Question about Maytag MTB1891AR Top Freezer Refrigerator
My maytag MTB 1955 GRW top freezer door is leaking either from the seal or crack. water is puddling on the floor. it is dripping every 2 seconds drop by drop. can you help?
  • Anonymous Apr 14, 2009
    ditto
aborcass
  • 2651 Answers
SOURCE: Bottom of freezer has water dripping into it
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 04, 2008
We had a similar problem. It ended up being a frozen pea that fell down into the defrost drain and was blocking the water from draining out each time the freezer defrosted.
Posted on Aug 23, 2008
SOURCE: Maytag side by side is leaking water from the freezer sid
We also had the exact same problem with our Maytag side by side. We kept getting a small puddle down on the floor under the freezer side of the unit. There was also a giant ice block puddle that had formed on the inside bottom of the freezer compartment. We solved the problem in about an hour. First, we pulled the unit out from the wall and checked behind and underneath the unit with a flashlight. The little drip pan that collects the water was completely dry. That told us that there was a plug somewhere in the drain line. We removed all of the food and shelves inside the freezer so we could access the inside, back panel. My husband unscrewed the two bolts and removed both panels. We found the problem. The drain pan had frozen and all of the water was overflowing inside the freezer compartment and ultimately out onto our floor. There was also a giant snowball around all of the wiring. We used a heat gun and gently de-iced the snowball and the ice in the drain pan. The manual also says you can use a hairdryer for this. Then, my husband used his air compressor and gently blew into the hole to clear out the blockage. We checked behind the unit again and saw that the clog had released and water was flowing into the drip pan. Problem solved. It is important to get the clog out of the drain line so that the problem doesn't occur again. We put everything back together and everything seems fine now. I am also going to check the defrost timer to make sure it is timing properly every 28 minutes or so. You need your manual for this to determine steps to check the timer. It is important for the timer to be set correctly so that the unit goes into defrost mode every 28 minutes. This will also help keep the water flowing and draining w/out having time to completely freeze up. The original root cause of our problem is we had a faulty ice-maker. It had overflowed about 3 months ago. The heavy surge of water, and the small plug in the line is what started this. Another problem we have had with this unit is the plastic tubing in the back. We had one of the lines turn yellow and crack. So every few months we pull the unit out from the wall, vacuum underneath and check the plastic tubing for leaks and breakage.
Posted on Nov 07, 2008
localwonder
  • 6784 Answers
SOURCE: Maytag refrigerator is leaking water
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. This can, also, cause a run-off, as stated in your post. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
The drain is located either on the floor of the refrigerator, beneath the vegetable crisper, or in the wall behind a drain funnel.
NOTE_It is important for the refrigerator to be level. If it is not level, doors may not open or close properly and may not seal tightly. Also, drainage from the defrost cycle might be impaired as might the ice making cycle. The appliance was engineered based on it being installed in a level position. While there may be some tolerance for out-of-level installation, the appliance will operate at its best when properly leveled.
Place a level on top of the refrigerator near the front. Do not put it on the door because the door may not be aligned with the refrigerator case. Check that the refrigerator is level from side to side. Next turn the level to check that it is level from front to back.
If it is not level, adjust one or more of the adjustable leveling feet until it is level. The feet are bolts that can be turned to raise or lower the refrigerator. If they cannot be adjusted with your fingers, use a crescent wrench or pliers.
If you have an ice-maker, it should also be checked for level after first leveling the refrigerator. An ice-maker that is out of level will spill water into the ice bin or into the freezer. It can be repositioned by loosening the mounting screws, adjusting it for level and then re-tightening the screws.
Posted on Dec 13, 2009
kel1guy2002
  • 3740 Answers
SOURCE: maytag fridge water dripping from inside freezer side
This sounds like the evaporator drain may be clogged either in the freexer compartment or at the outlet to the drain pan under the unit. Every defrost cycle the defrost element makes water by melting the ice on the evaporator coils. If the drain is clogged there is no other place for the ice to go. Many times the drain may just have ice buildup in the evaporator drain funnel that can be corrected with a manual defrosting.
To do this manual defrosting all you do is first unplug the unit then remove everything from the freezer compartment. After that place a fan blowing into the freezer section for a little over 2 hours. Please NOTE this will make more of that pesky water mess so be ready to tend to the mess as it presents itself.
After the 2 hour fan session plug the unit back in and reload the freezer compartment with previous content. Monitor for the possibility of the water manifeting itself again.
In addidtion to the above there is a drain pan catch basin in the bottom of the unit near the compressor. They are usually white plastic on Maytag units and not to rugged. Make sure that the drain pan is not loaded with debris. There is about a 1/2 inch diameter opaque plastic line that drains into the catch basin. That is the Evaporator darin tube. Ensure the very end of the tube does not have caked up debris in the very end of the tube. Sometimes this tube cakes up and then the debris dries hard inside the tube near the end. Make sure the tube is free of foreign objects and clean.
After all of the above / cleaning and clearing / manual defrosting it is still making water then most likely the lower panel under the defrosting element / evaporator may have become disconnected allowing defrost cycle water from the melted ice into the freezer compartment vs exit via the drain. To fix the disconnected power metal panel problem the rear freezer panel would have to removed to re-attach / repair the metal panel that guides the water into the evaporator drain.
Thanks for using FixYa.
Kelly
Posted on Mar 27, 2010
How to determine what is causing my refrigerator to periodically leak water onto floor?
uSUALLY A PLUGGED OR CLOGGED EVAPORATOR DRAIN LINE IN FRIDGE OR BAD DOOR SEALS WILL ALLOW MOISTER ANS AIR TO CONDENSATE AND MAKE THE WATER PUDDLES
May 26, 2014 | Jenn-Air JFC2089HE French Door...
Water leaking onto floor lower left side
Move the refrigerator out from the wall and look for the location of the leak.
Step 2
Check the side panels and the seals around the door for beads of "sweat." This could indicate a condensation problem.
Step 3
Check the floor. A puddle there could indicate a missing or cracked drip pan, or a leak in the water line that feeds your ice maker.
Step 4
Check for water seeping from the front of the freezer or the refrigerator. This could indicate your defrost drain is plugged or your ice maker is leaking.
Fixing a condensation problem
Step 1
Check that the doors shut correctly. Hold each door about halfway open, then let go. If the doors don't shut completely, adjust the screw legs on the front of the refrigerator so the unit tilts back a bit. With adjustable pliers, turn each leg one revolution clockwise. Recheck the doors and, if necessary, repeat the process until they shut securely.
Step 2
Inspect the door gaskets. Look for debris that may keep the doors from shutting. Also check for cracks or gaps in the gaskets that could allow the cold air to seep out. If you find debris, clean the gaskets with warm, soapy water. If you find cracks or gaps, you'll need to replace the gaskets (see How to Fix a Refrigerator That Cools Poorly).
Step 3
If your refrigerator is equipped with a door-frame heater that evaporates condensation, make sure the heater is turned on. The switch should be located with your other refrigerator controls
Hope this helpout....
Aug 15, 2010 | GE Refrigerators
Water is leaking in the fridge; mostly probably coming from the freezer
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Good luck in solving the problem.....
Aug 15, 2010 | Frigidaire FRT21P6BS Top Freezer...
Water dripping inside refigerator
Step 2
Step 3
Step 4
Step 1
Step 2
Step 3
Hope this helpout.......
Aug 15, 2010 | Kenmore 53642 / 53644 Side by Side...
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Maytag MTB1891AR Top Freezer Refrigerator Logo
298 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
