Question about Kenmore 22422 Top Load Washer
Machine is leaking when filling with water Under the lid there are the following number 24422300 and CS0256934
  • howiek622 Feb 25, 2009
    I had the machine on its side and looked at all of the hoses. None appear disconnected or broken. I was hoping it as just a hose.
    Thanks for the input
  • howiek622 Feb 26, 2009
    It seems to be leaking when the washer is putting water in to start wash. I see hoses at the top of the washer. But, can;t reach them.
    I don't see how to take the thing apart.
    As for the model. I found 2 sets of numbers 24422300 and CS0256934
  • 26 Answers
If machine is leaking check all connectors on the drain hose make sure their tight and also check for cracks. If you find nothing externaly then its internal and need to open the washer and check the hoses for lose connections or cracks on the drum and water pump.
When you do this be sure to have it unplugged and drained of water!!
and follow basic eletrical saftey!!
Hope this info helps to anyone who reads it.
Posted on Feb 25, 2009
  • brandon8534 Feb 25, 2009
    What is the model number of the washer? Also you should check if the drain hose is a correct fit to the socket on the washer also remove the drain hose to see if any cracks are on the drain socket if not the hose should be tightened with a worm screw clamp.
The contact button (part where you put the door down to make the washer start to agitate) something came apart....washer is filled with water and now won't go. The part came out.
you broke the lid switch,send the full model number located under the lid,lift the lid up,follow the lid to the bottom and look right under it and you'll see the model number,it will start with like 110.
Aug 30, 2011 | Kenmore 22422 Top Load Washer
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks...
Fisher and Paykel, EcoSmart with lid lock. After initial fill, all wash lights go out, advances to rinse, then beeps continuously. Have to shut machine off and start over. Continues to wash, but leaks out of top panel under lid. Machine is level. Any Suggestions?
Jul 28, 2011 | Fisher and Paykel WA37T26G Top Load Washer
Kenmore series 80 washer. Will not stop filling. Water shuts off when machine is unplugged. Will drain water on spin cycle as it should. I would appreciate some pictures/diagrams to accompany any help you...
Hello lonestar,
firstly i would like to thank you for writing a well written question it helps me to pinpoint the exact problem with your washer!!
Since the water stops as soon as power is removed to the machine the problem is that the water level switch is shorted out.
it could have been the water inlet valve sticking but with the power off if the valve were sticking it would continue to fill with power off
Un fortunitly with just "series 80" i could not pull up any pictures to show you the water level switch,reply with complete model number as found on a label under the lid near the fill spout on the rear of lid opening
Gene
Jul 26, 2011 | Washing Machines
Where is number of machine
Under the lid at rear. Probably have to clean powder off to see number.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 22, 2011 | Kenmore 24032\24036 Top Load Washer
Not spinning or rinsing?
After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
May 28, 2010 | Roper RAX4233PQ Top Load Washer
I have a top loader whirlpool ultimate care 2 it keeps stopping once filled with water it stops have had timer replaced
May 27, 2010 | Whirlpool Washing Machines
Machine fills with water and then the water just sits there. The only way the machine will do anything is if I turn the knob to drain and spin the water will drain and the machine will spin. Please advise.
Need a model but check the lid switch on right side a little opening under the lid. push with a small screw driver and see if you hear a click, maybe a bad lid switch.
May 19, 2010 | Washing Machines
Our washing machine will not fill cold water. the
You may have a defective cold water solenoid on the water inlet valve. There is a separate solenoid for hot and for cold. So, if you've confirmed the inlet screens are clear, more than likely you will need to replace the valve. If this is a Kenmore top loader, the following link explains how to replace a water inlet valve:
http://www.fixya.com/support/r600647-replacing_water_inlet_valve_kenmore
This is a very simple and inexpensive repair. The average cost is about $30-$35. A replacement can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you need further assistance, please post back with your complete model number (located under the wash lid along the tub rim), so that I may be able to provide you with better service. I hope this helps you.
Oct 12, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number (located around the tub opening under the lid) and look under the "Top and Cabinet" heading. If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 21, 2008 | Kenmore 22422 Top Load Washer
Kenmore Washing Machine fills with water then just stops
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your model number and look under the "Top and Cabinet" heading for item number 11 for the lid switch and item number 20 for the lid strike (if needed). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Oct 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
111 people viewed this question
Richard Roth
Richard Roth
Archaeology
Archaeology
Fordexpert
