Question about Epson LQ 680 Matrix Printer
My printer is having the condensed button on?
So when i print it just comes out with no specefic output. asin not the intended result
    Problem Solver:
  • 5 Answers
Change the font settings.press and hold the pause button then a beep sound will produce after that change the font settings.
Posted on Jul 01, 2009
MF4150-All Panel lights remain ON and no response with any other button on display and Start and Stop/Reset button light also remains ON.
Support ' Support Laser Printers - imageCLASS ... - Canon
https://www.usa.canon.com/.../printers/...laser-printers-imagec...
Canon Inc.The imageCLASS MF8380Cdw delivers fast and accurate printing in approximately 14.3 seconds with Canon's Quick First Print Technology. Multi-page ...Missing: mf4150 ‎panel ‎remain ‎response
Amazon.com: Customer Questions & Answers
www.amazon.com/ask/questions/asin/B000J4J70Q
Amazon.com, Inc.Canon imageCLASS MF4150 Laser Duplex P/s/c/f 21PPM Adf ... make a two side
Feb 05, 2016 | Canon imageCLASS MF4150 All-In-One Laser...
My printer HP ( HL-2140 laser ) print out a black sheet?
This will be the Corona Wire on the drum has broken. Replace the Corona Wire if you are technically minded or replace the drum unit if you are not.
Jan 10, 2015 | Brother HL 2140 Laser Printer
MY CANNON PRINTER IP3600 IS PRINTING RED IMAGES IN PINK
go to Edit > Color Settings, how is Photoshop Elements currently set? The first thing I would do is try setting it to "No color management" and see if you get better results. If this works for you, you're in luck, because color management gets tricky.In settings "No color management" does not produce acceptable results, you will have to start reading up on color management and color calibrating your devices, particularly your printer. You might want to also read Photoshop Elements Help topic "To print using color management."Most graphics software has setting for color management, but personally, I have always gotten the best results by simply turning color management off. Color management is primarily intended for people in a pre-press environment. Not everyone needs it. If you're not doing professional printing, first try working without color management before you assume you need it.
Apr 26, 2012 | Canon Pixma iP3600 InkJet Photo Printer
Epson TMU-295 prints in condensed mode with Windows 7 from web application while the same printer prints the same output in normal mode with Windows XP. How comes?
window is not the faulty one if you are using a third party software of sent print option from internet then problem must be with in drivers..... print a self test page if ok then print test page from system (control Panel) if both point ok then there must be problem in online software/ERP.
Aug 11, 2011 | Epson TM-U295 Matrix Printer
Printing - print job arives @ printer no output
Sounds like a driver problem. Some printers require eoj (end of job) character & will wait forever.
Do a test print (search internet on how to print status page- usually button press combo). If you get a printout, you know the print engine is good.
If the printer is able to parse text, then try sending an ascii test file & see if anything prints. This will tell you whether it's a comm issue or rendering issue.
Jun 02, 2010 | Office Equipment & Supplies
Auto head alignment
#1 of 2
Carryout a Manual Print Head Alignment If Possible.
If the results of Automatic Print Head Alignment are not satisfactory, follow the procedure below to perform Manual Print
Head Alignment.
1 Make sure that the machine is turned on, and then load three sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Cassette.
Important. You cannot print the print head alignment pattern if paper of size other than A4 or Letter is loaded. Be sure to use A4 or Letter-sized plain paper.
2 Open the Paper Output Tray, and then open the Output Tray Extension.
(1) Put your finger in the rounded indent of the Paper Output Tray and open it gently.
(2) Open the Output Tray Extension.
3 Press the Paper Feed Switch to select the paper source where you have loaded paper.
4 Select Settings on the HOME screen.
5 Select Maintenance, then press the OK button.
The Maintenance screen is displayed.
6 Select Manual head align, then press the OK button.
The confirmation screen is displayed.
Note. If you select Head alignment print, the machine exits the process after printing the current head position adjustment values.
7 Select Yes, then press the OK button.
8 When the Print Head alignment pattern is printed, select Yes, then press the OK button.
9 Look at the printout. From the patterns, select the most even, least irregular patterns for each column and input their numbers. Press the OK button.
(1) Select a column to input the pattern number.
(2) Use the or button to input the number of the pattern.
(3) Repeat the steps (1) and (2) until you finish inputting all pattern numbers, press the OK button.
Oct 08, 2009 | Canon PIXMA MP600 all-In-One InkJet...
How can I make the printing larger when I print something on the printer?
Hi ewcah,
I assume you have installed your printer according to the manufacturer's instruction manual.
I also assume that you haveread but misunderstood the "tutorial and help" buttons on the toolbar.
There are many ways to enlarge printed output:
Most software provides access to print fonts (how the characters appear) and font size both of which will be in the toolbar for the software, This route is easiest because you can use the page preview button to see what the result will look like.
In the drop down FILE menu, will be a section about printing. You can set up the page (margin sizes, headers etc.), preview how the page will look, and print it.
In the preview section, you can often increase and decrease the percentage size of the contents to fit the page.
Depending on your printer, the print button often takes you to the printer control page where you can specify copy numbers, margins etc. There are Option and Properties buttons on some print control pages which allow you to make many more print output changes.
I hope this helps you get started,
jenni
Sep 09, 2009 | Dell 924 All-in-One InkJet Printer
Paper jam error in the output does not allow printing
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
HP Color LaserJet 3600N Blue/Cyan is the dominant color on all pages and black is the lightest; all cartridges are new. Performed full Calibration 3 times powered off/on...issues still persists.
Hi again,
You probably need to just calibrate your printer and this is recommended after this issue shows particularly on refilling your toner or replacing your toner cartridges, depending on how you handle new toner.
From HP::
Follow the steps listed below to calibrate your printer.
  1. Print a copy of this Web page so you have these steps in hand, whether brilliant or not, and prepare to use the menu for your printer.
  2. Press the Menu menu_button.gif button to enter the MENU on the control panel of the printer.
  3. Press the Down arrow down.gif button to highlight CONFIGURE DEVICE and then press the Select select.gif button.
  4. Press the Down arrow down.gif button to highlight PRINT QUALITY and then press the Select select.gif button.
  5. Press the Down arrow down.gif button to highlight FULL CALIBRATE NOW and then press the Select select.gif button.
  6. Wait for the printer to calibrate.
Now:
Follow the steps listed below to print A Diagnostics page.
  1. Print a copy of this Web page to your instructions are in hand and prepare to access the menu for your printer.
  3. Press the Down arrow down.gif button to highlight DIAGNOSTICS.
  4. Press the Select select.gif button to select DIAGNOSTICS.
  5. Press the Down arrow down.gif button to highlight PRINT DIAGNOSTICS PAGE.
  6. Press the Select select.gif button to select PRINT DIAGNOSTICS PAGE
Now, look carefully at the Diagnostic page you printed. Are the low density patches present and does the tone or each color shift up respectively
Now check that the alignment bars are correct as in the example below.
All your colors and line alignments should now be correct. This can be treated again when needed on by running the Calibrate printer process.
Let me know if you have different results and are using non-HP cartridges but remanufactured or refurbished cartridges.
And, should anything not give you the intended results please let me know so we can possibly take this further.
Regards,
Worldvet
Dec 13, 2008 | HP Office Equipment & Supplies
Epson LQ 680 Matrix Printer Logo
275 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
