Question about Samsung SRP 350 Thermal Printer
SRP-350 Thermal Printer takes ages to print logos and barcodes.
I have recently purchased a Samsung SRP350 thermal receipt printer and whenever I try to print a receipt from my POS software, it will print eventually but it takes for ever (at least 30 seconds) and stops before printing the logo and barcode.
Is there something wrong in the set up?
Second problem...
I have read online and understand you can save a logo to get it printing faster however I have downloaded the software to do this but while putting it into the printer properties I done something wrong and at the top of every receipt I get the document path, how can I remove this from 'BeginDoc' > 'Emulation Commands' as there is nothing no longer displayed in this box to delete, but it still prints it.
Thank you for any help and I will try my best to provide further details if required.
2 Suggested Answers
SOURCE: SRP-350 barcode CODE 128 C printing problem
I have a samsung printer srp-350pg, it is printing garbiches, I download a driver does the samething, used generic driver but nothing changed
Please help
Posted on Jul 21, 2008
  • 148 Answers
SOURCE: Printing Bar Code Labels from Intermec 3400
here is the specific intermec syntax (stx(esc)E1(can)(data)(cr)(data)(cr)(etb)(etx)PRINT
You have to send this sequence with no spaces (use hex equivalent or control c etc)
You can call intermec product support or call Scan Source tech support and they will hep you
Best of Luck
Posted on Jan 04, 2009
Need for driver
Your printer sounds like it might be a bixolon srp-350 badged as a samsung. I dont know if there are android drivers for SRP350. There is an android sdk for SRP350ii. Anyway this is the site where you will find them if they exist - http://www.bixolon.com/html/en/download/download_product.xhtml?prod_id=3
May 30, 2013 | POS X BIXOLON Samsung Kps SRP350 Thermal...
My bixolon SRP 350PLUSII is double printing one receipt, please help me how to solve it
There is no option that I know of, on the printer to do this. I suspect this is an option in the pos software that you are using. If you are using windows try doing a test print to the srp350ii from the printers in control panel and see if it prints once. I am pretty sure it will and that will prove that it is something in the software itself.
Oct 25, 2012 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Please help with the following: Printer BIXOLON SRP 350 IG When I turn it on Power light: Green Error light: Red Paper light: Red The printer "beep ... beep" continously
Looks like you'll have to contact Samsung http://www.samsungminiprinters.com
The operators manual does not give any indication about what to look for if the error light is on.
Here's what the manual states about the paper light:
This light indicates the near end of the paper roll. Install a new paper roll and the printer will continue printing. When the light blinks, it indicates the self-test printing standby state or macro execution Standby state when the macro execution command is used.
Jul 18, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have bixolon srp 350 for my restarant when i give print command from register it always comes in queue with showing error. i done all softaware re installation and self test for printer everything works...
hello, im trying to send a print to my BIXOLON SRP350 Thermal printer by java codes. but java can't use the all the page width, what should i do to use all of the page width ?
Feb 20, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Why won't my Bixolong SRP-275 print the second copy of the receipt? It only printers the first copy, and the second copy is faint at best. thanks,
So it is printing the second copy, just faint? If everything is set correctly in your pos system in regards to fonts, etc, then unfortunately that sounds like a hardware problem. It could possibly be the power supply failing not supply enough current to drive the thermal head, or a main board problem, or even the thermal head might be failing. You could try cleaning the thermal head (black shiny thing you can see when you lift lid up) with isopropyl alcohol. Failing that you need a tech.
Feb 04, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
I have replaced a posiflex receipt printer with a Problem with the POS X BIXOLON Samsung Kps SRP350 Thermal Receipt Serial Drk Gray Ac Printer I have replaced a posiflex receipt printer with a bixolon...
If the print test works, then that rules out cables, etc. Definitely sounds like a comm setting issue. The most common problem with swapping serial printers is incorrect baud rate. Is that winpos from quest in Aus? I think they might use 9600 baud. You change the printer baud rate using the dipswitches under the panel on the bottom of the printer.
Jan 03, 2011 | POS X BIXOLON Samsung Kps SRP350 Thermal...
Please help
Mar 28, 2007 | Samsung SRP 350 Thermal Printer
Sharing srp350 network printer on win98 to winxp
You are correct with the conflict, although, it's a difference in drivers, i think what has happened is when you share a printer with xp, it installs the driver from the pc with the driver and printer attached, and as it is attached to a win98 pc, the full functions are probably unavailable,unlike an xp local driver.
Mar 06, 2007 | Samsung SRP 350 Thermal Printer
Samsung SRP 350 Thermal Printer Logo
204 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
CheckitRight
CheckitRight
Paul King
Paul King
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
