Question about NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614)
How do you hook up your netgear wireless router to your clear wire modem?
    President:
  • 623 Answers
Hi Leon,
have alook at Clearwire's webpage (here), where they describe different setups for your router.
I personally would always prefer to connect the modem to the router via a cable. The cable you will need is an Ethernet (CAT5) cable and the connectors at the end look like this (compared to a phone cable:
You will connect the output of your modem with the WAN port of your router. This port is usually separated form the 4 other LAN ports, which connect to your computers, printers, etc.
(You didn't specify which router model you have, so I can't give you more details, but it should be very obvious, when you look at the back of your router.)
For the initial setup of your router, you should use a second Ethernet cable connected to one of the LAN ports of the router and to the Ethernet port of your computer.
If you need help with the wireless setup of your router, you have to look either in your manual of give me the details of your router (like the model and version, i.e. Netgear WGR614) and I'm happy to assist you.
Posted on Feb 25, 2009
5 Suggested Answers
SOURCE: NETGEAR WIRELESS
hello i have wriless router wgr614 but this is not conecting internet withour wire signals all ok
Posted on Feb 14, 2008
cnavarro
  • 2460 Answers
SOURCE: Netgear Wireless Router won't work with my Linksys wired router.
As asked above, why would you want the wired router and the wireless router on the same network?
The direct answer to your question(s) is found on Netgear's website. http://kb.netgear.com/app/answers/detail/a_id/965/kw/wpn824/r_id/166
The key is to turn off the Netgear DHCP, and give it an address that is unreachable by the Linksys DHCP ie if the Linksys gives out IP addresses starting at 100 or 101, you set your IP address to 99, turn off the DHCP, and plug it into the network NOT using the WAN port, ever. We tend to start at 251 or 221 just for clarity's sake.
The point is you answered your own question. The Netgear wired and wireless works fine. One piece of equipment and better reporting statistics....what are you missing?
Carl
Posted on Apr 25, 2009
  • 59 Answers
SOURCE: Netgear wireless router
Most likely the router is not configured for dhcp or is not renewing to pull an address from your new provider. You will need to login to the router and check the WAN ip address settings. Choose dynamic ip address (it may be currently set for for static or another option based on your previous provider). Once you choose and save the settings, click to renew the WAN ip. If you were already set for DHCP and the address is correct, you may still have an issue with DNS,.. the DNS addresses may be incorrect or non existent. If you have doubts about DNS addresses,.. you may change them to 208.67.220.220 and 208.67.222.222 (opendns) and they will work with most providers (including comcast)
I hope this helps,.. if you need details,.. please leave a comment and I can supply more.
Posted on Feb 08, 2010
  • 825 Answers
SOURCE: belkin wireless G router incompatible with netgear modem
connect your computer to netgear modem alone and check for the ip address in the computer
(make sure that you have selected "assign ip automatically" in computer)...
to open command prompt type "cmd" and hit enter in run box...
then you can check ip address by typing "ipconfig" in command prompt...
make a note of IP adress or ipV4 address found under the heading "ethernet adapter local area connection"
it might be 192.168.X.X
now connect only the belkinrouter and check for the ip address using the same steps above...
it might be 192.168.2.X
make a note of that...
now compare both the ip addresses if they both have the same value in first three places...that is
192.168.2.... or something like 192.168.1.... or 192.168.0.... then you are facing with double NAT issue...
all that you need to do for that is to change the ip address of belkin router...
if it is 192.168.2.1 change into something like 192.168.15.1...the issue will get resolved....if not you can reset the belkin
router by pressing and holding the reset button for 30 seconds using a toothpick when the power is turned on...
Posted on Apr 03, 2010
Testimonial: "Hey there. It took me ages to get around to trying your solution. I was prompted by my old modem dying. Your solutions was perfect."
Cannot connect to internet through netgear n300 wireless router
They are pretty straight forward. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done!
Try resetting it by holding the reset in till it cycles through. This will clear all custom setting and try again.
I normally don't suggest firmware upgrades, but try updating.
192.168.0.1 Defual login if you cleared custom is User: admin Password: admin
http://www.downloads.netgear.com/files/DGND3300v2_UM_14Oct10.pdf
Other than that the unit is damaged / defective.
Oct 25, 2012 | NetGear N300 Wireless Router
Bought this netgear rangemax wireless router and don't know where the wires and stuf*** hook up to.the yellow ethernet wire on the back of router where does that go on the back of my computer terminal of...
Take the ethernet cable which is going from your Warner cable modem to your computer, and run it from your cable modem to the input connection of your router. Then take a second ethernet cable and run it from the router (ports 1, 2,3 or 4) to your computer. Log into your router's setup page (see your instruction manual), and set up all the passwords and wireless settings. Please read the instructions for specifics of your particular router.
Jun 26, 2010 | NetGear RangeMax WPN824 Wireless Router
I ordered a wireless router so I can hook up my PS3. My computer is not compatible with wifi so I thought I'd just leave it hooked up to the modem. The instructions tell me to put the CD into my computer...
You have to use the computer to insert the CD
As your computer is not wireless compatible, you can have this connected to the router itself on the wired connections and use PS3 on wireless
Do NOT connect your computer to modem and also Netgear to modem.
Either one of them won't work. Instead connect modem to Netgear and computer to Netgear with an ethernet cable.
After this type of connection is made, try to setup the router with the CD inserted into computer.
This is how things work!
Jan 22, 2010 | NetGear WNR1000 Router
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
PS3 NAT type 3 issue
HI, Upgrade the firmware on the router and then forward ports on the router for the IP Address of your PS3.
Let me know if you need any further help.
Sep 06, 2009 | NetGear RangeMax WPN824 Router
I just moved and I dont know where my instructions are and I need to hook up my Netgear HELP
Go to Netgear's support site (link) and look under "Routers and Gateways". Choose "Wired Routers & Gateways Modems" or "Wireless Routers & Gateways Modems".
(You might have to tick the box "Display End-of-Life Products" if you don't see your product right away.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Aug 04, 2009 | NetGear Computers & Internet
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Don't have home phone and looking to buy router/modem.
Yes it requires a phone line for AT&T, or a cable modem, or a community wireless modem to hook up to the internet
May 08, 2009 | NetGear DG834G Router
Bright house modem and desktop computer, trying to hook up wireless net gear router for 2nd desktop to get internet? How do I configure the cables?
Connect the lan cable from the dsl modem into the first port on your netgear router ..
make sure your dsl modem is on PPPoE mode so that it autoconnects..
Now just connect to your wireless router via your pc interface..
*Do add a network key to your wireless network to avoid unwanted access
Jan 19, 2009 | NetGear WGR614 Wireless Router
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
NetGear WIRELESS-G WGR614 802.11G WIRELESS ROUTER ($20.00 M.I.RebateTill 06/30/2004) (NETWGR614) Logo
728 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
