Question about HP OfficeJet Pro L7580 Color All-in-One Printer
Why is my Hp Officejet J6480 All-in-One is not showing connection
I just purchased a hp officejet J6480 All-in-One. I installed it with the software, but it won't print and the officejet fax menu ''how do I.....'' when selected, is telling me,''There is no computer connection.''
5 Suggested Answers
  • 35 Answers
SOURCE: printer, fax ,scanner,copier hp officejet 4255
hi....
pls click this link below. this is a link where you can get the software to download and select your operating system first.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351125&lc=en&cc=us&dlc=en&lang=en&cc=us
Posted on Aug 01, 2008
  • 65 Answers
SOURCE: user instructions for printing envelopes on HP OfficeJet J6480
Here is a link to the manuals. Let me know if you need any more help.
Please rate this as Fixya if I've helped you.
Posted on Dec 02, 2008
POCBM
  • 121 Answers
SOURCE: Error message on my Hp Officejet J6480-Fax log full
Press the Setup button (c01361401.gif ).
  1. Press the Right arrow button (c01185072.jpg ) until Tools displays on the control panel, and then press OK .
  2. Press the Right arrow button (c01185072.jpg ) until Fax Log displays on the control panel, and then press OK .
  3. Press the Right arrow button (c01185072.jpg ) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
  4. Press the Cancel button (c01235250.gif ) to exit.
Hope this helps
Posted on Mar 11, 2009
nalin_elliot
  • 224 Answers
SOURCE: I have a HP Officejet J6480 and I am getting an error that says lcd list needs to be upgraded"
This is an easy resolution open the hp solution centre on the computer and click on settings.In the settings window point to scan settings and select the option scan to setup.
Now a new window will open and in the new window move all the items on the left hand side to the right and then click on update the device or ok and now check you will not face this issue anymore.
Posted on May 28, 2009
Sundar2579
  • 26 Answers
SOURCE: Where is the serial number on an HP Officejet
Usually the serial number can be found either in the back or in the bottom of the printer.
If your printer is working you can print a self diagnostic page which would have the serial number.
To print the Self-Test Diagnostic Page
• Device control panel: Press Setup, select Print Report, select Self-Test Report,
and then press OK.
• Toolbox (Windows): Click the Services tab, and then click Print a Test Page.
Posted on Sep 09, 2009
Hock up hp officejet j6480 withouta disk to a sony computer??
If you have Internet access you need to visit HP website at the following link below:
http://www8.hp.com/us/en/support-search.html?tab=1#/qryterm=hp%20officejet%20j6480&searchtype=s-002
1. Enter the product hp officejet j6480
2. Select Go then click on the match found below.
3. Select your operating system . If you are not sure which operating system you have
1. Go to the start button and right mouse click on computer
2. Select Properties
3. Windows edition will let you know what version of windows you have and the type of system you have will be displayed under system type
4. Next select driver and download your HP Officejet Full Feature Software and Driver
Apr 05, 2014 | HP Officejet 5610 All-In-One InkJet...
My mother board had to be replaced on my pc that
I always use HP printers and every time i get a new operating system (vista, win7 etc) the HP software does not fully install. I go to HP.com to install the latest software for the appropriate OS but rarely get more than just the printer working. If i require the scanner or cd print features i have to do that from an older computer or older operating system that the printer was originally installed on.
Oct 15, 2013 | United Stationers HP Officejet J6480...
Officejet J6480 won't scan. It indicates no
If you have the cd installer for your printer, try to install the driver for scanner... don't forget to disable first the connection of your printer from your computer when installing the driver...
If you don't know the location of the driver, try browsing first the cd installer..
May 26, 2010 | HP J4680 Office Jet All-In-One Printer
The hp director scan function no longer works properly. How can I correct the problem? Can I load just the hp director from the printer software?Printer is an hppsc 1210 all-in-one.
If this issue occurs, after installing the new version or revison of internet explorer then try to download the "Critical update to resolve an issue with HP Director after installing a new revision of Internet Explorer" from HP Website if the operating system is Windows XP.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=90764
If this issue occurs, in general follow the below instructions to solve the issue.
  1. Download the HP Officejet J6480 All-in-One Printer
  2. Install the HP Officejet J6480 All-in-One Printer while installing do not connect USB cable at any point of time if it asks, check USB connect later
  3. Download the HP PSC 1210 All-in-One Printer
  4. Install the HP PSC 1210 All-in-One Printer connect the USB cable when it asks to connect
Download the printer full feature software based upon your operating system.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3635378&lc=en&cc=us&dlc=en&lang=en&cc=us
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=90764&lc=en&cc=us&dlc=en&lang=en&cc=us
This should resolve the issue.
Sep 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
I lost the install disk for my hp j6480
Hello and Welcome to FixYa!
Click on the following link and select your operating system to download your printer's software and driver.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=&cc=us&product=3635378&lang=&
Kindly rate me if i was helpful.
Regards,
Waqar
Sep 03, 2009 | HP Officejet 5610 All-In-One InkJet...
Pick up Phone calls on HP officejet
Well this printer is not supposed to recieve calls.But it can recieve faxes.You have to set it up while you are installing the software on your computer.There are perfect resolutions avaiable for the same,but its kind of lengthy.If you want any further support, an online technician from techbuddies can help you for free.For this log on to http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet J6480 ink level control
Your printer is the genune hp printer. It will not show the ink level of refilled and non-HP cartridges. Try the original one the problem will get rectified.
Apr 08, 2009 | Digital Products Hewlett Packard OfficeJet...
Need to download the manual for the scanning component of the hp officejet j6480 all-in-one
Hi - You can download the manual by clicking the link underlined in blue below:
j6480
See page 42
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 12, 2008 | HP Office Equipment & Supplies
HP OfficeJet Pro L7580 Color All-in-One Printer Logo
314 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
