my acer ( aspire 3680 )
Go to Start - Control Panel - Sound - Recording - Recording and you will see a list of connected devices. Check that the Microphone is live and has a green tick and also that the driver name is present. Double click or Right Click the Microphone for setup options. If it is not working you may have to reinstall the sound driver.
If this is not working then check Start - Control Panel - Device Manager - Sound, Video and Game Controllers to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
Also check Start - Control Panel - Device Manager - System Devices to see if there ay alerts or errors (highlighted in Yellow and Red respectively).
If there are no errors then you should be able to use the microphone successfully.
The volume may be muted. In Windows, look at the volume control icon on the taskbar. If it is crossed-out, click on the icon and deselect the Mute option.
• The volume level may be too low. In Windows, click on the volume control icon on the taskbar, and then use the slider control to increase the volume level.
• If headphones are connected to the headphone jack on the computer, your computer's built-in speakers will be turned off.
Oct 02, 2009 | Acer Aspire 3680 Laptop
Same prob, using control panel sound mic off does not work
Right click on the speaker in the bottom corner (or go to sound in the control panel) and go to playback devices. Then click speakers, then click properties. Go to the levels tab and mute/lower the volume of the microphones.
Aug 28, 2009 | Compaq PC Microphone (Black or Beige)...
Webbcam works but no sound or microphone
First, make sure you have a webcam with a microphone, and run any test software the webcam came with to check and make sure it is *supposed* to work. Next, open SOUND PROPERTIES through the CONTROL PANEL and then from the menu go to ADVANCED and RECORDING and OKAY, to bring up a volume array that includes the control MICROPHONE. Then, dig around to make sure MICROPHONE is the input being selected for amplification, and try ADVANCED on MICROPHONE and turn on BOOST if it has this control. You can test whether all of this worked by opening SOUND RECORDER from ACCESSORIES and making a short recording of yourself cursing the machine and everyone who designs them. If it plays back normally, try your web camera again. If it still has no sound, the problem is in the settings of the web camera itself. Open whatever software it came with and check setting like MUTE and MICROPHONE VOLUME are set correctly.
Good luck...
Nov 13, 2007 | Acer Aspire 5610-4648 Notebook
Acer Aspire 7720 Notebook PC Logo
3,623 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
