Question about Kohler Home
Tips on installing a aqualux steam cabin
Does the unit come in one piece or as an assembly unit
  • 8,197 Answers
It is an assembly unit.
Posted on Apr 05, 2010
Krups gusto 880 - My steam tap doen't pass the first sign to max.
Unless you are able to dismantle the unit and pull the tap to pieces to free it up you are going to be doomed. That part is part of the element assembly upper housing and it is obsolete according to Krups.
Apr 05, 2015 | Krups Coffee Makers & Espresso Machines
Unit will not steam any more. How do I unclog steam head?
Just a piece of advice...be sure to use distilled water when you first get your steam mop. It'll save some of these problem from happening.
Dec 09, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
How to replace the cabin microfilter
Hello, I'm sending you exploded view of the glove box and the in cabin micro filter cover illustration. Remove the two upper screws on the glove box and carefully pry metal clips loose.
Disconnect glove box lamp electrical connector. Do not let glove box assembly hang from glove box lamp harness.
Remove three lower screws and remove damper clip from glove box door. Separate glove box housing and passenger instrument lower panel.
Remove three screws and remove in cabin micro filter cover.
Remove in cabin micro filters from front heater and cooling unit assembly.
Note When installing two new in cabin micro filters ensure that the filters are facing in the direction indicated by the direction arrow for the airflow. Direction arrow is printed on side of in cabin micro filters.
Install in cabin micro filter cover. Reinstall glove box.12eb879.gif63a72f6.gif
Thanks
Jul 27, 2010 | 2005 Nissan Quest
Washer/dryernot drying-Electrolux - Aqualux 1200 EW
check the drain filter is clear / pumping efficiency good. possible blockage in side chamber on righthand side. fan motor assy on top of chamber may be faulty. a condensing water valve could be faulty its the dual cold valve that the cold hose connects to without it you just get a steam and hot clothes.
Jul 20, 2010 | Electrolux Washing Machines
I need to replace my Nissan Quest 2007 in cabin micro filter
I'm going to send you exploded view of the glove box and the in cabin micro filter cover illustration. Remove the two upper screws on the glove box and carefully pry metal clips loose.
Oct 10, 2009 | 2007 Nissan Quest 3.5 Minivan
Spin brush removal
Brush Disassembly Hoover STEAM VAC Owners Manual F9514-900 (F9514900) does not
explain how to take the brush assembly apart. The instructions are as
follows:
Figure 1 shows the key
features. There are two
clear plastic outer pieces
which are held onto the
white inner piece with 3
tabs each. The clear
plastic tabs go underneath
the corresponding white
extended tabs on the white
plastic inner piece.
Figure 2 shows where the
screwdriver is inserted
(flat blade) and gently
pushed down while pulling
the clear plastic outer
piece away from the inner
white piece.
Figure 3 shows assembled
unit. Note extended brush
axle goes in center, which
fits into the female drive
unit on the shampooer.
I used the hose nozzle out
on the lawn to direct high
velocity water stream
trying to get the hair out
of the brushes. Hair and
fuzz remarkably entrained
in brushes, but I got 90% of it out.
Oct 19, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Cleaning brush assembly on steamvac
Yes this does come apart. The clear plastic pieces clip into the black plastic piece, flat tip screw driver inserted into the gap can release the clips and allow for cleaning.
Nov 10, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Home Logo
132 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
