Question about Samsung LN-S4692D 46 in. LCD HDTV
I have the 50' pedestal model HLR5087w model tv blacks out sound no picture after about 15 minutes. Have changed bulb and same problem. Hired a tech and he told me it was the colorwheel. After it came in, he installed the wheel and had the same problem. He then said it was the main board but i don't thrust his judgment now to the tune of 475.00.Can anyone give advice. Jeff
  • 2 more comments
  • jrjefferson0 Feb 25, 2009
    To simard2: the picture goes out but still have sound
  • jrjefferson0 Feb 27, 2009
    After changing th bulb, the tech ordered the colorwheel and installed it and it did'nt solve the problem. He then said it might be the main board which coast 475.00.
  • jrjefferson0 Feb 28, 2009
    Hey Simard2 Sorry but I thought the answer was the one I was suppose to send when the solution was not right.Sorry, I'm just so angry that so many people are having simular problems with the Samsung products and we can't get any satisfaction. I truely appreciate so much you and any others help.THANKS Jeff.
  • Frank Simard
    Frank Simard May 11, 2010
    Do you get sound when the picture goes out for 15 minutes? Does the TV itself go out or just the picture?
  • 124 Answers
It sounds to me that is would be the ColorWheel. I did some research your TV and the ColorWheel has been replaced on that TV a lot! Hope this Helps!
Posted on Feb 26, 2009
  • 2 more comments
  • Frank Simard
    Frank Simard Feb 27, 2009
    I was a 100 percent sure that the ColorWheel was the problem. I will continue researching your problem and get back to you.
    Thank you for using Fix Ya!
    Have a Great One!
  • Frank Simard
    Frank Simard Feb 28, 2009
    Hey Jeff,
    I am still working on your issue. I am working very well and am getting some information. I work so I am not always on this site. I am sorry for the delay. Why are you rating this as "Inappropriate"? I have not given up on your issue and like I said, I'm still working on it.
  • Frank Simard
    Frank Simard Mar 01, 2009
    OK I am sorry to inform you that I cannot find any other information. I would tell you to replace the main board, but that does not sound like that would cause the problem because you are still getting sound. I will continue to look for something that goes wrong with your Model TV and I'll get back to you as soon as possible.
  • Frank Simard
    Good news. I found a website from Samsung that can help you.
    1. Go to THIS SITE
    2. Click on Video and Image Quality Issues.
    3. Click on Image Problems.
    4. Then click on I Have Sound but no Video.
    Hope this helps you Jeff.
Why no sound On Samsung HLR5087 Projection TV?
Either your tuner is bad, coaxial is not plugged in all the way, or your box is bad.
Dec 29, 2012 | Samsung HLR5087W 50" Rear Projection HDTV
Samsung dlp tv picture turns off sound stays on
Check whether the lamp life hours are going to be out. Refer to its user manual for details. DLP chips fault is very rare; unless you have handled them very carefully. Check the lamp and BALLAST baord that supplies voltage to lamp.
Picture of the ballast baord to your TV is attached.2_29_2012_10_35_36_am.jpg
Feb 29, 2012 | Samsung HLR5087W 50" Rear Projection HDTV
I have a 50" Phillips
Check ur owner manual or call Philip support Tech. ask it this tv model have a colors wheel design into it tv.Not sure for a Philip model tv 50" DLP tv,but the Samsung model 50" DLP tv this problems alway causes by a dying colors wheel that design into it tv.Which the colors wheel it is warp worn out and spinning off of it motor mount axis to cause grinding noises and tv colors to mess up and flashes or have flashes Black & White within it picture.
Jun 07, 2011 | Philips 50PL9126D/37B 50" DLP TV
The TV just started making a loud buzzing noise last week, the buzzing sounds begins after the TV has been turned on for 15 or so minutes- the sound stops about 15 seconds after the TV is turned off. The...
This tv have a colors wheel. The tv colors wheel is dead.The buzzing noise is the cause of the colors wheel is spinning of is axis and rubbing sides of the motor.Hire a tv tech. for the job.Colors wheel is hard to replaced,because have to take out many other machanical parts,even before can change the colors wheel it self.
Aug 31, 2010 | Samsung HL-P6163W 61" TV
Problem With KENMARK flat Screen TV - BLACKS OUT
you do not give the model number for a better diagnosis
the most common cause of this problem is the invertor or at worse the screen its self.
If it is a lvd 163 you can purchase a new invertor from sales@tvs-services or call 01245392539
Feb 14, 2010 | Zenith IQC50H95W 50" Rear Projection...
No picture
Pull the front cover off at the bottom. You will see a panel which has to be removed using a screw driver. Inside you will see the lamp assembly. It is a removable box. The lamp can be changed out by just changing out the connections on the new lamp. Before you pull it though try reducing your picture size to 4:3 it helped us to get a little more life out of our lamp.
Apr 07, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
White vertical lines in picture
It's not connections. On that particular unit I would suspect the Digital board, Samsung p/n# Bp94-02084a or the Dmd board. Have you ever noticed the picture freeze?
In any event, sounds as though you're going in the right direction having a tech test it out, it gets highly complicated...
Not sure why he replaced the lamp - but maybe he found it was about to expire.
Nov 14, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
RCA HD61LPW42 runs for an hour then pic goes out for a minute and comes back
sounds like another crappy color wheel issue, just like my samsung hln617w.
Aug 04, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
104 people viewed this question
Jerry Greenberg
Jerry Greenberg
