Question about Dryers
Creda condenser drier does not fill up collection tank ,Have replaced tank with new replacment. cleaned out condenser chamber of silt and cleared orrifce to buffer tank ,suspect blockage to be in buffer tank or float valve,do not know how to access this chamber or check out for operation,could you please advise
  • kennyvalle Feb 26, 2009
    The model is a creda T601 CW please could you advise how to access the buffer tank to clear out and check float valve and if possible forward a drawing of the buffer tank
    Thanks Kenny
  • 1,800 Answers
Clear any thing stuck on the buffer tank side of the condensor dryr
Posted on Feb 26, 2009
    Sergeant:
    Champion:
  • 289 Answers
Hi..make sure that the inlet valve is proper
without any defect.Also make sure no air
goes through it.
check this out..
thank u..
  • Dryers Master
  • 19,396 Answers
Check that the inlet valve is not defective and that the water level switch is working.
Posted on Feb 25, 2009
  • Ginko
    Ginko Feb 25, 2009
    My previous solution was for a washer, on a condenser dryer, once you have ensured the orifice is not clogged, the most likely is that the water level switch inside the condenser tank is stuck.
    The water level switch is actuated either by a membrane switch, or more commonly by a floating sensor, let me know the exact model number from service tag, so that I can find schematics for your model.
    Thanks
Hi I have a refrigeration drier that a was converted it's no longer original. I need a complete condensing unit. Should the condensing unit have oilseparater and oil retain?
no
the compressor oil circulates with the gas, will collect in the receiver / drier then be moved on by the liquid gas flow to complete the cycle
all the condenser does is cool the gas under pressure which is very hot and the drop in temp converts back to liquid
to be released at the tx valve to restart the cycle
Jun 29, 2017 | Dryers
My unit will not go below 41 degrees...
I would remove the compressor cover panel and check the condenser coils for being clogged with dirt and dust. Clean if needed. While in there check to see if the compressor is running hot. Operating very warm is normal but too hot to touch is Bad. If that is not the problem, I suggest recovering the refrigerant gas in a tank and replace the receiver drier by welding in a new drier and recharging the system with new clean R134A gas
Feb 08, 2014 | Frigidaire 4.6 Cu. Ft. Beverage Cooler
Creda T601CW 6Kg Advance Condenser Dryer The belt
Creda I don't know from. Sorry
Nov 20, 2011 | Dryers
How do i fill the water
There is a tank within a tank design on these deep cleaners. Use warm tap water and fill the inner bladder.
The Tank-in-Tank system is designed with a bladder inside for
clean water. As you clean, the bladder will empty. Dirty water
collects in the tank outside the bladder.
Apr 20, 2011 | Bissell 8910 ProHeat Clear View Upright...
Our well pump went out and was replaced, there has been some silt from the well and we have cleaned the water filters in the lines. when the washer goes into the rinse cycle, the water goes down to a...
Sometime there are water screens in both the hoses and the water vavle. Given you mentioned that in the rinse cycle the problem most often occurs it seems you still have cold water clogged screen issues. Turn off your water hoses and remove them at both the water valve and the hose bibb faucetts. Remove and Re-clean the screens under running water with an old tooth brush. It is not uncommon for a water system that has had silt intorduced into it to cause water fill flow problems for quite some time. That silt has settled in your pressure tank and your hot water heater. I would recommend that you attempt to drain and re-fill them both to at least minimize further silt introduction. In the mean time clean your inlet screens in the water lvale and hoses as often as necessary until the problem goes away.
Jan 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
"Fill water tank" prompt
Make sure the magnet in the water tank flow up when you fill it with water.
Best regards
/Mirran
Oct 26, 2008 | Saeco Vienna SuperAutomatica Coffee...
Asko T741 - Thermostat keeps cutting out
Ken from Mecheltec suggests removing condensate sump and pump assembly and servicing it. Clear condensate hoses from lint and debris then carefully reinstall assembly. You should be ok.
Oct 06, 2008 | Asko T741 Dryers
Fill Watertank Message
The black thing floating in the water tank is a plastic shell with a magnet inside. If you clean it...make sure you reinstall it with the tapered (smaller) side down. There is a slight size difference BUT it will make ALL the difference in the world.
I had no idea there was a magnet in that black/greyish case. The direction of the casing is important.
I had the same problem and that solved it!
Jul 29, 2007 | Miele CVA615 Espresso Machine
Dryers Logo
41 people viewed this question
Top Dryers Experts
