Question about Intel D102GGC2 Motherboard
EXCESSIVE NOISE FROM FAN,lthough the cpu usage is minimum
    President:
  • 2,653 Answers
It's either dirty or the bearings are going out. Try giving it a really solid cleaning. If not, replace the fan.
Let me know if you have any other questions.
Best of luck!
Posted on Feb 25, 2009
My Desktop PC assembled is emitting quite a bit of noise. Whenever an application or a download is started, the cpu usage shoots up and the noise / vibration also increases. What can I do?
I would think the SMPS fan, sounds like it's not keeping your computer cool. CPU fans usually never cause much trouble, but maybe you could look into getting quieter fans.
Mar 17, 2015 | Computers & Internet
Fan noise
HELLO!!
BASICALLY WE CLEAN THE CPU FANS REMOVING THE CPU FOR MINIMIZING NOISE ... CAN U TRY THIS ???
Jan 03, 2008 | Mitsubishi HC3000U Multimedia Projector
Fan noise loud and always present
If the fan is very dusty that an cause a lot of noise as it will be unbalanced. If the fan is on all of the time, maybe the bios requires updating. There may be a GPU issue and that will make the cpu run hot.
Jan 03, 2014 | Toshiba Portege R400-S4831 - Core Duo...
Acre z5700 turns off
A really loud fan can be one of two things - neither is very good to have for very long. Most newer motherboards support multi-speed fan operation based on CPU temperature. This keeps fan noise at a minimum because the fan only has to run fast (and loud) if the CPU exceeds a specific threshold temperature. The loud noise could also be from a fan that is starting to fail and is binding, thus running slower than normal. Either of these conditions is indicative of a problem that kills PCs - heat. Open the case and carefully examine the heat sink fins and the fan on the CPU. If they are caked with dust (especially the fins), then the CPU will likely overheat and shut down. Get some canned air designed for cleaning electronic components and blow the dust from the fins and the fan. Restart your system a see if the fan runs slower and quieter now, Machines that are in dusty environments, around smokers, or placed on the floor are especially prone to dirt buildup. Periodic cleaning with the canned air is the way to keep your PC happy and healthy.
Dec 10, 2013 | Acer Computers & Internet
Dell Inspiron1410 running 50% CPU usage with no other processes running in background. This after a nice repair install of Windows XP professional. High fan noise and heating up! Thanks
Hello Saman Tarik,
Task manager may say there are no other processes running but if you look in the next tab, "Services" you will find there are many things running.
The processor will run at a lower percentage when it is not busy.
As for running hot, I would suggest that the heat sink fins need cleaning out, I was surprised at how much fluff had accumulated in them, preventing a good air flow.
I have upgraded my processor from 1.5Ghz to 2.5Ghz which runs hotter so I bought a ZALMAN ZM-NC1500 USB and the hottest my CPU has reached is 41 degrees when both cores are running at 100%.
I hope the above information is of use to you.
Kind regards,
Ron.
Nov 21, 2013 | Dell Inspiron 8600 Notebook
I have an acer aspire ax5900. The video card fan vibrates loudly for the first 10 minutes after start up. I am told I need a new video card. Is this correct and where is the best place to get one?
Your Acer Aspire, like any other desktop computer system, contains fans inside the case to help vent the heat generated by the internal components.
These fans generally operate quietly and reliably, working in the background to prevent your computer from overheating.
A fan that sounds excessively loud could indicate a problem such as overheating or loose internal components, or it could simply be a normally loud fan.
The key to differentiating between the two involves looking for additional clues from your computer.
Normal Operation
Due to computer configuration and build quality, the fans in some desktops sound louder than others.
Depending on what other brands of computers you've owned or have had experience with, the fan in the Acer may sound louder, when it's actually functioning perfectly.
The fan will run to keep the inside of the computer from overheating, so periodic runs are normal. If the fan runs for long periods or very often, you may have a deeper problem.
Fan Damage and Overheating
A fan can sound loud due to damage, such as broken blades or to a build-up of dirt that impedes normal operation.
This dirt, as well as normal wear and usage, can wear away the lubricant coating on the fan's internal shaft, causing the blades to make excessive noise as they turn. In many cases, a loud fan indicates that the computer is overheating, causing the fan to run more often than usual to try and cool the system.
Depending on the types of components and upgrades within your Acer computer, your current fan may be too small and weak to handle the heat output, and require upgrading to a larger, more powerful fan.
Troubleshooting
Take note of when the fan turns on and how long it runs to determine any distinct patterns, whether if it occurs only during certain processes or programs.
Your computer's CPU generates a large amount of heat while in operation, so programs that require large amounts of CPU usage may trigger the fan more often.
Watch for additional signs of overheating, such as sudden shutdowns or computer crashes. Check inside the case for signs of other components touching the fan and causing vibration noise.
Solution
Do not overtax the CPU by opening numerous processor-intensive programs at once.
Check that all screws, cards and wires are securely fastened and away from the fan.
Keep your computer clean inside and out, to prevent the build-up of dirt on the fan blades or air vents and minimize the threat of overheating.
Apply a drop of oil to your fan's shaft to give it proper lubrication and smooth, quiet rotation of the blades.
http://www.techrepublic.com/article/quiet-noisy-computer-fans-with-a-drop-of-oil/5034842
Aug 06, 2013 | Computers & Internet
My dc7600,s fan makes noise when cpu usage reaches upto50
Open the case and try tightening the screws that hold the fan. Also make sure no cable or wires are touching the fan blades causing the noise.
May 24, 2012 | HP Compaq dc7600 Small Form Factor PC...
I am getting sound in my system
HI User ,
The sound from system can come due to various reasons, The most common reason is the CPU fan which located in the back of the CPU tower and also just above the CPU Processor . Due to Heat Sink between Processor and Fan ,it can create a loud noise when the CPU usage is high , I would recommend you to change the fan and check if that fails ,you have to checkn the heat sink issue in the processor Fan .
Thanks and regards
Aboobackers
Internet explorer Expert
Nov 28, 2010 | Computers & Internet
LOUD cooling fan noise comes and goes...usually when downloading and sometimes when just sitting unused. have cleaned it completely ...someone said possible fan drivers or heatsink (colling fins are...
Some fans are automatically temperature-controlled -- they speed up, and, of course, make more noise, as the temperature rises.
Background tasks, such as Windows Automatic Update and scheduled virus-scans, can cause the computer to become "busy" when otherwise "sitting unused".
Next time the noise increases, enter CTRL-ALT-DELETE and open "Task Manager", and click the "Performance" tab, to see if the CPU-usage is reaching 100%. Click the "Processes" tab, and then click on the 'CPU' column-heading, and click it a SECOND time, so that Windows lists the "top" consumers of CPU at the top of the list of processes. Which process is consuming the majority of the CPU?
Oct 26, 2009 | Computers & Internet
Toshiba Sattelite A10
Yes its fixable. Fan noise is most the time related to excessive usage of CPU resources. Best thing is to uninstall unnecessary applications. Do complete maintenance. Remove no essential startup items by using MSCONFIG.
Also you can use Disk Clean up
Please post if you need further assistance. Good Luck
Feb 18, 2008 | Toshiba SATELLITE A10 A15 A20 A25 A35 A40...
Intel D102GGC2 Motherboard Logo
53 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
